cyco55(at)COMCAST.NET Guest
Posted: Sat Oct 04, 2008 6:33 am Post subject: command push pull cables |
Has anyone had experience making or buying the push pull cables for throttle, prop, shutters ect?
Posted: Sat Oct 04, 2008 7:19 am Post subject: command push pull cables |
Cy,
Most of the time the problem is not with the inner cable assembly, the problem is caused by the soft copper shield/tube which the cable assembly runs in. The shield becomes dented or kinked and each dent or kink adds to the friction placed on the cable, soon it becomes stiff and unusable. If the dent or kink is within the travel range of the end rods the assembly qiuckly becomes nearly unusable. The outer shield or tube can be easily replaced with std copper tubing of the correct size. I built one up from scratch for the mini yak and I think I used 7/16 copper tubing. If you do need the cable assembly it's doable by contacting the McFarlane company. They can swage the SS rods onto the cable but at that time they did not have the tooling to cut the metric threads on the rod ends.
Like many jobs getting the part out to work on it is 99% percent of the battle, this one is no different, you will be talking to yourself before you get the control R&R'd, so do it on a day when you have your midget contortionist buddy visiting your hanger. Or maybe wait until the circus comes to town to recruit some help.
Hope this helps.
Always Yakin,
Doug
On Sat, Oct 4, 2008 at 7:32 AM, Cyrus Kissling <cyco55(at)comcast.net (cyco55(at)comcast.net)> wrote:
| Quote: | Has anyone had experience making or buying the push pull cables for throttle, prop, shutters ect?
Always Yakin,
Doug Sapp
Phone 509-826-4610
Fax 509-826-3644
czech6(at)mesanetworks.ne Guest
Posted: Sat Oct 04, 2008 7:46 am Post subject: command push pull cables |
Is there any reason we receive the same posting 4 or 5 times?
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Cyrus Kissling
Sent: Saturday, October 04, 2008 8:32 AM
To: yak-list(at)matronics.com
Subject: command push pull cables
| Quote: | | http://www.matronics.com/Navigator?Yak-List | 0123456789
flushjohnson(at)charter.n Guest
Posted: Sat Oct 04, 2008 1:25 pm Post subject: command push pull cables |
I have experienced almost complete lockage of the throttle and prop controls. Could not find any binding in the tubes forward of the front cockpit controls. The binding was bwtween the front cockpit and rear, somebody had tightened the control lock in the rear and moving the front bent the tubes between the two. My advise is to remove the rear control lock knob.
Posted: Sun Oct 05, 2008 6:44 am Post subject: command push pull cables |
Doug,
You found a trained 3 foot monkey with 12” fingers? Is he/she for rent? If so, how much?!
Doc
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Forrest Johnson
Sent: Saturday, October 04, 2008 4:23 PM
Subject: Re: command push pull cables
----- Original Message -----
Sent: Saturday, October 04, 2008 10:19 AM
Cy,
Hope this helps.
Always Yakin,
Doug
Always Yakin,
Doug Sapp
Phone 509-826-4610
Fax 509-826-3644
| Quote: | | href="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-Listhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c | | 012345678901234567
AV8ORJWC
Posted: Sun Oct 05, 2008 6:57 am Post subject: command push pull cables |
We have a manufacturer of Cablecraft control cables here in Portland. I
set up Shane Wease of Vintage Aircraft Restoration for those interested
in the 3' monkey removal and replacement system.
John Cox - Bozo the Clown
[mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Roger Kemp MD
Sent: Sunday, October 05, 2008 7:43 AM
Subject: RE: command push pull cables
Doug,
You found a trained 3 foot monkey with 12" fingers? Is he/she for rent?
If so, how much?!
Doc
Johnson
lock knob.
Posted: Sun Oct 05, 2008 8:59 am Post subject: command push pull cables |
John,
Can you provide more info off line?
doc
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of John Cox
Sent: Sunday, October 05, 2008 9:57 AM
We have a manufacturer of Cablecraft control cables here in Portland. I set up Shane Wease of Vintage Aircraft Restoration for those interested in the 3' monkey removal and replacement system.
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Roger Kemp MD
Doug,
Doc
