ghinman(at)mts.net Guest
Posted: Tue Sep 23, 2008 7:29 am Post subject: Wheel pants too low? |
I installed the wheel pants on my RV-8
per Van's directions,but I think they may be too low.
I cannot get a 2X4 underneath the back for a wheel chock
when the plane is down on the tail.
I will be using a grass strip so have concerns.Do others have
their wheel pants this low?
George H. Inman
ghinman(at)mts.net
panamared5(at)brier.net Guest
Posted: Tue Sep 23, 2008 8:35 am Post subject: Wheel pants too low? |
Sounds about right to me, I can not get a 2X4 under the wheel pant
either. I use 1/2" aluminum angle as a wheel chock. Even that is a tight fit!
RV6 "Wicked Witch of the West"
At 10:29 AM 9/23/08, you wrote:
George H. Inman
ghinman(at)mts.net
HCRV6(at)comcast.net Guest
Posted: Tue Sep 23, 2008 9:39 am Post subject: Wheel pants too low? |
I installed my RV-6's wheel pants also per Van's instructions and cannot get any standard chocks under them. I made some "U" shaped chocks from 3/4 PVC pipe and elbows that work great and weigh next to nothing.
Harry Crosby
RV-6 N16CX, flying - 516 hours
-------------- Original message ----------------------
From: George Inman 204 287 8334 <ghinman(at)mts.net>
George H. Inman
ghinman(at)mts.net
rickrv8(at)msn.com Guest
Posted: Tue Sep 23, 2008 12:10 pm Post subject: Wheel pants too low? |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> George,
My -8 wheel pants are the same way. No way will a 2x4 fit behind the tire. Mine seem to be lower in the back compared to most others I've looked at. I have flown on grass strips many, many times with no problem. The only issue I have is getting into hangars that have steel angle installed on the floor as a door track. The back of my pant can't clear these tracks without putting down some type of ramp. I've scarred the bottom rear of my pants numerous times.
Rick McBride
johnd(at)wlcwyo.com Guest
Posted: Tue Sep 23, 2008 4:04 pm Post subject: Wheel pants too low? |
My wheel pants also had the same problem, couldn’t clear the angle on the bottom of my door.
I ended up always backing my plane in by lifting the tail to clear.
When I finally wore the original tire out, I replaced them with retreads and the tires just happen to be taller by ½” to ¾”.
This allowed the rear of the wheel pants to clear the angle.
[b]John L. Danielson[/b]
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Richard McBride
Sent: Tuesday, September 23, 2008 2:07 PM
To: rv-list(at)matronics.com
Subject: Re: Wheel pants too low?
George,
Rick McBride
rveighta(at)earthlink.net Guest
Posted: Tue Sep 23, 2008 4:47 pm Post subject: Wheel pants too low? |
This seems to be a universal problem with the Van's tail draggers. My 8 is the same; I taxi across about 100' of grass to get to my airpark's runway and I get a collection of grass inside the rear half of the pants everytime.
Walt Shipley
Posted: Wed Sep 24, 2008 8:32 am Post subject: Wheel pants too low? |
Walt,
Did you install a bulkhead in the rear half of the wheel pants to prevent crud from collecting back there?
Harry Crosby
RV-6 N16CX, flying - 517 hours
Walt Shipley
timb
Joined: 16 Apr 2008 Posts: 77 Location: Frankston, Texas
Posted: Wed Sep 24, 2008 9:50 am Post subject: Wheel pants too low? |
Interesting, what tail wheel system are you using? I understand there are some available that raise the tail slightly and maybe that would be enough to correct it also.
Tim Bryan
RV-6 Flying
N616TB over 100 hours now
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of John Danielson
Sent: Tuesday, September 23, 2008 6:59 PM
Subject: RE: Wheel pants too low?
John L. Danielson
George,
Rick McBride
_________________ Tim Bryan
RV-6 Flying
N616TB |
robertrv607(at)yahoo.com Guest
Posted: Wed Sep 24, 2008 10:02 am Post subject: Wheel pants too low? |
Harry:::
What is this??? please tell me I should have done that? I did not see that
on the plans.... I have the rv6a, please explain... I am now worried I am
missing that?? how is it done etc...
bert
--- On Wed, 9/24/08, HCRV6(at)comcast.net <HCRV6(at)comcast.net> wrote:
| Quote: | From: HCRV6(at)comcast.net <HCRV6(at)comcast.net>
Date: Wednesday, September 24, 2008, 12:31 PM
| Quote: | --> RV-List message posted by: HCRV6(at)comcast.net
Walt,
Harry Crosby
| Quote: | --> RV-List message posted by: rveighta <rveighta(at)earthlink.net>
8 is the
| Quote: | same; I taxi across about 100' of grass to get to my airpark's
runway and I get
| Quote: | a collection of grass inside the rear half of the pants everytime.
Walt Shipley
Posted: Wed Sep 24, 2008 4:54 pm Post subject: Wheel pants too low? |
