gmcjetpilot
Posted: Fri Sep 26, 2008 5:15 am Post subject: IMC - What If??? |
Good point about lighting and agree, but
one fine point. Most static and ground
straps help the airframe more than
avionics. You need to isolate the avionics
from the airframe and feed it with a
truly isolated interrupt power supply.
Most "homebuilt" EFIS don't have to meet
any specs but many do try to have at least
a regulated power supply. That is good to
protect the expensive parts in the main box
but may sacrifice it self in a surge.
Bottom line it goes dark.
Lighting is an amazing and powerful force
that we have scratched the surface. I have
been a pilot of planes that have been hit
by lighting from a small twin (aerostar)
to large twins B737. Each time damage was
done but to the airframe not the avionics.
Not saying that will be the case every
time, just my experience.
The day will come that a EFIS causes a GA
accident in IMC. There have been plenty from
vacuum pumps, so its not shocker the risk is there.
>What's gonna happen when you're up there
>and a lighting bolt strikes your RV and
>fries all your electrical systems?
| Quote: | Without ground straps on your control
>surfaces and static wicks your
>electronics could be the least of your
>problems. Actually we spent a lot of
>time with the help of Crossbow designing
>in lightning protection on the
>electrical connections that wire to the
>EFIS. Crossbow has extensive experience
>with passing the lightning protection
>requirements for certification. We have
>not actually done lightning verification
>testing of our EFIS or the RV-10.
RobHickman(at)aol.com Guest
Posted: Fri Sep 26, 2008 7:18 am Post subject: IMC - What If??? |
In a message dated 9/26/2008 6:17:04 A.M. Pacific Daylight Time, gmcjetpilot(at)yahoo.com writes:
| Quote: | Most "homebuilt" EFIS don't have to meet
The AFS internal Lithium battery powers the system after the protected regulated power supply. If a voltage spike takes out the regulator the screen will not go dark until the battery run's down, usually over an hour.
Rob Hickman
Advanced Flight Systems
Looking for simple solutions to your real-life financial challenges? Check out WalletPop for the latest news and information, tips and calculators.
khorton01(at)rogers.com Guest
Posted: Fri Sep 26, 2008 11:18 am Post subject: IMC - What If??? |
RobHickman(at)aol.com wrote:
Has the ability of the EFIS to remain powered after a lightning strike
been validated by any HIRF/lightning testing, or is it purely
hypothetical? Lots of stuff that looks good on paper fails when
subjected to testing.
Kevin Horton
Kevin Horton
RV-8 (Flight Test Phase)
Ottawa, Canada
http://www.kilohotel.com/rv8
Posted: Fri Sep 26, 2008 1:24 pm Post subject: IMC - What If??? |
In a message dated 9/26/2008 12:20:58 P.M. Pacific Daylight Time, khorton01(at)rogers.com writes:
| Quote: | Has the ability of the EFIS to remain powered after a lightning strike
subjected to testing. | You must have not read my original response,
In a message dated 9/25/2008 4:55:37 P.M. Pacific Daylight Time, RobHickman writes:
Actually we spent a lot of time with the help of Crossbow designing in lightning protection on the electrical connections that wire to the EFIS. Crossbow has extensive experience with passing the lightning protection requirements for certification. We have not actually done lightning verification testing of our EFIS or the RV-10. |
Looking for simple solutions to your real-life fi382257x1200540686/aol?redir=http://www.walletpop.com/?NCID=emlcntuswall086/aol?redir=http://www.walletpop.com/?NCID=emlcntuswall00000001" target="_blank">Check out WalletPop for the latest news and information, tips and calculators.
Bruce(at)glasair.org Guest
Posted: Fri Sep 26, 2008 6:56 pm Post subject: IMC - What If??? |
Just remember, with a non TSO'd EFIS, you and your family are the Beta testers.
Bruce
www.Glasair.org
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Bret Smith
Joined: 09 Jan 2006 Posts: 178 Location: Mineral Bluff, GA
Posted: Fri Sep 26, 2008 7:33 pm Post subject: IMC - What If??? |
Bruce,
Following your rationale, anyone who flies a non-certificated aircraft is a Beta tester... I fail to accept your premise.
Bret Smith
RV-9A N16BL
Blue Ridge, Ga
www.FlightInnovations.com
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bruce Gray
Sent: Friday, September 26, 2008 10:55 PM
To: rv-list(at)matronics.com
Subject: RE: IMC - What If???
Bruce
www.Glasair.org
_________________ Bret Smith
RV-9A (Emp) |
Posted: Fri Sep 26, 2008 9:07 pm Post subject: IMC - What If??? |
Yes, to a degree. I built my Glasair III, you built your RV-9. We both know how it was done and the care and pride we took in it.
I didn't write the code in my EHSI or your EFIS. I have no idea of the care or competence that went into it. Meeting TSO specs is one way to gage that level. Finding a bunch of pilots willing to bet their lives on it and fly it around for several thousand hours is another. No thanks, I'll pass.
Bruce
www.Glasair.org
ronlee(at)pcisys.net Guest
Posted: Sat Sep 27, 2008 5:06 am Post subject: IMC - What If??? |
Actually Bret he is right. I read about one guy (RV I think) who had
two different EFIS systems (different makers). He was in IMC and
maybe on approach or setting up for approach the main one quit functioning
properly. The other one worked. I don't recall the specifics but it may have
been a software/database issue.
Ron Lee
Bruce,
Bret Smith
RV-9A N16BL
Blue Ridge, Ga
Bruce
www.Glasair.org
Posted: Sat Sep 27, 2008 5:44 am Post subject: IMC - What If??? |
Yes, it was a GRT EFIS that locked up because a runway was not selected before a vector to final was initiated. He had another Dyon that kept working. He used his AP as the tie breaker. Said it was the most terrifying 10 minutes of his life.
Bruce
www.Glasair.org
Posted: Sat Sep 27, 2008 7:56 am Post subject: IMC - What If??? |
In a message dated 9/26/2008 7:58:03 P.M. Pacific Daylight Time, Bruce(at)glasair.org writes:
| Quote: | Just remember, with a non TSO'd EFIS, you and your family are the Beta testers.
Just because it is TSO'd does not mean it will not fail or have software issues. Last spring I borrowed the new factory Glasair Sportsman with dual AFS EFIS's for two months. We absolutely loved the plane and flew it for over 50 hours, including a trip to San Francisco. We only had two problems in the 50 hours that we flew it. The first problems started after the software in the TSO’d Garmin 430W was updated causing the screen to wash out and disappear in flight. The second problem happened after we entered the Class B airspace on our San Francisco trip, after about 5 minutes of silence (not much traffic today in the Bay Area?) We noticed that the TSO’d 430W had failed at the worst possible time. The radio was sent back to Garmin for repair and it worked great, until it failed again on Glasair’s trip to Sun-n-Fun.
Anything can and will have problems, you need to have the proper training so that you can recognize and handle the failure.
The following is from: [url=http://www.alexisparkinn.com/nwpilot\'s_tranatlantic_flight.htm]http://www.alexisparkinn.com/nwpilot's_tranatlantic_flight.htm[/url]
Then, the G1000 started to go nuts, with the fuel indicators displaying red X's. Next, I received a CO2 detector failure, then GPS-1 failure! At this point I was thinking "What next!?"
Well, I didn't have to wait long: The G1000 display suddenly went black, with white text in the left hand corner saying "initializing system"!
(Note: All this was happening at night, locked in the soup, at FL070 and 200+ miles from the nearest land -- with almost no communication with a ground-based person!)
robertrv607(at)yahoo.com Guest
Posted: Sat Sep 27, 2008 10:17 am Post subject: IMC - What If??? |
Kevin: Would be interesting to hear from EFIS People... on this I will call them
next week to hear what the have to say, as to what is the test they do on
their products...and what is the record of failures as of now...
Bert
--- On Fri, 9/26/08, Kevin Horton <khorton01(at)rogers.com> wrote:
| Quote: | From: Kevin Horton <khorton01(at)rogers.com>
Subject: Re: IMC - What If???
Date: Friday, September 26, 2008, 3:14 PM
| Quote: | --> RV-List message posted by: Kevin Horton <khorton01(at)rogers.com>
screen
| Quote: | will not go dark until the battery run's down, usually over an hour.
Kevin Horton
Kevin Horton
Ottawa, Canada
Posted: Sat Sep 27, 2008 11:34 am Post subject: IMC - What If??? |
testers.
_http://www.alexisparkinn.com/nwpilot's_tranatlantic_flight.htm_ (http://www.alexisparkinn.com/nwpilot's_tranatlantic_flight.htm)
The DO-178B software development process is no iron-clad guarantee
either. All it does is provide a higher level of confidence that the
software was correctly coded such that is works according to the
specification provided by the system designer. But, it provides no
guarantee that the software specification is in fact correct. I know of
multiple occassions where systems with DO-178B Level A (the highest
level) software had major software faults (HUD showing pitch and bank in
the wrong direction, fly-by-wire software crashing, etc) - not because
of software coding errors, but because the software spec did not foresee
all possible operating scenarios.
TSO approval and DO-178B software cert are useful benchmarks, but it is
only with many units in service for many thousands of hours that we
start to develope confidence that the units are trustworthy.
Assume that any device will either fail, or worse, that it will mislead
you. This assumption is important no matter what approvals the device has.
Kevin Horton
Ottawa, Canada
Posted: Sat Sep 27, 2008 11:45 am Post subject: IMC - What If??? |
Bert - there are so many different reasons that an EFIS could fail, or
mislead you, that you should simply assume that it could occur. This is
true whether they have done lightning tests or not.
Don't bet your life on it not failing. Have suitable backups installed,
and be ready and capable enough (i.e. proficient to use the backups in
real IMC conditions) to use them.
Kevin
bert murillo wrote:
| Quote: | Kevin: Would be interesting to hear from EFIS People... on this I will call them
Bert
screen
Kevin Horton
Kevin Horton
Ottawa, Canada
cjensen(at)dts9000.com Guest
Posted: Sat Sep 27, 2008 5:13 pm Post subject: IMC - What If??? |
One data point. Pair of GRT EFISs in a Velocity. 410 hours, almost 10% doing some level of IFR and not as much as a hint of a glitch...of course, that says only a little bit about the likelihood of problems tomorrow, but a set of mechanical AS, Alt, TT A/P and an MCI LifeSaver w/battery backup...not interested in challenging Mother Nature or Fate.
Chuck Jensen
n395v
Posted: Mon Sep 29, 2008 4:49 am Post subject: Re: IMC - What If??? |
Its not only the EFIS or its programming you need to worry about.
My F1 was all electric. 2 different EFISs.
All went black when the solenoid failed.
You need to plan backup into the sytems of the aircraft also.
_________________ Milt |
Posted: Mon Sep 29, 2008 5:07 am Post subject: IMC - What If??? |
That's why my ADI backup is Vacuum.
Bruce
www.Glasair.org
michele.delsol(at)microsi Guest
Posted: Mon Sep 29, 2008 6:46 am Post subject: IMC - What If??? |
Thought I'd add my 2 cents - Both my AFS 3400/3500 have internal batteries,
1/2 hr each. Plus a portable VHF and a portable GPS.
Michèle
RV8 - trying to get it finished.
-----Message d'origine-----
De : owner-rv-list-server(at)matronics.com
[mailto:owner-rv-list-server(at)matronics.com] De la part de Bruce Gray
Envoyé : lundi 29 septembre 2008 15:07
À : rv-list(at)matronics.com
Objet : RE: Re: IMC - What If???
Bruce
www.Glasair.org
Paul Valovich
Posted: Mon Sep 29, 2008 6:49 am Post subject: IMC - What If??? |
Since I started this thread with what I thought was a straight-forward presentation of the analysis I used in determining my panel configuration, perhaps an addition of a not-mentioned analysis factor will provide additional fuel to this debate. That factor is the reliability of vacuum –powered instruments in the days before glass cockpits.
While the focus of recent posts has been on EFIS failure what ifs, it was my understanding that the weak link of pre-EFIS IFR flight was vacuum pump reliability. Is that a correct statement?
If it is correct, then the pre-EFIS analogy to EFIS failure is IMC flight with no vacuum pump. What if???????????
Seems like the challenges would be the same – establishing controlled flight in an upright attitude and having enough confidence in the tools and procedures available in that mode to get it on the ground.
So what do you old guys have to say?
Booger
Posted: Mon Sep 29, 2008 7:39 am Post subject: IMC - What If??? |
True, but we've flown behind the standard six-pack for decades and it's failure modes are well known and recognized. EFIS failures are more insidious and, unless the screen goes dark, not easy to discern.
Vac pump failure is the weak link but with proper maintenance (or a wet vac pump), system reliability can be high.
Bruce
www.Glasair.org
chaskuss(at)yahoo.com Guest
Posted: Mon Sep 29, 2008 9:26 am Post subject: IMC - What If??? |
Paul,
Another way to improve reliability with vacuum attitude instruments is to use a "wet" vacuum pump, rather than a dry (oil-less) unit.
Charlie Kuss
--- On Mon, 9/29/08, Valovich, Paul <pvalovich(at)dcscorp.com> wrote:
| Quote: | From: Valovich, Paul <pvalovich(at)dcscorp.com>
To: "rv-list(at)matronics.com" <rv-list(at)matronics.com>
Date: Monday, September 29, 2008, 10:49 AM
-powered instruments in the days before glass cockpits.
correct statement?
Seems like the challenges would be the same - establishing
Booger
