rwhunter(at)integra.net Guest
Posted: Tue Sep 23, 2008 6:56 am Post subject: Firewall |
On page 27-2 step 6 it has you dimple all the rivet holes. In step 7 it
has you rivet everything and it tells you two of the nut plates are to
go on the forward side of the firewall. I have dimpled all these to be
flush on the forward side. What do I do with these two nut plates now
that the holes are dimpled for a flush mounting on the forward side.
Rob Hunter
40432
Fuselage
Posted: Tue Sep 23, 2008 8:00 am Post subject: Firewall |
Rob,
Your gonna think I'm crazy but I'm sure everyone has done this at least once...redimple it on the correct direction...
Rick Sked
40185
pascal(at)rv10builder.net Guest
Posted: Tue Sep 23, 2008 8:10 am Post subject: Firewall |
you'll use them later. One of them to hold the hydraulic lines the other for
something else.
Pascal
Sent: Tuesday, September 23, 2008 7:55 AM
Subject: Firewall
Rob Hunter
40432
Fuselage
woxofswa
