msausen
Posted: Mon Sep 22, 2008 9:11 am Post subject: eMag/pMag issues |
If anyone is considering using any of the eMag products, I strongly suggest you do your research. I have heard of frequent problems and failures of them over the years and have had discussions with some of you relaying what I have heard from others. Marc Zeitlin and others have had quite a bit of discussion lately on the Cozy builders list and some of that discussion has trickled over into the Aeroelectric and other lists and I felt it was pertinent for any of you that are interested in Emagair.
Below are a couple of links to discussions on this subject. Marc has documented his experience and discussions with others on the Cozy builders website. If you don’t know Marc he has the credentials to backup what he says having graduated from MIT and working as an ME for upwards of 30 years including currently working on SS2/WK2 for Scaled.
I have no hunt in this but I know some of you have been very interested in the upcoming 6cyl version. Read the following items, do your research, make your decisions accordingly. Be safe!
Michael
http://www.cozybuilders.org/Emagair_Warning/
http://www.maddyhome.com/cozysrch/ search for “emagair”
Posted: Mon Sep 22, 2008 10:55 am Post subject: eMag/pMag issues |
Michael,
Using a single eMag or pMag is no problem because if it goes bad you always have the Slick Mag to rely on in an emergency….Oh… wait…can anyone recommend a good parachute?
Robin
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen)
Sent: Monday, September 22, 2008 10:11 AM
Subject: eMag/pMag issues
Michael
http://www.maddyhome.com/cozysrch/ search for “emagair” | Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
n8zg(at)mchsi.com Guest
Posted: Mon Sep 22, 2008 11:31 am Post subject: eMag/pMag issues |
Strong Enterprises… <;-P
neal
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks
Sent: Monday, September 22, 2008 1:54 PM
Subject: RE: eMag/pMag issues
Michael,
Robin
Michael
http://www.maddyhome.com/cozysrch/ search for “emagair” | Quote: | | http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution | 01234567890123456789
msausen
Posted: Mon Sep 22, 2008 12:21 pm Post subject: eMag/pMag issues |
True, but I believe if it starts firing 180 out, as was the case for a couple of these, you won’t really have anything left for the slick to burn. Like I said no dog in this, I already made my ignition decisions. Just wanted to pass along the info and it sounds like they are trying to address the issues. I do find it interesting that a lot of supporters start out by saying that they have had couple of in flight failures but are very happy with them. You Slick mag owners must be ecstatic with yours! J
Michael.
Michael,
Robin
Michael
http://www.maddyhome.com/cozysrch/ search for “emagair” | Quote: | | http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution ; - The RV10-List Email Forum -http://www.matronics.bsp; - MATRONICS WEB http://forums.matronics.com</================== | = -Matt Dralle, List Admin.[/b][/quote]http://www.matronics.com/con[/b] [b]
dlm46007(at)cox.net Guest
Posted: Mon Sep 22, 2008 1:07 pm Post subject: eMag/pMag issues |
Aircraft Spruce sells parachutes. I used one for the test period on my 10. It is one of the few aircraft you could actually use a parachute without a lot of special rigging to get rid of the door.Mine is a National 425. Kind of pricey but if needed priceless.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Neal George
Sent: Monday, September 22, 2008 12:30 PM
neal
Michael,
Robin
Michael
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 0 [quote][b]
