Bakerseal Or EZTurn?
Site Admin
PostPosted: Wed Oct 01, 2008 6:22 pm    Post subject: Bakerseal Or EZTurn? Reply with quote
What are the pros and cons of Bakerseal vs. EZTurn for installing all
of the AN Blue fittings? I've got some of both and am about to do
the fittings for the fuel filter and fuel pump. They definitely have
different consistences - Bakerseal is kind of caulky and thick, and
EZTurn is kind of smooth and sticky like tooth paste. Van's says,
"either one". What's the common feeling on these products?
I assume that you just gunk some nicely on the end of the fitting and
then screw it tightly into the other part and wipe up the excess?
What about the flared fittings? Do you put it on the inside of the
flare too, or just the threads for the nut?
Thanks for the help!
Matt
RV-8 #82880
dsvs(at)ca.rr.com
PostPosted: Wed Oct 01, 2008 6:48 pm    Post subject: Bakerseal Or EZTurn? Reply with quote
I use bakerseal and only on pipe threads. If you get a leak from a flared
fitting I would recomend the seals that AC Spruce sells. Don VS
n320wt(at)yahoo.com
PostPosted: Wed Oct 01, 2008 7:27 pm    Post subject: Bakerseal Or EZTurn? Reply with quote
Matt. I use the same ProSeal used to assemble the RV fuel tanks on pipe fittings for hydraulics, fuel and oil. I use Ez-Turn on O-ring fuel pump fittings and the 37 degree flare and have had very few problems with leaks even on 1500 psi hydraulics in the Lancair IV.
BRIAN ALLEY (N320WT)
CARBON FIBER COMPOSITES
101 Caroline Circle
Hurricane, WV 25526
www.carbonfibercomposites.net
304-562-6800 home
304-395-4932 cell
How are you going to win by a nose if you don't stick out your neck?
--- On Wed, 10/1/08, Matt Dralle <dralle(at)matronics.com> wrote:
Subject: Bakerseal Or EZTurn?
To: rv-list(at)matronics.com, rv8-list(at)matronics.com
Date: Wednesday, October 1, 2008, 10:22 PM
installing all
about to do
definitely have
thick, and
Van's says,
these products?
fitting and
excess?
inside of the
Matt
RV-8 #82880
hooverra(at)verizon.net
PostPosted: Thu Oct 02, 2008 6:26 pm    Post subject: Bakerseal Or EZTurn? Reply with quote
“What are the pros and cons of Bakerseal vs. EZTurn for installing all of the AN Blue fittings?”
Matt,
I have used both EZ-Turn and Fuel Lube on AN fittings. The fuel lines appear to be leak free, not true for the brake lines. I will now try Loctite 567 on the brake fittings. Report to follow!!
Ralph & Laura Hoover
RV7A N527LR
Very very close!!
pbesing(at)yahoo.com
PostPosted: Sat Oct 04, 2008 2:02 pm    Post subject: Bakerseal Or EZTurn? Reply with quote
Bakerseal is very messy from what I recall. I had a tiny tin of ez turn and have had it for 10 years now and its still not gone..great stuff and goes a long, long way.
Paul Besing
RV-4 N73DD "Sunny"
Arizona
johnd(at)wlcwyo.com
PostPosted: Mon Oct 13, 2008 2:42 pm    Post subject: Bakerseal Or EZTurn? Reply with quote
I used EZ Turn, not so much to form a seal but to make connecting aluminum AN fittings easier. Makes their removal much easier.
Shouldn’t the flare fitting seal the line? I like the idea of EZ Turn due to the fact you can apply the correct torque without fear of galling the aluminum fittings.
[b]John L. Danielson[/b]
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of RALPH HOOVER
Sent: Thursday, October 02, 2008 8:23 PM
Matt,
RV7A N527LR
Very very close!!
