Trim Tab
robertrv607(at)yahoo.com
PostPosted: Sat Sep 27, 2008 10:03 am    Post subject: Trim Tab Reply with quote
Hi
Recently I have aproblem with the Elec. Trim...II have an RV6A;
When flying, the trim without a reason, goes full up, pitch up....I reset it, and works
Ok for some time..
It is intermitten....Does any one have any idea what can create this auto change???
I know I can put a swuitch to disconnect it... that is not the question..
is a technical for those wiith electrical Knowledge....
I think is always uP... but maybe it has gone down also,,,, I have to check this
to be sure...I know the up is complete full defflextion...
I hate to think I have to opoen everything under,,, to check wires to the
stick???
Suggestions appreciated.
Bert
rv6a
carl.froehlich(at)cox.net
PostPosted: Sat Sep 27, 2008 10:19 am    Post subject: Trim Tab Reply with quote
I’d start with the wires to the stick. As this is an intermittent, my guess is you have a chafing problem so first look at where the wire come out of the stick.
Carl Froehlich
RV-8A (450 hrs)
RV-10 (fuselage)
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of bert murillo
Sent: Saturday, September 27, 2008 2:02 PM
To: rv-list(at)matronics.com
Subject: Trim Tab
Hi
Ok for some time..
stick???
Bert
rv6a
n8zg(at)mchsi.com
PostPosted: Sat Sep 27, 2008 10:23 am    Post subject: Trim Tab Reply with quote
Bert –
Ray Allen had a run of the original-style trim relays with a high failure rate.
The old relays are considerably smaller than the current crop.
Visit the website and compare the photo of the new style to yours.
If you have the old style, I’d contact the company and request replacement.
neal
Sent: Saturday, September 27, 2008 1:02 PM
Subject: Trim Tab
Hi
Ok for some time..
stick???
Bert
rv6a
kcflyrv(at)comcast.net
PostPosted: Sat Sep 27, 2008 1:49 pm    Post subject: Trim Tab Reply with quote
Ditto,
It was the relay that failed in my case about 2 years ago. (RV6) Ray Allen sent me a replacement and it has been perfect ever since.
765 hours
Ken Cantrell
Web:www.viewpointphoto.net
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Neal George
Sent: Saturday, September 27, 2008 11:22 AM
Subject: RE: Trim Tab
Bert –
neal
Subject: Trim Tab
Hi
Ok for some time..
stick???
Bert
rv6a
http://forums.matronics.com
 Filesize:  5.35 KB
 Viewed:  2361 Time(s)
