elevators
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List
Vince Frazier
PostPosted: Tue Sep 09, 2008 5:13 am    Post subject: elevators Reply with quote
SNIP***** I've heard it adds 2 knots in comparision to the RV-4 elevator
counterweighted
tips.
Jim Ayers ******SNIP
I'm dying to know who swapped elevators and made these tests on the same
day, under the same conditions, and is a good enough pilot to measure 2
knots accurately. I am skeptical that either tip would offer any real
speed, although the RV-4 tips should be lighter due to longer arm... but
even that isn't much.
If it's speed you're after, maybe that old RV-4 tail IS the way to go.
It's got a shorter VS that, in theory, should be less drag.
Vince - RV-4 tail, and like it.
- The Matronics Rocket-List Email Forum -
http://www.matronics.com/Navigator?Rocket-List
Vince Frazier
3965 Caborn Road
Mount Vernon, IN 47620
812-464-1839 work
812-985-7309 home
F-1H Rocket, N540VF
http://vincesrocket.com/
Im7shannon(at)aol.com
PostPosted: Tue Sep 09, 2008 8:06 am    Post subject: elevators Reply with quote
I think the diffrence is in the trailing edge construction, a sharp point VS the rounded over blunt end of bent sheet metal. That is what made the RV 9 faster than they expected. Think of the difference if all the control surfaces were done that way. Makes sense to me.
Kevin Shannon
counterweighted
tips.
Psssst...Have you heard the news? There's a new fashion blog, plus the latest fall trends and hair styles at StyleList.com.
kahuna
PostPosted: Tue Sep 09, 2008 9:03 am    Post subject: elevators Reply with quote
"Think of the difference if all the control surfaces were done that way."
Nooooo.
There is a reason they are NOT all done that way.
The speed does not come for free. You get a significant increase in control input required to deflect at higher speed.
Mike
[img]cid:1__=0ABBFE2CDFCEB4528f9e8a93df938(at)us.ibm.com[/img]Im7shannon---09/09/2008 12:14:16 PM---I think the diffrence is in the trailing edge construction, a sharp point VS the rounded over blunt end of bent sheet metal. Th
[img]cid:3__=0ABBFE2CDFCEB4528f9e8a93df938(at)us.ibm.com[/img]
To
rocket-list(at)matronics.com [img]cid:3__=0ABBFE2CDFCEB4528f9e8a93df938(at)us.ibm.com[/img]
cc
Subject
Re: elevators [img]cid:3__=0ABBFE2CDFCEB4528f9e8a93df938(at)us.ibm.com[/img][img]cid:3__=0ABBFE2CDFCEB4528f9e8a93df938(at)us.ibm.com[/img]
Kevin Shannon
counterweighted
tips.
?Rocket-List">[b]http://www.matronics.com/Navigator?Rocket-List
u>http://forums.matronics.com[/u]
ion">[b]http://www.matronics.com/contribution
 Filesize:  105 Bytes
 Viewed:  3845 Time(s)
 Filesize:  1.23 KB
 Viewed:  3844 Time(s)
 Filesize:  45 Bytes
 Viewed:  3843 Time(s)
lesdrag(at)aol.com
PostPosted: Tue Sep 09, 2008 8:03 pm    Post subject: elevators Reply with quote
I didn't do the testing for that data. However, using density altitude and a consistent test procedure works pretty good.
Jim Ayers
lesdrag(at)aol.com
The same round trailing edge was used on both sets of elevators.
Jim Ayers
PostPosted: Wed Sep 10, 2008 3:42 am    Post subject: elevators Reply with quote
In a message dated 9/9/2008 9:03:59 PM Pacific Daylight Time, lesdrag(at)aol.com writes:
Jim Ayers
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List All times are GMT - 8 Hours
