elt locations
rv10(at)sinkrate.com
PostPosted: Tue Sep 09, 2008 7:22 pm    Post subject: elt locations Reply with quote
I’m considering mounting the ELT antenna inside the airplane on the longeron behind the passenger side rear window. For people that have done this where are you mounting the ELT itself? Pictures would be nice.
THX
-Ben
ricksked(at)embarqmail.co
PostPosted: Tue Sep 09, 2008 7:46 pm    Post subject: elt locations Reply with quote
Mine is on the floor of the tailcone right of the bellcrank assembly in the tailcone...used some angle stock atached to the J-stringers and made a floor for the bracket to be attached too...pretty basic..There is an advantage to making it accessible in the event of an unlikely water landing as you suggest behind the passenger...you could actually remove it, install the external antenna and plug your headset into it easily if needed.
Rick S.
40185
partner14
PostPosted: Tue Sep 09, 2008 8:04 pm    Post subject: elt locations Reply with quote
I hope the pics are self explainatory.  Any questions, just email.
Don McDonald
#40636
--- On Tue, 9/9/08, Ben Westfall <rv10(at)sinkrate.com> wrote:
Subject: elt locations
Date: Tuesday, September 9, 2008, 8:21 PM
I˘m considering mounting the ELT antenna inside the airplane on the longeron behind the passenger side rear window. For people that have done this where are you mounting the ELT itself?  Pictures would be nice.
THX
-Ben
get=_blank rel=nofollow>http://www.matronics.com/Navigator?RV10-List
=nofollow>http://forums.matronics.com
blank rel=nofollow>http://www.matronics.com/contribution
 Filesize:  73.49 KB
 Viewed:  230 Time(s)
 Filesize:  100.61 KB
 Viewed:  239 Time(s)
Don A. McDonald
40636
AirMike
PostPosted: Wed Sep 10, 2008 1:50 am    Post subject: elt locations Reply with quote
I was told that antennas like these cannot "see" thru carbon fiber. Is any part of the cabin top made with carbon fiber?
Also I think that Rob Hickman from Advanced Flight Systems also has his mounted in the baggage area.
See you OSH '18
Q/B - sold.
wayne.e(at)grandecom.net
PostPosted: Wed Sep 10, 2008 2:58 am    Post subject: elt locations Reply with quote
I mounted my ELT antenna just inside the baggage compartment immediately on the left almost against the fuselage. It's out of the way and in case I ever need it hopefully I will be able to get at it. I thought about putting it behind the bulkhead, which I think many have done, but as I said I wanted to be able to get at it.
Also I have an overhead console and I have the ELT antenna mounted horizontally up in the console. I've also seen some mount the antenna horizontally in the tail section area and you can access it if the rear fairing is off.
I've attached a couple of photos of where I mounted it. I've done quite a bit of traveling, using the baggage compartment, and it's nit proved to be any problem.
Wayne Edgerton N602WT
 Filesize:  149.23 KB
 Viewed:  221 Time(s)
 Filesize:  171.35 KB
 Viewed:  233 Time(s)
