rcsfca
Joined: 22 Feb 2008 Posts: 10 Location: San Francisco Bay Area
Posted: Sat Oct 04, 2008 4:29 pm Post subject: Rotax 912UL no start |
Well, brainiacs, I've got a puzzle for you in the Rotax ignition department.
We last flew the KF (a 1993 Model IV - 1200) in June/08, ten hours of flying over two days, from Arizona to its new home in the San Francisco Bay Area. Wonderful flying, no hiccups. Fuel was and still is 100LL. The plane and engine now have 273 hours TT (yes, it's that low, but we know its history very well, so there's no issues about misrepresented use, etc.).
Until last Saturday, neither the plane nor the engine had moved since June. We had it in the hangar, working on the gear and the brakes. I also installed a Battery Minder from VDC in July but that was the only electrical/mechanical change involving the power system.
Last Saturday, we rolled it out, topped off the 100LL, and she started after 20 or 30 seconds of engine-turning but ran rough, as though running on less than 4 cylinders. After about a minute or so, we shut it down and it hasn't started since, and we're goin' nuts trying to figure it out. Cranking, cranking, cranking. Lots of battery but no start.
Fuel system is solid - I opened the float bowl on each carb and they were full of fuel. We tried a bit of starting fluid in each carb throat. No luck.
I looked at the plugs on two of the cylinders and both were very good looking, light tan with no signs of fouling, and the electrodes were very square with no wear.
I then got a spark plug wire tester to see if there was any juice getting to the plugs and the tester indicated NO spark. I then looked carefully at the ignition module wiring to see if there were any apparent wiring problems like bad grounds. Nothing was evident.
So now I have to turn to the forum for insights and others' experience. Do the ignition units go belly up without warning? Am I overlooking something? Ideas?
Rich Cunningham
SF Bay Area
Sbennett3(at)aol.com Guest
Posted: Sat Oct 04, 2008 5:48 pm Post subject: Rotax 912UL no start |
Rich, I have a 4/1200 classic built in 93 myself. I've been flying a lot of cross countries this summer. I only use 93 auto gas when local, but on CC's I use 100LL. I'm having hard start problems the last 4 starts. I spin prop and it seems there's no compression on 1 or 2 cylinders. Today I put 8 ounces per 10 gallons of Marvel mystery in my gas and 6 ounces in my oil res. I think my prob was stuck valves as I have read on here before. Our Rotax motors don't seem to like leaded fuel. If you know it's an ignition problem i'm off base here, but if you're searching, try what I did and it may work. After I flew 150 miles today, I let the plane sit for a couple hours. (while I ate my hot dog and hamburger) When I fired it back up (5'th start) It was pumping up all cylinders and ran like a dream. I'm happy with my results... Steve Bennett 4 classic 1200 speedwing 965hrs and loving my little bird. Oh ya, I live in NC Durham NC
In a message dated 10/4/2008 8:30:36 P.M. Eastern Daylight Time, r66rc-matronics(at)yahoo.com writes:
[quote]--> Kitfox-List message posted by: "rcsfca" <r66rc-matronics(at)yahoo.com>
Rich Cunningham
SF Bay Area
Read this topic online --> - MATRONICS WEB FORUMS - List Contribution Web Site [quote][b]
brucejolene(at)iowateleco Guest
Posted: Sun Oct 05, 2008 4:03 am Post subject: Rotax 912UL no start |
Check for loose wires at the ignition module. You might check wires going
to and from your mag switches. I had a similar problem and it was loose
wiring connections.
Bruce
Kitfox III
kitfoxfugit(at)yahoo.com Guest
Posted: Mon Oct 06, 2008 10:02 pm Post subject: Rotax 912UL no start |
Assuming 912UL, 273 hrs, ran fine in June, sat since, won't start cold.
I leave mine sit a lot as I use it mainly to go places from time to time. I always pull it through slowly and a lot by hand before starting to get the oil up out of the cylinders and into the sump. Never turn it backwards. Sometimes residual oil will have to burn out, but you will see the blue smoke.
Once I had a problem with the ignition switches being off. Another time, it was a low battery, be sure it is fully charged. Another time, one choke was not set right, be sure they both work when you pull the knob. Also be sure the throttle is closed completely to make suction for the "choke" to work, the springs could be opening it some. Then when it starts get it up to around 2200 RPM or so right away to avoid gearbox chatter. Sometimes in hot weather it does not want to be choked for a cold start. One time when attempting a start soon after a long trip, it was vapor locked even though the fuel line was wrapped.
The type and presence of air cleaners has made a difference on mine. It starts and runs best with the big air cleaner on the carb heat box. I don't think you are supposed to use starting fluid. 100LL should not spoil on you like Mogas but even Mogas should last 4 months. I always run TCP when I have to use 10LL, a guy in Tracy has it, I think it is called Declan chemicals or something like that. I leave mine with 100LL or stabilizer in it when I know it will be sitting.
Changing the plugs is cheap and can make it start and run better, especially after a lead diet. Be careful checking for spark, shorting them can be an $800 mistake with that ignition system. Lockwood has a video you should watch before trying to operate it if you are not used to Rotaxes. Rotaxes are good engines, but you can't operate them like Continentals or Lycomings. You have to learn what they need.
JA KF IV Speedster 912UL (at) O70
rcsfca
Posted: Wed Nov 26, 2008 12:43 pm Post subject: Re: Rotax 912UL no start |
Even though several months have passed since you heard about the problem, it was not actually solved until 10 days ago. We tried each of the numerous suggestions that were offered but in the end, I had to have a technician from California Power Systems, the western U.S. distributor for Rotax, come out to my hangar (at Concord, CA (CCR) ) and go through the problem.
Up to that point, I put a lot of attention on the battery (new Odyssey plus an aviation-designed trickle charger from VDC) and the fuel. Neither changed the no-start although the cranking was top-notch!
When the tech came out, he took about an hour, with instruments to determine that both of the Ducati ignition modules were not working, but for different reasons. One of them was completely out of service and had to be replaced. The other had corrosion on several of the leads buried in that wiring stack that sits next to the modules. The corrosion was cleaned up, and guess what happened? It started immediately (and continues to start immediately), within seconds of cranking. We re-balanced the carbs and the work was done. The Ducati unit was $800 and the labor (welcome to California) was $400.
In a way, I wish the problem had been something that you Kitfox detectives cleverly knew about and could have been fixed without the tech (and without the $1200 parts and labor) but the plane is 15 years old now and, well, you know how it goes. At least we don't have to haul our planes out of the water every year and scrape barnacles off the bottom...
Thanks again,
Rich Cunningham
Model IV-1200 912UL
SF East Bay (CCR)
Float Flyr
Posted: Wed Nov 26, 2008 7:26 pm Post subject: Rotax 912UL no start |
True Rich... I pull mine out of the water after every flight and never get the barnacles The pond i launch form has an altitude measured in single digit feet.
Noel Loveys
Campbellton, NL, Canada
CDN AME intern, PP-Rec
C-FINB, Kitfox III-A
912 almost installed
Aerocet 1100 floats
[url=noelloveys(at)yahoo.ca]noelloveys(at)yahoo.ca[/url]
7.29 KB |
8619 Time(s) |
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
