n142ds(at)gmail.com Guest
Posted: Fri Sep 26, 2008 7:34 am Post subject: Rudder Trim |
Does anyone have a picture of a 'powered' rudder trim for an RV-10 install? I'd like to take a look at how folks did it while I'm working on the rudder.
Thanks....
David W. Schaefer
rene(at)felker.com Guest
Posted: Fri Sep 26, 2008 8:33 am Post subject: Rudder Trim |
Tim has some on his site….the RV-10 bible:
http://www.myrv10.com/N104CD/upgrades/20071104/index.html
Rene' Felker
RV-10 N423CF Flying
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David Schaefer
Sent: Friday, September 26, 2008 9:31 AM
Subject: Rudder Trim
Thanks....
David W. Schaefer
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
robin1(at)mrmoisture.com Guest
ricksked(at)embarqmail.co Guest
Posted: Fri Sep 26, 2008 4:52 pm Post subject: Rudder Trim |
Robin,
Your rudder trim is the cleanest to date short of some of the knob and screw systems, how about a little info on the modifications you did such as reinforcement of the trailing edge, additional ribs inside the rudder...anything you can think of that would make this easier for us to duplicate..right now I'm fixin to do the hinge method but some details of your design would be great...I get the tray setup and the servo but what did you do internally to preserve the trailing edge integrity above and below the tab? I really want to go this way, the only thing I may do different is a composite tab instead of the aluminum one...and yes I have stared at your pictures for at least a year or ever since you posted them...just getting ready to get off the pot and cross this one off my list of TODO's but a bunch of newbies to the list will start asking this question, which one just did, hence my request...So how bout a little writeup. Only address the stuff that is not obvious in your photos unless you're feeling expressive!!
Rick Sked
40185
