don(at)dmack.net Guest
Posted: Mon Sep 29, 2008 5:32 am Post subject: Running AOA tubing in RV-6A |
Hello,
I am trying to add an AOA to my Dynon on my 6A. It connects to the Dynon
Pitot. I am attempting to run the tubing behind the tank and in front of the
spar. I am trying to do this without removing the tank. I can not get the
tube to go through. It feels like it is going to the end of the tank and
being blocked. I shined a flashlight down the space at the wing root in a
dark hanger and could not see any light when I looked from the wingtip to
the tank. I do not see anything on the plans that would indicate something
is there. Does anyone know if there is something there or a suggesting for
running the tube?
Don Mack
Posted: Mon Sep 29, 2008 7:37 am Post subject: Running AOA tubing in RV-6A |
Don,
IIRC, there is a double rib just outboard of the tank which I drilled through and put in a set of grommets.
To carry the line, I removed a few of the nutplates for the top attach screws and put an angle bracket under them for an additional nutplate which fastened an adel clamp....about three places. I have pictures at home...if you want 'em.
I think I can state with confidence that the tank will need to come off - unless you snake the hose through the lightening hole in the double rib - but it'll probably rub there.
Ralph
RV6AQB Slider N822AR (at) N06 - getting my final airworthiness application paperwork reviewed.....
sbuc(at)hiwaay.net Guest
Posted: Mon Sep 29, 2008 7:53 am Post subject: Running AOA tubing in RV-6A |
No need to remove a tank!
I added an LRI AOA to my flying RV-6 and the probe lines are routed
through the wing rib lightning holes. Just use commons sense for
securing the tubing to the ribs. I slipped a short length of rubber hose
over the tubing at the ribs, drilled a 1/4" hole near the edge of a
lightning hole, and secured the tubing to the rib with a zip tie. Other
simple methods will work as well, no need to get complicated.
If you have a wiring conduit in the wing, you may be able to snake the
tubing down the conduit.
Sam Buchanan
Ralph E. Capen wrote:
<recapen(at)earthlink.net>
Don,
Ralph RV6AQB Slider N822AR (at) N06 - getting my final airworthiness
n1cxo320(at)salidaco.com Guest
Posted: Mon Sep 29, 2008 8:59 am Post subject: Running AOA tubing in RV-6A |
Sam is right, I cut a slit in the flex conduit in the wings and ran the
tubes from the LRI into it and pushed them to the fuselage...works just
fine.
Posted: Mon Sep 29, 2008 9:33 am Post subject: Running AOA tubing in RV-6A |
John and Sam may be right about being able to run it without removing the tank by using the flex tubing - I recall my tubing being aft of the spar and Don is trying to go forward of the spar. Depending on where the Dynon computer is mounted, you may have to cross the spar eventually.
Posted: Mon Sep 29, 2008 10:36 am Post subject: Running AOA tubing in RV-6A |
eventually.
The tubing has to go to the panel to be connected to the Dynon. The spar
can be crossed at the same place as all the stuff going to the back of
the airplane.
Sam Buchanan
Posted: Mon Sep 29, 2008 11:08 am Post subject: Running AOA tubing in RV-6A |
Agreed!
