Guy Buchanan
Posted: Thu Sep 11, 2008 8:46 pm Post subject: [!! SPAM] RE: Kitfox-List Digest: 25 Msgs - 09/10/08 |
At 10:49 AM 9/11/2008, you wrote:
| Quote: | Sonny Logan who built No. 36 two decades ago tells me no
trim needed, just use flaperons. I'm thinking a simple bungee pulling elev.
Tube either way with a small rope and a sailboat clam cleat is the simplest.
Any input appreciated.
I like my manual trim. It's easy and it works. Lowell's done
testing and found the elevator trim tab to offer much less drag than
trimming with the flaperons. I like it because it has a lot more
range than the flaperons and works when you use the flaperons as
flaps. (Obviously if you use the flaperons as flaps, you can't use
them for trim.)
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
