		pwmac(at)sisna.com Guest
				 Posted: Wed Oct 01, 2008 5:17 pm    Post subject: Switch question |
				Can any one give me a quick answer for the amp rating of a S700-2-10
 switch The application is for a fuel pump that draws 8.5 amps steady state.
 Thanks, Paul
  |  | - The Matronics AeroElectric-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Joemotis(at)aol.com Guest
				 Posted: Wed Oct 01, 2008 6:14 pm    Post subject: Switch question |
				In a message dated 10/1/2008 6:19:02 P.M. Pacific Daylight Time,  pwmac(at)sisna.com writes:
  Strait from the Masters desk, via the Time Warp.
  Joe Motis
  http://www.aeroelectric.com/articles/Switch_Ratings.pdf
 Looking for simple solutions to your real-life financ57x1200540686/aol?redir=http://www.walletpop.com/?NCID=emlcntuswall00000ol?redir=http://www.walletpop.com/?NCID=emlcntuswall00000001" target="_blank">Check out WalletPop for the latest news and information, tips and calculators.
		nuckolls.bob(at)cox.net Guest
				 Posted: Wed Oct 01, 2008 7:13 pm    Post subject: Switch question |
				At 07:13 PM 10/1/2008 -0600, you wrote:
 Thanks, Paul
    It should be okay for this application. We've seen
    a rash of failures for the Carling switches sold
    by B&C and others . . . the ones with riveted fast-on
    tabs. Be sure and install these with LOOSE coupling
    between bundled wires and individual tabs . . . something
    like 2" of free wire that has a pretty good bend
    in it too.
    I'm pretty convinced that the failures observed had
    a beginning with too much mechanical stress on these
    riveted joints. Once the pressure in the joint starts
    to relax, resistance goes up and it's downhill from
    there.
         ( . . .  a long habit of not thinking   )
         ( appearance of being right . . .       )
         (                  -Thomas Paine 1776-  )
				 Posted: Thu Oct 02, 2008 6:02 am    Post subject: Switch question |
				Thanks Bob,
   I have been following the Carling thread. Now I ask what the
 Microswitch part to match the 2-10 Carling.
 Sorry I did not save the Micro link, but now I need a part number.
 Thanks again, Paul
 At 09:10 PM 10/1/2008, you wrote:
 <nuckolls.bob(at)cox.net>
 >S700-2-10 switch The application is for a fuel pump that draws 8.5
 >amps steady state.
 >Thanks, Paul
    in it too.
    there.
				 Posted: Thu Oct 02, 2008 7:29 am    Post subject: Switch question |
				At 07:50 AM 10/2/2008 -0600, you wrote:
 Thanks Bob,
   I have been following the Carling thread. Now I ask what the Microswitch
 Thanks again, Paul
    I published that last week:
 At 06:27 PM 9/25/2008 -0500, you wrote:
  <willslau(at)comcast.net>
 Hi Bob,
 Can you furnish a list of the Microswitch part numbers to correlate to the
 various switch configurations as shown in Fig 11-14, particularly the
 progressive transfer switches? I have some of the Carlings on hand, but am
 considering switching to the more robust product line before installing
 anything. Thanks.
 William Slaughter
 There's a Microswitch catalog for the TL series devices on
 my server at:
 http://aeroelectric.com/Mfgr_Data/Switches/Microswitch_TL-Series.pdf
 There is a correlation between the dash-numbers I adopted
 (and B&C retained) for identifying switch functionality.
 An S700-1-3 is a Micoroswitch 1TL1-3
 An S700-2-10 is a Microswitch 2TL1-10
 etc.
		willslau(at)comcast.net Guest
				 Posted: Thu Oct 02, 2008 3:23 pm    Post subject: Switch question |
				"There's a Microswitch catalog for the TL series devices on
    my server at:
    etc.
    Bob . . ."
 You can order them through DigiKey. Note that the TL series all use screw
 terminals, but Honeywell has similar switches with Fast-On Tabs. It appears
 that the -50 and -70 types are only available in the TL series. The Digikey
 catalog page has all the details.
 William Slaughter
 RV-8QB
