carl(at)flyers.freeserve. Guest
Posted: Mon Sep 29, 2008 9:14 am Post subject: Europa-List: Re: Europa-List: Mod 72 - Undercarriage mountin |
The easy solution which will only work if you do it before jamming the insert in the tube is to file down the end of the taper so that it fits all the way - you will need a lathe or drill to do this.
SORRY, I just re read this. I meant to say taper the end of the steel insert using a file or similar so that it matches that of the reamer. What I actually said doesnt make a lot of sense - probably still doesnt.
530 Bytes |
618 Time(s) |
