craigtxtx(at)yahoo.com Guest
Posted: Thu Oct 02, 2008 2:56 pm Post subject: RV8A Weight and balance |
I weighed my RV8A and was somewhat surprised at the results. I have a Superior O-360 normally aspirated engine, Sensenich fixed pitch propeller, and forward mounted lightweight battery. The empty weight worked out to 1080 lb with a CG at 74.8" (as measured using a datum 70" forward of the leading edge). With only the pilot (220 lb) on board, I need between 20 and 30 lb of ballast in the rear baggage compartment to be within the acceptable CG with maximum or minimum fuel respectively. Is this typical for an 8A? With a fixed pitch propeller and lightweight battery I was expecting to be not quite so nose heavy. Have others had similar results?
Thanks in advance for your help.
Craig Gallenbach
RV8A, N184CG ........ almost ready to fly
| | - The Matronics RVSouthEast-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RVSouthEast-List |
Dale Ensing
Joined: 11 Jan 2006 Posts: 571 Location: Aero Plantation Weddington NC
Posted: Thu Oct 02, 2008 3:45 pm Post subject: RV8A Weight and balance |
Craig, Go here to see how you compare with other 8A.
http://www.rvproject.com/wab/
Dale
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
vitez(at)carolina.rr.com Guest
Posted: Thu Oct 02, 2008 4:06 pm Post subject: RV8A Weight and balance |
Craig,
I’d double-check those numbers.. I seriously doubt you’re that much off..
Did you use these:
Main wheel right: 94.06” aft of Datum
Main wheel left: 94.06” aft of Datum
Nose Wheel: 34.55” aft of Datum
What was the weight distribution? Can you post the numbers? I also assume the plane was weighted longerons leveled w/ closed canopy etc etc..
Maybe this spreadsheet would help:
http://www.rv8a.com/downloads/RV-W&B.xls
PS.. Just for fun, I used my numbers for weight on each wheel, using the above arms and I got 78.76” empty C.G at 1081 lbs…. which is more in-line with what’d be expected..
Good luck..
Radomir
From: owner-rvsoutheast-list-server(at)matronics.com [mailto:owner-rvsoutheast-list-server(at)matronics.com] On Behalf Of Dale Ensing
Sent: Thursday, October 02, 2008 7:44 PM
To: rvsoutheast-list(at)matronics.com
Subject: Re: RV8A Weight and balance
Dale
----- Original Message -----
To: RV list (rv-list(at)matronics.com) ; SERV (rvsoutheast-list(at)matronics.com)
Sent: Thursday, October 02, 2008 6:56 PM
Subject: RVSouthEast-List: RV8A Weight and balance
Craig Gallenbach
| Quote: | | 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3Dst-List"'>http://www.matronics.com/Navigator?RVSouthEast-List3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3Dmatronics.com3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D://www.matronics.com/contribution3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | | 0123456789 | Quote: | | 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 0 | Quote: | | 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 1 | Quote: | | 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 2 | Quote: | | 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 3 | Quote: | | 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 4 | Quote: | | 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 5 | Quote: | | 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 6 | Quote: | | 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 7 | Quote: | | 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 8 | Quote: | | 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 9
bill(at)repucci.com Guest
Posted: Thu Oct 02, 2008 4:46 pm Post subject: RV8A Weight and balance |
Craig,
One other question, was your -8A level, both fore and aft as well as left and right, when you weighed it?
From: owner-rvsoutheast-list-server(at)matronics.com [mailto:owner-rvsoutheast-list-server(at)matronics.com] On Behalf Of Radomir Zaric
Sent: Thursday, October 02, 2008 8:06 PM
Subject: RE: RV8A Weight and balance
Craig,
Did you use these:
Good luck..
Radomir
Dale
Craig Gallenbach
| Quote: | | 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3Dst-List"'>http://www.matronics.com/Navigator?RVSouthEast-List3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3Dmatronics.com3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D://www.matronics.com/contribution3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | | 0123456789 | Quote: | | 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 0 | Quote: | | 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 1 | Quote: | | 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 2 | Quote: | | 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 3 | Quote: | | 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 4 | Quote: | | 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 5 | Quote: | | 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 6 | Quote: | | 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 7 | Quote: | | 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 8 | Quote: | | 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 9 | Quote: | | st-List"'>http://www.matronics.com/Navigator?RVSouthEast-List | 0 | Quote: | | st-List"'>http://www.matronics.com/Navigator?RVSouthEast-List | 1 | Quote: | | st-List"'>http://www.matronics.com/Navigator?RVSouthEast-List | 2 | Quote: | | st-List"'>http://www.matronics.com/Navigator?RVSouthEast-List | 3 | Quote: | | st-List"'>http://www.matronics.com/Navigator?RVSouthEast-List | 4 | Quote: | | st-List"'>http://www.matronics.com/Navigator?RVSouthEast-List | 5 | Quote: | | st-List"'>http://www.matronics.com/Navigator?RVSouthEast-List | 6 | Quote: | | st-List"'>http://www.matronics.com/Navigator?RVSouthEast-List | 7 | Quote: | | st-List"'>http://www.matronics.com/Navigator?RVSouthEast-List | 8 | Quote: | | st-List"'>http://www.matronics.com/Navigator?RVSouthEast-List | 9
Posted: Fri Oct 03, 2008 4:34 am Post subject: RV8A Weight and balance |
Radomir,
My weights were:
Nose wheel: 321
Right wheel: 381
Left wheel: 379
I weighed the airplane level to within 0.1 degree and used a digital aircraft scale so I'm pretty confident of the weights.
If I use the distance measurements shown on one of Van's examples (the ones in your note) I come up with an empty CG of 76.4 and all is well with pilot and fuel on board. If I measure my airplane, however I get different measurements for wheel locations. When I measure my wheel locations, I get 32.25 for the nosewheel and 92.75 for the mains. The only difference is that when I made these measurements, the airplane was not level, but rather with all wheels on the ground. That might make a difference, but I didn't think it would be that much.
Craig
--- On Thu, 10/2/08, Radomir Zaric <vitez(at)carolina.rr.com> wrote:
[quote]From: Radomir Zaric <vitez(at)carolina.rr.com>
Date: Thursday, October 2, 2008, 7:05 PM
Craig,
Did you use these:
Good luck..
Radomir
Dale
lenleg(at)aol.com Guest
Posted: Fri Oct 03, 2008 4:38 am Post subject: RV8A Weight and balance |
Craig:
Glad to hear you are so far along. I fly with an 18 lb. tool bag on my rear shelf to compensate for a heavy nose. I have a CS prop so that adds weight up front.
Good lluck !
Len
Posted: Fri Oct 03, 2008 4:42 am Post subject: RV8A Weight and balance |
Dale,
Thanks, that's a good reference tool. My CG is considerably different than the others.
Craig
--- On Thu, 10/2/08, Dale Ensing <densing(at)carolina.rr.com> wrote:
[quote]From: Dale Ensing <densing(at)carolina.rr.com>
Date: Thursday, October 2, 2008, 6:43 PM
Dale
Posted: Fri Oct 03, 2008 6:58 am Post subject: RV8A Weight and balance |
I'd use Van's arm numbers. It looks like the arm measurements you got may not be "correct." They're significantly off, but they're also consistent which tells me there's really no problem -- just a measuring difference (eg measured to a different point on wheel etc..)
Even with the best of effort, I doubt you built all your wheels 2 inches forward than everybody else It's (mostly) prepunched kit, right?
Looks like you're in good shape... sounds like first flight is just around the corner
Good luck!
Radomir
---- Craig Gallenbach <craigtxtx(at)yahoo.com> wrote:
Radomir,
Â
My weights were:
Â
Nose wheel:Â 321
Right wheel:Â 381
Left wheel:Â 379
Â
Â
If I use the distance measurements shown on one of Van's examples (the ones in your note) I come up with an empty CG of 76.4 and all is well with pilot and fuel on board. If I measure my airplane, however I get different measurements for wheel locations. When I measure my wheel locations, I get 32.25 for the nosewheel and 92.75 for the mains. The only difference is that when I made these measurements, the airplane was not level, but rather with all wheels on the ground. That might make a difference, but I didn't think it would be that much.Â
Â
Craig
