Bonanza with IO-520BB idles rough
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Beech-List
martymitchell
PostPosted: Sun Sep 14, 2008 9:16 am    Post subject: Bonanza with IO-520BB idles rough Reply with quote
I have an IO-520BB in my Beech Bonanza that runs rough at idle and low RPM. I have changed the spark plugs, cleaned the injectors, checked the mag timing (just installed after 500 hour inspection and new distributor block), and had a mechanic check the idle fuel pump pressure and idle mixture setting.
I also did a compression check and all cylinders are above 60/80. There doesn't seem to be any difference in drop with each mag at various RPM's. I have not changed the ignition wires.
Any ideas on other things to look for?
Thanks!
- The Matronics Beech-List Email Forum -
http://www.matronics.com/Navigator?Beech-List
Marty Mitchell
Bonanza N44GN
idewhirst(at)indtechnolog
PostPosted: Mon Sep 15, 2008 3:13 am    Post subject: Bonanza with IO-520BB idles rough Reply with quote
I would look for an intake leak.
martymitchell
PostPosted: Mon Sep 15, 2008 7:06 am    Post subject: Re: Bonanza with IO-520BB idles rough Reply with quote
I have verified that all the hose clamps are tight and that all the intake bolts are secure, but not sure where else to look and how to determine if it's leaking.
Thanks.
Marty Mitchell
Bonanza N44GN
Heavy707(at)comcast.net
PostPosted: Mon Sep 15, 2008 7:44 am    Post subject: Bonanza with IO-520BB idles rough Reply with quote
What is the largest difference between cylinder compression? You say all are at least 60/80 but how far apart are they and are they very different from the last time they were taken? When is the last time the prop governor was checked?
Did it start being rough just after coming out of the shop for repairs? Could it be cam related? Bad lobe on cam?
Best of luck.
martymitchell
PostPosted: Mon Sep 15, 2008 8:02 am    Post subject: Re: Bonanza with IO-520BB idles rough Reply with quote
Both mags were inspected, a new distributor block was installed on one due to a corroded terminal, and returned to the plane. I only did a brief compression check to see if anything really bad happened to a cylinder, but will have to go back and do it more carefully to get the exact numbers and will compare with existing numbers.
Seems like the trouble began after the mags were pulled out and returned.
I suppose it could be a bad cam lobe. The engine is 1500 hours TSO.
The prop governor has not been checked for 1500 hours as far as I know.
I'm planning to check the ignition wires today.
Marty Mitchell
Bonanza N44GN
martymitchell
PostPosted: Mon Sep 15, 2008 9:51 pm    Post subject: Re: Bonanza with IO-520BB idles rough Reply with quote
Problem Found! I did a second compression check and took my time. Although all of the compressions are in the low to mid 60's, it appears that each cylinder has a valve leak, one exhaust and 5 intakes. I suppse that is why it idles so rough.
Thank you all for your help and suggestions. I should have started off with a careful compression check.
Marty Mitchell
Bonanza N44GN
BobsV35B(at)aol.com
PostPosted: Tue Sep 16, 2008 5:36 am    Post subject: Bonanza with IO-520BB idles rough Reply with quote
Good Morning Marty,
I am getting in on this thread very late, but didn't I see that your roughness came on suddenly following a repair to an ignition component?
I would not feel that your cylinder compressions would have caused a sudden change in operation.
Have you looked at the cylinders with a borescope?
Continental now tells us that the older compression check done alone is not valid. You really need to take a good look at the valve face. That will tell you if the valve is leaking under operating conditions. Many valves that show leakage via a static compression check will seal just fine under normal operations. I would look further for your problem.
I think there may be a newer version of the Continental Motors Service Bulletin concerning cylinder testing, but the one I have before me right now is dated 2003. It is SB03-3. Be sure you have that one or a newer version before you start tearing things apart!
Happy Skies,
Old Bob
In a message dated 9/16/2008 12:52:44 A.M. Central Daylight Time, orders(at)martymitchell.com writes:
--> Beech-List message posted by: "martymitchell" <orders(at)martymitchell.com>
Marty Mitchell
Bonanza N44GN
Psssst...Have you heard the news? There's a new fashion blog, plus the latest fall trends and hair styles at StyleList.com.
martymitchell
PostPosted: Tue Sep 16, 2008 7:03 am    Post subject: Re: Bonanza with IO-520BB idles rough Reply with quote
Thanks Old Bob. Good advice. I am aware of Service Bulletin SB03-3 and have read it. Turns out that I mistakenly reported my problem as being 5 intake leaks, when in fact, air was leaking thru the crankcase breather, so they are actually ring leaks.
So I have 1 exhaust valve leak and 5 that are leaking past the rings.
I'm not sure that explains idle roughness. I'm just about ready to pull the mags and have them re-checked for proper internal timing but the mag shop says it not my problem.
Still very confused....
Marty Mitchell
Bonanza N44GN
thender(at)adelphia.net
PostPosted: Tue Sep 16, 2008 8:07 pm    Post subject: Bonanza with IO-520BB idles rough Reply with quote
This sounds dumb.. but have you verified that all the plug wires are going
to the right places, and that they aren't damaged, etc?
-TH
martymitchell
PostPosted: Tue Sep 16, 2008 8:14 pm    Post subject: Re: Bonanza with IO-520BB idles rough Reply with quote
I did test all the ignition wire with one of those ignition wire testers. I believe it only checks for shorts to ground but does not check for opens. I'm sure all the wires are in the right place or it would run REAL bad.
There are a couple damaged spots but just to the outer vinyl, no further.
Any other ideas?
Marty
Marty Mitchell
Bonanza N44GN
hal_kempthorne(at)sbcglob
PostPosted: Wed Sep 17, 2008 9:33 am    Post subject: Bonanza with IO-520BB idles rough Reply with quote
An intake air leak will be a factor at low speeds and less so at higher speeds.
hal
(Finally rid of the Debonair - but I loved her for all her faults)
Now flying an RV6-a (Lycoming)
pankajnagarkoti86
PostPosted: Mon Oct 12, 2009 2:10 pm    Post subject: Re: Bonanza with IO-520BB idles rough Reply with quote
no,Any ideas|
......because i do not knowledge for that.
Best hosting | Website worth calculater
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Beech-List All times are GMT - 8 Hours
