coop85(at)cableone.net Guest
Posted: Sun Sep 28, 2008 8:06 am Post subject: engine transport |
Kind of an off topic question, but this the best forum I’ve seen to get ideas.
As a gluten for punishment, I’ve started another project, a Steen Skybolt (repeat offender in that as well as the RVs). Due to retiring I’ll be moving and am trying to find the best way to move the engine. It’s currently on the airplane but the airframe would be easier to move and fit better in the truck if I take the engine off. I’m leaning toward leaving the engine attached to the mount and set in on the floor pointed nose up with the engine mount on the floor of the truck. BTW the engine is the same as in my -10, IO-540-D4A5.
Any concerns over traveling for a day with the engine pointed up instead of horizontal?
Marcus
Posted: Sun Sep 28, 2008 9:00 am Post subject: engine transport |
Marcus Cooper wrote:
| Quote: | Kind of an off topic question, but this the best forum I’ve seen to get
ideas.
of horizontal?
It'll ride just fine that way. You've probably thought of draining the
oil already. If the truck has wood floor, drive a few drywall screws
through the mount to keep it from walking.
Linn
Marcus
AV8ORJWC
Posted: Sun Sep 28, 2008 9:08 am Post subject: engine transport |
At any given moment, there are intake and exhaust valves at various stages of being open (from the camshaft lobes). Fluids can seep by the rings. Make sure your oil level does not allow leakage out any openings to areas not intended. Have a great drive. It is called a Sump and placed so gravity keeps fluids in the correct locations.
John
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Marcus Cooper
Sent: Sunday, September 28, 2008 9:06 AM
Subject: engine transport
Marcus
Do not archive [quote] [/b][/b][/b][/b]http://www.matronics.com/Navigator?RV10-List[/b]http://forums.matronics.com[/b]http://www.matronics.com/contribution [b]
KiloPapa
Joined: 24 May 2006 Posts: 142 Location: Pearblossom, CA
Posted: Sun Sep 28, 2008 12:16 pm Post subject: engine transport |
Here is how the engine I bought from a private party was secured for shipping. (Plywood box cover removed)
Kevin
40494
[img]cid:034001c921a6$6601a8c0(at)KevinPam[/img]
[img]cid:034101c921a6$6601a8c0(at)KevinPam[/img]
83.08 KB |
442 Time(s) |
92.42 KB |
415 Time(s) |
_________________ Kevin
40494
do not archive |
Posted: Sun Sep 28, 2008 5:06 pm Post subject: engine transport |
I'd see if anybody near you has recently received an engine and still have their shipping crate. You could just borrow (or otherwise acquire) it and ship that way. That's the safest way I can think of. Might be an engine or airplane shop near you that has a crate they would let you have. Maybe worth a couple of calls. I'd give you one but I usually just keep one on hand in case I need it and disassemble the rest.
Jesse Saint
Saint Aviation, Inc.
Cell: 352-427-0285
Fax: 815-377-3694
On Sep 28, 2008, at 12:05 PM, Marcus Cooper wrote:
| Quote: | Kind of an off topic question, but this the best forum I’ve seen to get ideas.
Marcus
| Quote: | http://www.matronics.com/Navigator?RV10-List
blue; text-decoration: underline; ">http://forums.matronics.com
style="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution
