Lynn Matteson
Posted: Sat Sep 27, 2008 4:04 pm Post subject: CHT probe placement |
When I recently rebuilt my Jabiru 2200 engine, I decided it was time
to make the CHT probe move to a better location, and avoid the
dreaded spark plug gasket removal and replacement problem. I didn't
like the idea of putting the probe under a head bolt as some have
done, fearing the idea of putting 24 lbs of torque on a copper
terminal, so I followed another poster's idea and drilled and tapped
a hole in the head between, and slightly below, the spark plug
locations. Now I find that the temperature readings are quite a bit
above the reported 10 degrees or so difference (from the spark plug
locations) that I have read about for the head bolt locations. I have
looked into this and have decided that the spark plug probes (mine
anyway) position the thermocouple wire attachment point...the point
where the actual reading is made, the "business end" if you will,
(and it is NOT the area that actually touches the head)...one-half
inch above the head surface, and well into the airflow that goes past
this area. This spark plug thermocouple is further insulated by
having it *above* the spark plug gasket, making it even further from
the cylinder head, albeit by a very small amount. I believe this 1/2"
of separation from the head is enough to place the "business end" of
the t'couple in the relatively cool air passing by. I used to see
CHT's of an average of about 275° F, while I now see my CHT's read
about 350-360° F, and up to about 385° F in climb, at 1500' MSL, (at)
80° F ambient. Straight and level flight after a 5 minute settling
down period after climbout will see the 350's I mentioned. My
thermocouple attachment point...the business end...is now closer to
the head, and tucked between the head and a fin instead of sticking
up into the airflow, so I can accept the higher readings, especially
when the engine is running so strong now and climbing better than I
recall it doing before the engine breakdown. I might add that each
flight sees lower CHT's as the engine breaks in.
Any comments?
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200, 562 hrs, and counting...all systems are go.
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Fox5flyer Guest
Posted: Sun Sep 28, 2008 3:32 am Post subject: CHT probe placement |
Just one comment, Lynn. KUDOs!
What you are doing is true experimenting and that is what these airplanes
are all about. Have you spoken to any of the Jab reps about what you're
doing? I'm sure they're aware of it and probably watching very closely.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 397+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
Lynn Matteson
Posted: Sun Sep 28, 2008 4:50 am Post subject: CHT probe placement |
Thanks, Deke.
Talk about experimenting....I just added a second Odyssey PC 680
battery to try to isolate the ignition system while I and Electroair
try to solve some ignition-related gremlins, and until I order the
correct battery box, I just taped it to the console (orange tape, of
course), and wrote on the tape: "Chill out, Inspector, it's only
temporary!"
Regarding the placement of the t'couple probe....someone over in OZ
had already done this, using a hole that was already there (for no
apparent reason), and called the factory to see if it was ok to use
it for that purpose, and they said yes, that's what we used it
for...for a while. Now why they don't still use it is anybody's
guess. Sometimes I think they've got too many engineers working over
there and not enough real mechanics. I've tried to email Jabiru in
OZ, and got no reply...this was regarding my broken crank gear....I'm
sure lawyers monitor the phones, emails, maybe even the air they
breathe.
In the meantime, I'm dealing with some occasionally erratic readings
from the Grand Rapids EIS (not to be confused with the Electroair
Ignition System [EIS] ) in which the readings sometimes go to 5
digits for rpm, CHT, and EGT. If I push "next" then "previous" the
readings read correctly. I suspect that it's something to do with the
proximity of the ignition modules to the GR EIS wires, but that's
what I'm trying to sort out.
Also, in the meantime, I'm flying it and starting to learn to fly
almost over again after 8 weeks (today) of being grounded....for
instance, I learned just the other day that when you make a radio
announcement, the signal goes a lot further and can be heard by more
folks if the radio is actually turned on. : )
Fog's lifting...gotta go....
Lynn Matteson
Kitfox IV Speedster
On Sep 28, 2008, at 7:31 AM, fox5flyer wrote:
<fox5flyer(at)idealwifi.net>
airplanes are all about. Have you spoken to any of the Jab reps
about what you're doing? I'm sure they're aware of it and probably
Deke Morisse
Mikado Michigan
progress."
- Joseph Joubert
N369LM |
gary.algate(at)sandvik.co Guest
Posted: Mon Sep 29, 2008 10:33 pm Post subject: CHT probe placement |
Lynn
I have my CHT probe directly under the Spark Plug but I don't remove the plug gasket so it is sandwiched under the gasket directly on the head.
This is the way most of the Aussies have their CHT probes set up. I never have any signs of leak either.
My CHT's read as we discussed earlier 275 - 295 Cruise and now as it is getting warmer here I am seeing up to 330 in climb.
I recently modified my lower cowl again to get more air out.
I will get some comments from the factory about t=your findings
Gary
Gary Algate
SMC, Exploration
Office Phone: +61 8 8276 7655
This e-mail is confidential and it is intended only for the addressees. Any review, dissemination, distribution, or copying of this message by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error, kindly notify us immediately by telephone or e-mail and delete the message from your system. The sender does not accept liability for any errors or omissions in the contents of this message which may arise as a result of the e-mail transmission.
Lynn Matteson <lynnmatt(at)jps.net>
Sent by: owner-kitfox-list-server(at)matronics.com
28/09/2008 09:43 AM
Please respond to
kitfox-list(at)matronics.com To
jabiruengine-list(at)matronics.com, jabiruengines(at)yahoogroups.com, kitfox-list(at)matronics.com cc
Subject
CHT probe placement
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
Any comments?
Lynn Matteson
Kitfox IV Speedster
Lynn Matteson
Posted: Tue Sep 30, 2008 4:39 am Post subject: CHT probe placement |
Thanks Gary, and by the way, someone smarter than me (and that
includes nearly the world population) suggested that I put one of the
other t'couples back under the spark plug and do a side-by-side
comparison....DUH! why didn't I think of that? I have just
resurrected one of the spark plug terminals and will rob a
thermocouple from an adjacent head, install the plug terminal, and do
that very thing. I think it best to do a flight first and record the
temps that I'm getting, so I can then do a cyl-to-cyl temp variation
chart, then with the one cylinder rigged with the two t'couples,
interpret/guess what the variation between the two locations should
be...within reason of course, then apply this to the other cylinders.
Interesting that you get away with the gasket not being right next to
the head. When Jabiru says to do the gasket removal, t'couple
placement, gasket re-installation, they are creating a lot of work
for us guys with all 4 spark plugs so being monitored. Why haven't
THEY (Jabiru) done their homework, and sorted all this out for us?
There are times that I think that Jabiru hires only engineers who
also have a law degree! (sorry to all you lawyers out there, but this
whole litigation climate in this country and others SUCKS!!)
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200, 562 hrs, and counting...all systems are go, or nearly so...
On Sep 30, 2008, at 2:28 AM, gary.algate(at)sandvik.com wrote:
Lynn
Gary
Gary Algate
SMC, Exploration
28/09/2008 09:43 AM
Please respond to
To
cc
Subject
CHT probe placement
Any comments?
Lynn Matteson
Kitfox IV Speedster
www.matronics.com/Navigator?Kitfox-List _-
www.matronics.com/contribution _-
N369LM |
peteohms
Posted: Tue Sep 30, 2008 8:42 am Post subject: CHT probe placement |
I haven't been following this thread closely but in my own experience I
mounted a CHT probe on a Quicksilver MX and removed the washer per
instructions and soon thereafter had a plug back out almost causing an
emergency landing in a bad spot. I put a plug in WITH the washer and never
had another problem.
Pete
III 912
Hell Paso, TX
_________________ Pete
Leander, TX
Kitfox III, 912ul, Grove |
Lynn Matteson
Posted: Tue Sep 30, 2008 2:29 pm Post subject: CHT probe placement |
I did some tests today regarding the CHT probe placements on my
Jabiru 2200 engine. I'm cross-posting this so others can benefit, and
even make assumptions regarding other engines, perhaps. I was
wondering out loud about how the different mounting locations for the
thermocouple probes might affect the readings of the cylinder head
temps. During my recent overhaul, I decided I didn't like the "under-
the-spark-plug" mounting location, so I changed to a location that
required me to drill into the head, tap it for an 8-32 machine
screw...actually a socket head cap screw...and affix the proper
electrical terminal onto the end of the t'couple probe...after
removing the spark plug terminal of course.
First I went up and got some CHT numbers as the basis for comparison.
I noted that cyl. #1 ran 317, 327, and 340° F, during various phases
of flight. Noting these, I then took the probe from cyl #3 and
attached to it a spark plug terminal (12mm), and installed it onto
the spark plug that lives over the exhaust valve on #1 cylinder. I
first removed the spark plug washer like Jabiru says to do, installed
the probe/terminal, then reinstalled the spark plug washer, and
reinstalled the plug. Then went flying again.
Here is how I'll report the numbers....I'll call the new location
(the machine screw termination) CHT, and the spark plug termination,
SP, as In (CHT/SP)
The numbers I got were as follows (with an ambient of 61° F) (drum
roll please)....initial taxiing= (250/220); taxiing further=
(266/230); climbing out= (308/232); further climbing=(321/243);
leveling off (not recorded for how long level)= (330/245); not noted
what attitude, but not climbing=(334/249); climbing again briefly=
(344/248) I noted that the max differential was 96° F, and the
climbing EGT's were in the high 1200's. I didn't have enough hands,
instruments or inclination to record every aspect of the test, but I
got enough to satisfy myself that my new locations for the CHT probes
work, and now I can rest assured that I'm not overheating the engine
as I thought I might when I first started it up with this
configuration. Needless to say, the CHT's now apparently rise more
quickly, and if you're like me, and you've been accustomed to seeing
it rise slowly and only into the low to mid- 200's, the ol' pucker
factor rises just as quickly and the finger gets close to the panic
button, but it's just numbers, and now that I've done some testing,
I'll relax a bit on this subject at least.
Lynn Matteson
Kitfox IV Speedster
N369LM |
Posted: Tue Sep 30, 2008 3:16 pm Post subject: CHT probe placement |
Great job Lynn.
This makes a lot of sense now. With my pick ups directly against the top of the head (under the washer) I am getting readings that appear to be midway so it really all depends upon where you take the readings -
Good luck and fly "blue side up"
Gary
Gary Algate
SMC, Exploration
01/10/2008 08:07 AM
Please respond to
kitfox-list(at)matronics.com, jabiruengines(at)yahoogroups.com, jabiruengine-list(at)matronics.com cc
Subject
Re: CHT probe placement
SP, as In (CHT/SP)
Lynn Matteson
Kitfox IV Speedster
Float Flyr
Posted: Tue Sep 30, 2008 5:49 pm Post subject: CHT probe placement |
Lynn
I don't have a Jab or for that matter I'm not too interested in installing
one... I'm still working on getting the 912 into my 'fox. Having said that
I think your report on the location of the thermocouples to be to the point
and factual. Thanks. It's always good to keep up on what's being done.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Lynn Matteson
Posted: Tue Sep 30, 2008 6:44 pm Post subject: CHT probe placement |
Thanks, Gary. I know this really helps me to not panic when I see
those "big" numbers. All I gotta do now is to reset the "maximums" on
my EIS so I don't get false alarms. I only got the one when it went
over 392° F the first time I taxied with it, but after that it has
not lit up for overtemps even with the "hotter" probe placement. On
second thought, maybe I won't change them, as now it will just give
me an early warning, and it really won't mean anything...yet.
Lynn Matteson
Kitfox IV Speedster
On Sep 30, 2008, at 7:15 PM, gary.algate(at)sandvik.com wrote:
Great job Lynn.
the readings -
Gary
Gary Algate
SMC, Exploration
N369LM |
paul(at)eucleides.com Guest
Posted: Tue Sep 30, 2008 8:16 pm Post subject: CHT probe placement |
On Tue, September 30, 2008 3:29 pm, Lynn Matteson wrote:
| Quote: | During my recent overhaul, I decided I didn't like the "under-
Good and useful experiment. Would you post a few photos of the thermocouple installation?
I want to do the same with my Rotax 914.
Paul A. Franz, P.E.
PAF Consulting Engineers
Office 425.440.9505
Cell 425.241.1618
Lynn Matteson
Posted: Wed Oct 01, 2008 2:36 am Post subject: CHT probe placement |
I've got photos of the install, and when I remove the plug t'couple
today, I'll take a few how how close together they are. I was amazed
at how close together hey can be physically, yet give such different
readings.
Lynn Matteson
Kitfox IV Speedster
On Oct 1, 2008, at 12:15 AM, Paul A. Franz, P.E. wrote:
<paul(at)eucleides.com>
Paul A. Franz, P.E.
Office 425.440.9505
Cell 425.241.1618
N369LM |
Lynn Matteson
Posted: Wed Oct 01, 2008 10:42 am Post subject: CHT probe placement |
Thanks, Noel....that's the reason that I posted it...because some
people might like the info and want to change their location. The
spark plug location has always been a pain in the backside to me, and
I was even cussin' while I was dealing with just this one yesterday,
and again when I removed it this morning.
Lynn Matteson
Kitfox IV Speedster
On Sep 30, 2008, at 9:42 PM, Noel Loveys wrote:
Lynn
installing
said that
the point
done.
Noel
N369LM |
Guy Buchanan
Posted: Wed Oct 01, 2008 12:32 pm Post subject: CHT probe placement |
At 09:42 AM 9/30/2008, you wrote:
| Quote: | I haven't been following this thread closely but in my own
experience I mounted a CHT probe on a Quicksilver MX and removed the
washer per instructions and soon thereafter had a plug back out
almost causing an emergency landing in a bad spot. I put a plug in
WITH the washer and never had another problem.
Hmmmm. I've been running them for 250 hours without a washer in my
582 and have not had a problem.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
