rv10es(at)earthlink.net Guest
Posted: Wed Mar 15, 2006 7:09 am Post subject: master switch LED |
Great and simple. This is what I will do. Thanks. How-come I did
not think of this after 25 years of flying?
rob kermanj
On Mar 15, 2006, at 9:55 AM, Buhwana wrote:
Quote: |
What makes you think if you didn't see the master switch on you
would see the little LED? He's a suggestion form a lurker. Turn
your strobe light on and leave it on. when you turn the master
switch on for starting the light signal to everyone to "clear
prop". When you leave the airplane if you are blinded by the
strobes, you left the master on.....
tom RV-6A 939GK
I am wanting to put an LED on the panel that Hill inform us when
the Master
switch is on and the plane is off. We have left the Master switch on
several times to the tune of a dead battery when we get back to the
plane.
Is there a way to wire the ground of the LED through the start
switch so
that it will get power when the Master is on, but won't ground
until the
ignition switch is in the off position?
www.matronics.com/Navigator?RV10-List
Tim(at)MyRV10.com Guest
Posted: Wed Mar 15, 2006 7:20 am Post subject: master switch LED |
I have an avionics fan that I decided to leave on whenever the master
is on....so it's audible. It's saved me already. I also used
to use the rotating beacon being left on in my old plane too,
so that's a great idea.
Buhwana wrote:
Quote: |
What makes you think if you didn't see the master switch on you would
see the little LED? He's a suggestion form a lurker. Turn your strobe
light on and leave it on. when you turn the master switch on for
starting the light signal to everyone to "clear prop". When you leave
the airplane if you are blinded by the strobes, you left the master on.....
tom RV-6A 939GK
I am wanting to put an LED on the panel that Hill inform us when the Master
several times to the tune of a dead battery when we get back to the plane.
Is there a way to wire the ground of the LED through the start switch so
that it will get power when the Master is on, but won't ground until the
mstewart(at)iss.net Guest
Posted: Wed Mar 15, 2006 7:34 am Post subject: master switch LED |
You can use your alternator idiot light for the same purpose.
When the engine is stopped and the master is on, the alt light will tell
you the master is on. Has saved me more than once.
Works for me.
You can see the result here:
http://www2.mstewart.net:8080/super8/panel/index.htm
Enjoy
Mike
the Master
plane.
switch so
until the
sam.marlow
Posted: Wed Mar 15, 2006 8:30 am Post subject: master switch LED |
Hi Michael:
Just wondered, can you display an ILS on the Grand Rapids system. I don't see a separate ILS nav head? Or are you strictly VFR?
Stewart, Michael (ISS Atlanta) wrote:
Quote: | Quote: | --> RV10-List message posted by: "Stewart, Michael (ISS Atlanta)" <mstewart(at)iss.net> (mstewart(at)iss.net)
Works for me.
Enjoy
Mike
Quote: | I am wanting to put an LED on the panel that Hill inform us when
the Master
plane.
switch so
until the
Posted: Wed Mar 15, 2006 9:14 am Post subject: master switch LED |
Yep.
Both the GRT and BMA do.
Even better, can display ILS needles and synthetic HITS at the same time(overlayed) on the GRT, while the BMA is displaying HITS against ILS.
Its very valuable to see it all.
You can shake and bake it however you like and it works.
Mike
160 hrs RV-S8
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sam Marlow
Sent: Wednesday, March 15, 2006 11:27 AM
Subject: Re: master switch LED
Hi Michael:
Quote: | --> RV10-List message posted by: "Stewart, Michael (ISS Atlanta)" <mstewart(at)iss.net> You can use your alternator idiot light for the same purpose.When the engine is stopped and the master is on, the alt light will tellyou the master is on. Has saved me more than once. Works for me.You can see the result here:http://www2.mstewart.net:8080/super8/panel/index.htm Enjoy | 012 Quote: | 3456789 Quote: | You can use your alternator idiot light for the same purpose. | 0 Quote: | You can use your alternator idiot light for the same purpose. | 1 Quote: | You can use your alternator idiot light for the same purpose. | 2 Quote: | You can use your alternator idiot light for the same purpose. | 3 Quote: | You can use your alternator idiot light for the same purpose. | 4 Quote: | You can use your alternator idiot light for the same purpose. | 5You can use your alternator idiot light for the same purpose. | 6 Quote: | You can use your alternator idiot light for the same purpose. | 7 Quote: | You can use your alternator idiot light for the same purpose. | 8 Quote: | You can use your alternator idiot light for the same purpose. | 9 Quote: | When the engine is stopped and the master is on, the alt light will tell | 0 Quote: | When the engine is stopped and the master is on, the alt light will tell | 1 Quote: | When the engine is stopped and the master is on, the alt light will tell | 2 Quote: | When the engine is stopped and the master is on, the alt light will tell | 3 Quote: | When the engine is stopped and the master is on, the alt light will tell | 4 Quote: | When the engine is stopped and the master is on, the alt light will tell | 5 Quote: | When the engine is stopped and the master is on, the alt light will tell | 6 Quote: | When the engine is stopped and the master is on, the alt light will tell | 7 Quote: | When the engine is stopped and the master is on, the alt light will tell | 8 Quote: | When the engine is stopped and the master is on, the alt light will tell | 9 Quote: | you the master is on. Has saved me more than once. | 0 Quote: | you the master is on. Has saved me more than once. | 1 Quote: | you the master is on. Has saved me more than once. | 2 Quote: | you the master is on. Has saved me more than once. | 3 Quote: | you the master is on. Has saved me more than once. | 4 Quote: | you the master is on. Has saved me more than once. | 5 Quote: | you the master is on. Has saved me more than once. | 6 Quote: | you the master is on. Has saved me more than once. | 7 Quote: | you the master is on. Has saved me more than once. | 8 Quote: | you the master is on. Has saved me more than once. | 9012345
sam.marlow
Posted: Wed Mar 15, 2006 10:13 am Post subject: master switch LED |
Nice!
Quote: | v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> st1\:*{behavior:url(#default#ieooui) } <![endif]--> <![endif]--> <![endif]-->
Yep.
Mike
160 hrs RV-S8
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Sam Marlow
Hi Michael:
Quote: | --> RV10-List message posted by: "Stewart, Michael (ISS Atlanta)" <mstewart(at)iss.net> You can use your alternator idiot light for the same purpose.When the engine is stopped and the master is on, the alt light will tellyou the master is on. Has saved me more than once. Works for me.You can see the result here:http://www2.mstewart.net:8080/super8/panel/index.htm Enjoy | 0 1 2 Quote: | 3 4 5 6 7 8 9 Quote: | You can use your alternator idiot light for the same purpose. | 0 Quote: | You can use your alternator idiot light for the same purpose. | 1 Quote: | You can use your alternator idiot light for the same purpose. | 2 Quote: | You can use your alternator idiot light for the same purpose. | 3 Quote: | You can use your alternator idiot light for the same purpose. | 4 Quote: | You can use your alternator idiot light for the same purpose. | 5 You can use your alternator idiot light for the same purpose. | 6 Quote: | You can use your alternator idiot light for the same purpose. | 7 Quote: | You can use your alternator idiot light for the same purpose. | 8 Quote: | You can use your alternator idiot light for the same purpose. | 9 Quote: | When the engine is stopped and the master is on, the alt light will tell | 0 Quote: | When the engine is stopped and the master is on, the alt light will tell | 1 Quote: | When the engine is stopped and the master is on, the alt light will tell | 2 Quote: | When the engine is stopped and the master is on, the alt light will tell | 3 Quote: | When the engine is stopped and the master is on, the alt light will tell | 4 Quote: | When the engine is stopped and the master is on, the alt light will tell | 5 Quote: | When the engine is stopped and the master is on, the alt light will tell | 6 Quote: | When the engine is stopped and the master is on, the alt light will tell | 7 Quote: | When the engine is stopped and the master is on, the alt light will tell | 8 Quote: | When the engine is stopped and the master is on, the alt light will tell | 9 Quote: | you the master is on. Has saved me more than once. | 0 Quote: | you the master is on. Has saved me more than once. | 1 Quote: | you the master is on. Has saved me more than once. | 2 Quote: | you the master is on. Has saved me more than once. | 3 Quote: | you the master is on. Has saved me more than once. | 4 Quote: | you the master is on. Has saved me more than once. | 5 Quote: | you the master is on. Has saved me more than once. | 6 Quote: | you the master is on. Has saved me more than once. | 7 Quote: | you the master is on. Has saved me more than once. | 8 Quote: | you the master is on. Has saved me more than once. | 9 0 1 2 3 4 5
rvbuilder(at)sausen.net Guest
