CHP Stick Grips... company change
hotwheels
PostPosted: Mon Sep 15, 2008 9:33 am    Post subject: CHP Stick Grips... company change Reply with quote
Just fyi.
CH Stick Grips are no longer being made or supported by CH Products... Kevin Williamson (the original developer) bought out the molds and inventory from CHP after a change of ownership.
I have the CS-8 Aircraft Grip and they are -nice-.
Here's the new website and contact info:
Tosten Manufacturing
San Marcos, CA 92069
760-803-6034
http://www.tostenmanufacturing.com
Jay
jchang10
PostPosted: Sat Apr 03, 2010 7:33 am    Post subject: Re: CHP Stick Grips... company change Reply with quote
It seems like quite a few people have the Tosten grips in their -10's.
Can anyone flying with one of these grips, address whether the forward sweep on the grip is an issue as far as panel interference goes?
With that forward sweep, clearly, you get less forward distance until hitting the panel. I'm just not sure if that is a practical concern at all when everything is finally rigged and tested.
Thanks!
Jae
MauleDriver(at)nc.rr.com
PostPosted: Sat Apr 03, 2010 9:39 am    Post subject: CHP Stick Grips... company change Reply with quote
I've trial fitted it and found that the stick has to be modified in some
way to clear the panel. I bent mine in a press. Others have re-welded it.
I'm not sure if any of the stick tops or any of the alternate panel
setups end up without requiring some mod of the stick.
Bill "pants off the ground" Watson
Thanks!
Jae
http://forums.matronics.com/viewtopic.php?p=292867#292867
partner14
PostPosted: Sat Apr 03, 2010 1:59 pm    Post subject: CHP Stick Grips... company change Reply with quote
Jae, if you zoom in on the pic attached, you will see what I did to make them clear the panel... they go right under and clear by at least .050".....Not that I will ever need to push the stick that far forward. I might have slightly modified the connection on the bottom... just can't remember. But they work fine, no issues.
Don McDonald
--- On Sat, 4/3/10, jchang10 <jc-matronics_rv10(at)jline.com> wrote:
Subject: Re: CHP Stick Grips... company change
Date: Saturday, April 3, 2010, 8:33 AM
--> RV10-List message posted by: "jchang10" <jc-matronics_rv10(at)jline.com (jc-matronics_rv10(at)jline.com)>
Thanks!
Jae
http://forums.matronics.com/viewtopic.php?p=292867#29286om/Navigator?RV10-List" target=_blank>http://www.matronics.com/Navigator? - MATRONICS WEB FORUM; -Matt Dralle, List Admin==========
 Filesize:  155.02 KB
 Viewed:  8580 Time(s)
Don A. McDonald
40636
ricksked(at)cox.net
PostPosted: Sat Apr 03, 2010 6:27 pm    Post subject: CHP Stick Grips... company change Reply with quote
Jae,
I have the CH, now Tosten grips. They work fine and mine just brush the
switches and CB's on the panel at full forward. I cut the sticks a low as
they would go to install the grips. FWIW, nothing against them but on my
next aircraft I'm using the Infinity grips and modify the stick to allow
them to not hit the panel. Reason? They just feel nicer to me and the
switches have a more tactile feel and are less apt to be inadvertently
actuated, my 2 cents as always,
Rick Sked
N246RS coming close to the magical 100 hours
jchang10
PostPosted: Sun Apr 04, 2010 9:43 am    Post subject: CHP Stick Grips... company change Reply with quote
Rick... thanks. this is the first I have heard of a preference for the
Infinity grips for this reason. Also, it does look like the Infinity
grips have a similar amount of forward sweep on them as to the Tostens.
Thanks for all the other responses. Initially, I wanted to avoid all
this trouble by going with the Ray Allen grips, which seeemed nice and
simple enough for me. However, i just did not like stand the individual
trim buttons instead of a hat switch. I emailed Ray Allen about
switching out for a hat switch, but they replied negative on that
request. Always somethin...
I did find Robin's old post about how he increased the bend angle in the
stick here. It does seem simple enough.
http://forums.matronics.com/viewtopic.php?t=59431&highlight=infinity+control+stick+robin
Now to investigate Rick's issue. Wink
Jae
Rick wrote:
Jae,
Rick Sked
#40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011
PostPosted: Sun Apr 04, 2010 11:25 am    Post subject: CHP Stick Grips... company change Reply with quote
It appears that the Tostens can be setup so they can rotate freely while
in operation. For example, rotating enough so that it can be fully
gripped with the left or right hand. Can anyone comment?
I've handled both grips but haven't flown with either. I preferred the
Tostens due to fewer switches and a more pleasing fit and feel. But
again, I haven't flown either of them.
Bill "working on pants for his third leg" Watson
individual trim buttons instead of a hat switch. I emailed Ray Allen
about switching out for a hat switch, but they replied negative on
that request. Always somethin...
the stick here. It does seem simple enough.
Jae
Rick wrote:
> Jae,
> low as
> Rick Sked
speckter(at)comcast.net
PostPosted: Sun Apr 04, 2010 4:04 pm    Post subject: CHP Stick Grips... company change Reply with quote
Bill, I have them and love them. I have them rotate and fits my hand
perfectly. I did have to reform the stick to prevent them hitting the
panel, but I have a Stein panel so don't know if they would hit the regular
one. I too did not need or want all those extra switches.
Gary Specketer
PostPosted: Sun Apr 04, 2010 4:41 pm    Post subject: CHP Stick Grips... company change Reply with quote
Hey Gary, glad to hear they can rotate. That seems like a neat
feature. I have a Stein panel blank too and I had to do the bending of
the stick to get it to clear but it seems to work in my pre-flight cockpit.
I'm getting close....
Bill "the '10 flies in '10 Watson
Gary Specketer
