Loose bolts
rv8a2001(at)yahoo.com
PostPosted: Tue Sep 16, 2008 4:17 am    Post subject: Loose bolts Reply with quote
I have found all sorts of loose bolts on the engine. First it was the exhaust bolts, I had to tighten them 3 times before they would "hold". Then the valve covers started leaking, nothing new, this is "normal". Well the screws were so loose I could remove some with my fingers, now they have been tightened and the leaks have stopped and have not come loose again since. The last couple bolts I found loose were to the case halves! From what I have read about others and their loose hardware experiences, the next upcoming annual just months away, ALL fasteners will be checked over the entire aircraft.
Scott
n223rv(at)wolflakeairport
PostPosted: Tue Sep 16, 2008 6:01 am    Post subject: Loose bolts Reply with quote
Where did you get your engine?
rocketbob(at)gmail.com
PostPosted: Tue Sep 16, 2008 7:09 am    Post subject: Loose bolts Reply with quote
One of the engineers I know from Lycoming has told me in the past that Lycoming case half bolts should be checked periodically for torque (100in/lbs) and that its not uncommon to find loose bolts. In other words check them at every condition inspection.
Bob Japundza
RV-6 flying F1 under const.
On Tue, Sep 16, 2008 at 8:15 AM, scott bilinski <rv8a2001(at)yahoo.com (rv8a2001(at)yahoo.com)> wrote:
[quote]--> RV-List message posted by: scott bilinski <rv8a2001(at)yahoo.com (rv8a2001(at)yahoo.com)>
Scott
PostPosted: Tue Sep 16, 2008 7:28 am    Post subject: Loose bolts Reply with quote
They were tight when the engine was new/refurbed. This was after several hundred hours flying.
 Scott
JSchans(at)lycoming.textr
PostPosted: Tue Sep 16, 2008 7:31 am    Post subject: Loose bolts Reply with quote
Here is the actual tightening procedure.
Jeff Schans
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bob J.
Sent: Tuesday, September 16, 2008 10:34 AM
To: rv-list(at)matronics.com
Subject: Re: Loose bolts
Bob Japundza
Scott
SI1029D_Tightening_Procedurs_for_crankcase.pdf
 Filename:  SI1029D_Tightening_Procedurs_for_crankcase.pdf
 Filesize:  439.12 KB
 Downloaded:  38444 Time(s)
acepilot(at)bloomer.net
PostPosted: Tue Sep 16, 2008 1:29 pm    Post subject: Loose bolts Reply with quote
I think the original poster stated that nuts WITH cotter pins had
loosened. How does this happen? Isn't that what cotter pins are
supposed to prevent? If not, they're just extra weight I can eliminate
on my -4 Smile
Scott
Scott
Scott
http://corbenflyer.tripod.com/
Flying Corben Junior Ace - Building RV-4
Gotta Fly or Gonna Die
Jess
PostPosted: Tue Sep 16, 2008 1:50 pm    Post subject: Loose bolts Reply with quote
If your cotter pinned bolts are loose, two things to check were they really torqued correctly the first time or did the Bolts STRECH. If they did, replace them.
In a message dated 9/16/2008 2:30:29 P.M. Pacific Daylight Time, acepilot(at)bloomer.net writes:
--> RV-List message posted by: Scott <acepilot(at)bloomer.net>
on my -4 Smile
Scott
--> RV-List message posted by: scott bilinski <rv8a2001(at)yahoo.com>
Scott
Scott
Gotta Fly or Gonna es y --> - MATRONICS WEB FORUMS nbsp; - List Contribution Web Site ;   =========================
Psssst...Have you heard the news? There's a new fashion blog, plus the latest fall trends and hair styles at StyleList.com.
Mark Phillips in TN
PostPosted: Tue Sep 16, 2008 6:23 pm    Post subject: Loose bolts Reply with quote
This is a phenomenon I have experienced on my RV-6A and also by other RV builders I know. It was actually brought to my attention by another builder. (Thanks, Charlie Bravo!) After some hours in operation, engine vibration & flight loads will tend to compress the stack of materials at the engine mount bolt locations on the firewall, resulting in a natural loosening of the nuts. Each annual condition inspection, this is an item I religiously check and address as necessary.
Mark Phillips - RV-6A "Mojo" 500 hours and warming up for the next C.I....
From The PossumWorks...
wnorth(at)sdccd.edu
PostPosted: Wed Sep 17, 2008 8:18 am    Post subject: Loose bolts Reply with quote
Yeah,
It is likely compression of both the metal stack and the tube that projects
out which is the weld point for the rest of the mount.
What is frustrating is the four stayed tight for 1000 hours and then got
loose in the last 200.
On the case half discussion, all cases flex a microscopic amount as the
cylinder is projected away from the piston. Ya, you should check those
fasteners every chance you get.
On the Titan ECI AD, piss, I got 'em, fortunately am very low in the A group
and now need to do a comp check every 50 instead of 100 hours. And they did
a "hartzel" bait and switch by making them throwaway units after the fact.
Not that I disagree with this, running cylinders beyond the original TBO
comes at some increased risk. Given the low cost differential between
overhauled and new it is hard to justify reusing them over peace of mind.
But still it rankles one's sensibilities.
ghinman(at)mts.net
PostPosted: Thu Sep 18, 2008 5:38 am    Post subject: Loose bolts Reply with quote
<http://www.aircraftspruce.com/catalog/hapages/ms27151palnuts.php>
I noticed one guy had -MS27151 PAL NUTS - ON TOP of the regular
nuts on his crank case bolts.
I do not know if this works,but may be worth a try for those who
have had loose engine bolts.
George H. Inman
ghinman(at)mts.net
