		nuckolls.bob(at)cox.net Guest
				 Posted: Fri Sep 19, 2008 8:14 am    Post subject: Vern's crimp tool performance . . . |
				Vern,
 I was able to run a resistance measurement on your newly
 installed terminals and got readings on the order of 200
 micro-ohms . . . right in step with the values I get from
 a PIDG terminal installed with an AMP T-head tool.
 I was unable to measure the crimps on the terminals off the
 failed switch . . . not enough lead-length to get a grip
 on.  But I did cross section the crimp and got the following
 photomicrograph . . .
 http://aeroelectric.com/Pictures/Misc/VL_Crimp_Tool_1.jpg
 The terminal from the failed switch exhibits no voids in
 the wire grip. Of course, you used this tool on other terminals
 NOT attached to switches and you've not seen a failure there
 so the results of my little look-see were predictable.
         ( . . .  a long habit of not thinking   )
         ( appearance of being right . . .       )
         (                  -Thomas Paine 1776-  )
  |  | - The Matronics AeroElectric-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		rv-9a-online(at)telus.net Guest
				 Posted: Fri Sep 19, 2008 9:05 am    Post subject: Vern's crimp tool performance . . . |
				Thanks, Bob.   I think you've safely eliminated bad crimps as a contributing
 factor.  Much apprectiated.
 Vern
 [quote] --
