dan(at)familybrown.org Guest
Posted: Wed Sep 10, 2008 3:27 pm Post subject: FOR SALE - PRICE REDUCED: Isham RV Tool Kit with upgrades |
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Price on this set is reduced to $2200 OBO plus shipping, now including
the Sioux 1/4" air drill with keyless chuck. Please reply off list if
interested.
Dan Brown wrote:
For a variety of reasons, mostly relating to my being called to active
duty with the Army, I won't be able to complete my planned RV-7A.
Consequently, I'll need to sell my tools. This is the complete Isham
kit pictured at:
http://www.store-planetools.com/index.asp?PageAction=VIEWPROD&ProdID=9
This kit includes a pneumatic rivet squeezer and the popular DRDT-2
dimpling tool.
In addition, the following extras are included:
Screw-adjustable Rivet Squeezer Ram (a $70 value)
Avery Longeron Yoke (a $150 value)
Avery Thin-nose (no-hole) Yoke (a $140 value)
Avery back-rivet plate (a $50 value)
Avery flush swivel rivet set (a $40 value)
A couple of additional countersink cutters
Additional side-grip clecos (about 10 extra of each, IIRC)
That's $450 in upgrades, in addition to the Isham set. All tools are in
excellent condition. The air drill is NOT, repeat NOT included;
everything else is.
This would cost nearly $3000 for these tools ordered new. I'll take
$2500 OBO, plus shipping. If you're local to Fayetteville, NC, you can
pick up. Contact me by e-mail at dan(at)familybrown.org if interested.
Thanks for your interest!
The following tools are included:
DRDT-2 Dimpler* (email for delivery date on DRDT-2)
Pneumatic Rivet Squeezer (U.S.A.)*
3” C-Yoke Installed on Squeezer (U.S.A.)*
Adjustable Set Holder for Pneumatic Squeezer (U.S.A.)*
3X Rivet Gun with excellent teasing trigger*
EZ change spring for straight rivet sets*
EZ Change Spring for flush sets (Snap-On Ind U.S.A.)*
Swivel and Air Flow Restrictor with fine precision adjustment*
1” Diameter Flush Rivet Set (Snap-On U.S.A.)*
3/32” Cupped Rivet Set 3.5” (Snap-On U.S.A.)*
1/8” Cupped Rivet Set 3.5” (Snap-On U.S.A.)*
3/16” Cupped Rivet Set 3.5” (Snap-On U.S.A.)*
1/8” Double Offset Rivet Set (Snap-On U.S.A.)*
Back Rivet Set* (Special Small 1/2" Diameter for RV's)
Mini-Bucking Bar, 1 lb. (Snap-On U.S.A.)*
Bulkhead Bucking Bar (Snap-On U.S.A.)*
Footed Bucking Bar (Snap-On U.S.A.)*
Microstop Countersink Unit, needle-bearing, non-chattering (U.S.A.)*
#40 Countersink Bit, 3/32” (Snap-On U.S.A.)*
#30 Countersink Bit, for 1/8” & #6 Screw (Snap-On U.S.A.)*
#8 Countersink Bit, #8 Screw (Snap-On U.S.A.)*
#10 Countersink Bit, #10 Screw (Snap-On U.S.A.)*
Left Cut Snips, easy to use offset type (Klein Tools U.S.A.)*
Right Cut Snips, easy to use offset type (Klein Tools U.S.A.)*
Straight Cut Snips, easy to use offset type (Klein Tools U.S.A.)*
#40 Aviation Cobalt Drill Bits for 3/32” rivets, 8 each
#30 Aviation Cobalt Drill Bits for 1/8” rivets, 6 each
#27 Aviation Cobalt Drill Bit
#21 Aviation Cobalt Drill Bit
#19 Aviation Cobalt Drill Bit
#12 Aviation Cobalt Drill Bit
1/4" Aviation Cobalt Drill Bit
12” Aviation Extra Long #40 Drill Bit
12” Aviation Extra Long #30 Drill Bit
Deburr Tool, Speed Handle Type for small & large holes (U.S.A.)*
Cleco Pliers*
4 Cleco Clamps, 1/2" (Calif Assoc Prod or Zephyr U.S.A.)*
4 Cleco Clamps, 1” (Calif Assoc Prod or Zephyr U.S.A.)*
Pop Rivet Tool, Professional Heavy-Duty unit with Swivel Head*
3/32" Universal Cupped Squeezer Set (Snap-On U.S.A.)*
1/8” Universal Cupped Squeezer Set (Snap-On U.S.A.)*
5/32" Universal Cupped Squeezer Set (Snap-On U.S.A.)*
3/16” Universal Cupped Squeezer Set (Snap-On U.S.A.)*
Flat Squeezer Set 1/8” (Snap-On U.S.A.)*
Flat Squeezer Set 1/4" (Snap-On U.S.A.)*
Flat Squeezer Set 3/8” (Snap-On U.S.A.)*
Flat Squeezer Set 1/2" (Snap-On U.S.A.)*
3/32” Rivet Dimple Die (Springback U.S.A.)*
1/8” Rivet Dimple Die (Springback U.S.A.)*
5/32" Dimple Die*
3/16" - #10 Screw Dimple Die*
#8 Screw Dimple Die*
#6 Screw Dimple Die*
Squeezer Set Organizer*
Squeezer Set Adjustment Washers *
Stainless Steel Rule, 12”*
Unibit 1/4" - 3/4" by 1/16ths, (Klein U.S.A.)*
3 Permanent Markers, Sharpie
1/2 x 1 Reducers for 3M Wheel*
325 Cleco Fasteners, 3/32” (Calif Assoc Prod or Zephyr U.S.A.)*
175 Cleco Fasteners, 1/8” (Calif Assoc Prod or Zephyr U.S.A.)*
10 Cleco Fasteners, 5/32" (Calif Assoc Prod or Zephyr U.S.A.)*
10 Cleco Fasteners, 3/16” (Calif Assoc Prod or Zephyr U.S.A.)*
Edge Deburring Tool, Hex Swivel type*
Fluting Pliers, Smooth Flute Nylon Jaws*
Fluting Pliers, Deep “V” Nylon Jaws*
Rivet Cutter*
Air Tool Oil
Drill Stop Set of 4 with Allen Wrench*
Rivet Set DOTS, Easier than Rivet Tape
3/32” Pop Rivet Dimple Die, Springback (U.S.A.)*
1/8” Pop Rivet Dimple Die, Springback (U.S.A.)*
Hand Seamer (Klein Tools U.S.A.)*
3/32” Drive Pin Punch (Klein Tools U.S.A.)*
1/8” Drive Pin Punch (Klein Tools U.S.A.)*
Scotch Brite Hand Pads, 4 each
Rivet Length Gauge*
Rivet Shop Head Gauge, 4-piece*
Dan Brown, KE6MKS, dan(at)familybrown.org
"Since all the world is but a story, it were well for thee to buy the
more enduring story rather than the story that is less enduring."
-- The Judgment of St. Colum Cille
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.1 (MingW32)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFIyFctyQGUivXxtkERAp4TAKCIURWWxSCdzkPhXv8bVtTYvNrbSQCdEkNc
3RPVti0x0O3Cne/DzKFYcNU=
=Xmss
-----END PGP SIGNATURE-----
rlundin46(at)yahoo.com Guest
Posted: Thu Sep 11, 2008 3:59 pm Post subject: FOR SALE - PRICE REDUCED: Isham RV Tool Kit with upgrades |
I don't need the tool kit but good luck to you in the Army and thank you for your service.
Best regards,
Rick Lundin
--- On Wed, 9/10/08, Dan Brown <dan(at)familybrown.org> wrote:
| Quote: | From: Dan Brown <dan(at)familybrown.org>
Subject: FOR SALE - PRICE REDUCED: Isham RV Tool Kit with upgrades
To: rv-list(at)matronics.com
Date: Wednesday, September 10, 2008, 7:24 PM
Hash: SHA1
now including
reply off list if
interested.
called to active
planned RV-7A.
the complete Isham
> kit pictured at:
popular DRDT-2
> dimpling tool.
IIRC)
included;
> everything else is.
new. I'll take
if interested.
adjustment*
RV's)
(Snap-On U.S.A.)*
U.S.A.)*
U.S.A.)*
Tools U.S.A.)*
each
each
holes (U.S.A.)*
> Cleco Pliers*
U.S.A.)*
U.S.A.)*
Swivel Head*
U.S.A.)*
U.S.A.)*
U.S.A.)*
> 5/32" Dimple Die*
U.S.A.)*
Zephyr U.S.A.)*
Zephyr U.S.A.)*
Zephyr U.S.A.)*
Zephyr U.S.A.)*
> Rivet Cutter*
> Air Tool Oil
> Rivet Length Gauge*
thee to buy the
enduring."
=Xmss
