willfly(at)carolina.rr.co Guest
Posted: Fri Jan 06, 2006 5:54 pm Post subject: Saturday |
Weather is good for Saturday. Who want to play and where?
Cappy
| - The Matronics RVSouthEast-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RVSouthEast-List |
sawad13(at)msn.com Guest
Posted: Fri Jan 06, 2006 7:10 pm Post subject: Saturday |
I hope to be out at Goose Creek later in the afternoon. I need to change my
tires on my RV-4 and don't have a clue as how to jack the thing up off the
ground to take the wheels off. If your really bored and want to stop by...
come on over! I won't be out there till probably sometime after 2pm.
Ron Awad
Quote: | From: "Steve Glasgow" <willfly(at)carolina.rr.com>
Reply-To: rvsoutheast-list(at)matronics.com
To: "SERV" <rvsoutheast-list(at)matronics.com>
Subject: RVSouthEast-List: Saturday
Date: Fri, 6 Jan 2006 20:54:03 -0500
Cappy
jclarkmail(at)gmail.com Guest
Posted: Fri Jan 06, 2006 7:18 pm Post subject: Saturday |
If you get to Columbia by 11:45, you can go with us for BBQ.
James
On 1/6/06, Steve Glasgow <willfly(at)carolina.rr.com> wrote:
This is an alternate email. Please continue to email me at
james(at)nextupventures.com .
WVSWIFT(at)aol.com Guest
Posted: Fri Jan 06, 2006 7:21 pm Post subject: Saturday |
Ron:
General Waskow at Bradford in Huntersville has a neat jack for the RV4.
Jacks only one at a time by threaded rod.
Eddie Shields
Larry(at)bowenaero.com Guest
bill28104(at)yahoo.com Guest
Posted: Fri Jan 06, 2006 7:36 pm Post subject: Saturday |
hey Ron, I ordered a jack for rv's. should arrive
next week. if you can wait, you can use it. bill
--- Ron and Shannon AWAD <sawad13(at)msn.com> wrote:
Shannon AWAD" <sawad13(at)msn.com>
Posted: Fri Jan 06, 2006 7:41 pm Post subject: Saturday |
Could I just lift the plane up off the ground by the engine mount with a
Chain fall??? I may end up waiting till I get use of a proper jack but my
tires got alot of wear and tear on my trip to Florida last weekend and the
tires now are BALD BALD BALD!!!! I would like to change them out before I
fly it again.
Ron Awad
Subject: RE: RVSouthEast-List: Saturday
Date: Fri, 6 Jan 2006 19:36:22 -0800 (PST)
> sometime after 2pm.
> Ron Awad
> Glasgow"
> where?
> >Cappy
> browse
> Subscriptions page,
> FAQ,
> Admin.
http://toolbar.msn.click-url.com/go/onm00200415ave/direct/01/
tadsargent(at)bellsouth.n Guest
Posted: Fri Jan 06, 2006 7:57 pm Post subject: Saturday |
Ron I'll be there tomorrow with instructions how to remove tires. Also use Bill's jack it is safer, unless you want to take the cowl off. Also the method you are thinking of may spin the a/c around.
Quote: |
Date: 2006/01/06 Fri PM 10:41:17 EST
sportav8r(at)aol.com Guest
Posted: Fri Jan 06, 2006 8:24 pm Post subject: Saturday |
I don't know, Cappy - the voices are telling me to stay home and clean my guns tomorrow...
eanderson(at)carolina.rr. Guest
Posted: Fri Jan 06, 2006 8:34 pm Post subject: Saturday |
Ron, I have a clamp that you clamp to the lower leg (near the brake) and
then use a car jack to lift the axle. Got both out at the Hanger. But the
screw jack of Bill's might be easier.
Ed
Posted: Fri Jan 06, 2006 8:57 pm Post subject: Saturday |
I will have a look in your hangar for the clamp
Ron Awad
To: <rvsoutheast-list(at)matronics.com>
Subject: Re: RVSouthEast-List: Saturday
Date: Fri, 6 Jan 2006 23:34:12 -0500
Ed
Posted: Sat Jan 07, 2006 4:41 am Post subject: Saturday |
Thanks for the offer but I made plans to visit Mike Louder's project in Stanley county. Next time for sure.
Cappy
Posted: Sat Jan 07, 2006 6:45 am Post subject: Saturday |
Ron, the clamp is in my tool bag in the aircraft, behind the pilot seat
back. Its a "U" bolt with a piece of Green Angle iron. The "U" bolt has
two nuts on each leg, big nuts are oversized and are simply spacers. Take
nuts off, put "U" bolt around gear leg as close as you can get it to the
brake caliper mount. Put the legs of the "U" bolts through the holes in the
angle iron. Tighten it down Good. The take the car jack and slip it under
the angle iron, jack up the angle iron and gear. If you are going to have
the wheel off a while I would put a block of wood under the axle.
Car jack is beside the storage cabinet.
Remember you will have to disassembly your brake caliper - otherwise the
rotor will keep you from pulling the wheel off after you remove the axle
nut.
Ed
Posted: Sat Jan 07, 2006 6:53 am Post subject: Saturday |
It picks up at the axle. Real neat and small to carry in plane.
Eddie
Posted: Sat Jan 07, 2006 7:23 am Post subject: Saturday |
Thanks Eddie, will have to pull the pants off and take a look later today.
Ron Awad
RV6AN25EH(at)aol.com Guest
Posted: Sat Jan 07, 2006 2:43 pm Post subject: Saturday |
Hey Ron,
Do not use the engine mount ring to lift the your plane. I have heard of
this breaking the engine case. Note: this ring is to lift the engine only!
Ed Horgan
N25EH
Posted: Sat Jan 07, 2006 5:31 pm Post subject: Saturday |
I was thinking of hooking the chain up to the engine mount itself and
pulling up only on one side at a time, but will try Ed's clampy thing, and
if that doesn't work I will see if I can use the one Eddie mentioned.
Ron Awad
