jesse(at)itecusa.org Guest
Posted: Tue Mar 14, 2006 3:55 pm Post subject: Master LED |
I am wanting to put an LED on the panel that Hill inform us when the Master switch is on and the plane is off. We have left the Master switch on several times to the tune of a dead battery when we get back to the plane. Is there a way to wire the ground of the LED through the start switch so that it will get power when the Master is on, but won’t ground until the ignition switch is in the off position?
Thanks and do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
I'm in Ecuador right now and should be back in the country by the end of May. You may call me at 352-505-1899 and leave a message that I can check from down here. Any I-TEC questions can be directed to the I-TEC office at 352-465-4545.
Rick S.
Posted: Tue Mar 14, 2006 10:08 pm Post subject: Master LED |
Jesse,
You should be able to activate the LED via a relay that is powered off the Master and grounded by the starter. I'm filling in on graveyard shift and my brain may not be working correctly but that's my thought.
Rick S.
40185
Fuse/finish
_________________ Rick S.
RV-10
40185 |
