grantr
Posted: Mon Sep 08, 2008 7:53 am Post subject: fuel line? |
II want to replace my fuel lines. What is the best line to replace it with.
My instructor said he used vinyl line back in the 90s on a phantom and that same fuel line is still good. Its hard but will not break.
Tygon and the blue fuel lines are nothing like this.
Does anyone use vinyl fuel line?
| - The Matronics Kolb-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
JetPilot
Posted: Mon Sep 08, 2008 9:12 am Post subject: Re: fuel line? |
The tygon and clear vinyl type fuel lines are substandard and cheap, I would not use those on any plane. They can be very easily cut, punctured, and go bad over time. You never see this type of fuel line in real airplanes, not even in boats, cars, and motorcycles...
You do have a couple good options, I use the Aeroquip aircraft fuel hose from Aircraft Spruce, it is expensive but very good, tough and durable. I don't think I will ever have to replace it. I also put the fire sleeve over it so that an engine fire wont melt through the fuel line and quickly become out of control. The other good option is the black fuel line used for boats. It is also very tough and wont go bad over time, you can get it at any marine store.
Mike
Kolb MK-III Xtra, 912-S |
Posted: Mon Sep 08, 2008 11:03 am Post subject: fuel line? |
with.
Grant R:
What is wrong with black neoprene automotive fuel line?
I have been using Gates neoprene fuel line for many years and many hours.
Why would I use that instead of the "normal" ultralight fuel line? Because
vinyl, tygon, polyurethane, and all the rest of those neat lines that you
can see the gas in are prone to failure, especially the pulse lines on two
stroke engine driven fuel pumps.
Some will tell you you must be able to see inside the line so you can see if
there is bubbles in there. If you must see if there are air bubbles in the
line, better not use neoprene. For reliability and longevity, I'll stick to
black neoprene fuel line.
_________________ John Hauck
Titus, Alabama |
Posted: Mon Sep 08, 2008 11:46 am Post subject: fuel line? |
Thom Riddle researched this and will have an answer when he returns
from vacation.
There is a qualified tygon variant available.
BB
On 8, Sep 2008, at 11:53 AM, grantr wrote:
Quote: |
<grant_richardson25(at)yahoo.com>
it with.
http://forums.matronics.com/viewtopic.php?p 3203#203203
Dana
Posted: Mon Sep 08, 2008 1:52 pm Post subject: fuel line? |
At 11:53 AM 9/8/2008, grantr wrote:
Quote: | II want to replace my fuel lines. What is the best line to replace it with.
I use the transparent blue polyurethane line sold by ACS and other aircraft
suppliers. I know it's not as durable as black neoprene but I like to see
if there's any air bubbles or other contamination. Tygon IS vinyl. Their
yellow vinyl (specifically sold as "fuel and lubricant tubing") is OK but I
feel it's too soft, hose clamps can cut into it... and it still hardens so
you need to replace it every year, especially if there's any ethanol in
your fuel. I tried some generic yellow "fuel tubing", supposedly the same
thing as the yellow Tygon, and it hardened up even sooner; I won't buy it
again. I would not use generic clear vinyl tubing, it's not made for fuel
and oil.
-Dana
Suicidal twin kills sister by mistake!
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Mon Sep 08, 2008 4:57 pm Post subject: Re: fuel line? |
I think at least one LSA manufacturer is using Nylaflow tubing for fuel line. At least that is what it looks like. It might be worth looking into. fairly inexpensive, easy to work with, and I would think very durable.
See it here http://www.aircraftspruce.com/catalog/appages/nylaflow.php
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Posted: Mon Sep 08, 2008 5:05 pm Post subject: fuel line? |
a follow up for the impatient:the manufacturer is Saint-Gobain. Some of their products are available through McMaster-Carr
Their fuel rated tubing is F-4040 but their test is stated as using ethanol free gas.
They also make an ultra chemical resistant tubing F-2075
http://tinyurl.com/ny6gt
BB
On 8, Sep 2008, at 3:45 PM, robert bean wrote:
[quote] [quote][b]
JetPilot
Posted: Mon Sep 08, 2008 5:15 pm Post subject: Re: fuel line? |
Dana wrote: |
John H said it very well that there is no reason you need clear fuel line. When was the last time you saw a Cessna, or any other type of aircraft or car with clear line so that you could " See " bubbles ? If you do not do something stupid in your fuel system design, like try to PULL fuel up with a fuel pump, bubbles will never be an issue. In a properly designed fuel system, a leak would be indicated be a drip or a wet spot, not by bubbles and sudden engine stoppage... Contamination, you are not likely to see it in the line... That is what fuel sumps and filters are for. You are fooling yourself if you think that you are safe from contamination, or that you will catch it because of clear fuel line.
Now you are willing to use fuel line that goes bad over time, is very prone to damage and even out of control leaks with even a little heat or mechanical abuse on the misguided belief that you need to be able to see the fuel in the line. Thank god almost every manufacturer of vehicles in the world does not buy into this foolishness, or we would have cars burning on the side of the road, and airplanes coming down in fireballs every day. That clear fuel line is cheap, and it is a hazard.
Mike
robcannon
Joined: 22 Jun 2008 Posts: 39 Location: British Columbia
Posted: Mon Sep 08, 2008 5:31 pm Post subject: Re: fuel line? |
I recently was faced with the same question about fuel line, and asked a friend who is a meticulous marine mechanic. He built a Beaver RX 550 over ten years ago and used clear yellow Tygon brand fuel line and is still using the original fuel line. I inspected this 12 ish year old line and it was still soft and supple, and in good shape. (His was encased in black split loom)(uv protected)
Another chainsaw mechanic I spoke with said he has used it for years as the pickup line into the gas tank with no visible breakdown or hardening. It can be cut easily, and therefore needs to be installed correctly, but I still believe it to be a good choice for ultralight fuel line, as it is proven to not break down for a long time.
It is possible that there are different brands of Tygon, but the kind I bought says "Tygon" on the box.
Rob Cannon
Dana
Posted: Mon Sep 08, 2008 5:36 pm Post subject: fuel line? |
At 09:15 PM 9/8/2008, JetPilot wrote:
Quote: | ...If you do not do something stupid in your fuel system design, like try
wet spot, not by bubbles...
Well, in the original UltraStar design, the tanks are below the engine...
and too far away to mount a pulse pump to push the fuel, so pulling it is
the only option. If a leak develops anywhere, it's going to show up as
bubbles... and I want to see them during my preflight runup. With every
inch of the fuel system visible during preflight inspection, it's easy to
verify that the lines are intact... and no trouble to replace them every
year or so.
-Dana
A pilot is a confused soul who talks about women when he's flying, and
about flying when he's with a woman.
1planeguy(at)kilocharlie. Guest
Posted: Mon Sep 08, 2008 6:16 pm Post subject: fuel line? |
For what it is worth...RANS recently released a Service Bulletin saying
to get rid of all the blue and clear poly-stuff fuel line and go to the
automotive stuff. The poly-stuff has been found to not like ethanol
(there it is again ;-( ) Supposedly there is some more expensive
poly-stuff lines that are ethanol OK but why bother? The SAE 30R7 stuff
from GATES is available at every NAPA, doesn't mind ethanol and is
(comparatively) cheap...
Jeremy
Dana
Posted: Tue Sep 09, 2008 3:21 am Post subject: fuel line? |
At 10:15 PM 9/8/2008, Jeremy Casey wrote:
Quote: |
For what it is worth...RANS recently released a Service Bulletin saying to
The blue polyurethane tubing sold by Bing is specifically labeled "alcohol
resistant fuel line"
-Dana
Why is it called tourist season if we can't shoot at them?
grantr
Posted: Tue Sep 09, 2008 4:25 am Post subject: Re: fuel line? |
The way my MK III with the 503 is setup, the pulse pump pulls the fuel up to the engine.
So is this the wrong way to have it setup? I don't have an electric pump. The only pump on mine is the pulse pump.
Should I get an electric pump?
Dennis.Kirby(at)kirtland. Guest
Posted: Tue Sep 09, 2008 12:58 pm Post subject: fuel line? |
<< The tygon and clear vinyl type fuel lines are substandard and cheap
Grant -
I'll second JetPilot's statement above, and will back it up with this
short story:
(OK - maybe a medium length story) (This all happened to me in the past
month.)
I installed new fuel tanks in my Mark-3 (2 x 6 gal) recently.
They are the stock, top-feed type tanks, with the stainless 1/4" pipe
dropping down into the tank. At the bottom end of the SS pipe is a
5-inch piece of flexible fuel hose, the other end of which is connected
to the finger screen, which rests on the bottom of the tank.
When installing these new tanks in June, I used Tygon for those two
5-inch pieces of flexible fuel line in each tank, for the finger
screens. It was new, unused tubing that I happened to have in my
aircraft supply bin, so I used it. It was in brand new condition -
soft, flexible, very rubbery. Since there is zero stress on that little
piece of fuel line sitting at the bottom of the tank, I figured it would
be OK. I was wrong.
(NOTE - the entire rest of my fuel system is plumbed using the black
Neoprene automotive fuel line, as you've seen recommended already in
this thread.)
After only 3 months of sitting in gasoline, that piece of flex line lost
its flexibility, and actually expanded a little bit. I discovered this
last week when I went to start the engine, and I turned on the electric
fuel pump (before starting the engine). I can always confirm that the
EFP is pushing fuel uphill to the engine when I see the fuel bubbling
though the clear glass fuel filter, located up at engine level.
I saw no fuel flowing through the fuel filter, even though the EFP was
on.
(Here's a plug for being able to see your fuel somewhere in the fuel
circuit, even if only at one point!)
The tanks each still had a gallon of gas, so the pickup screens were
well submerged in fuel. But the junction of the flex line and SS pipe
was ABOVE the fuel level, and air was being sucked into the fuel line
from the space between the inside of the flex line and the SS pickup
pipe. I couldn't believe that Tygon would lose its flexibility so
quickly from sitting in gas.
Right away, I replaced the Tygon with the black Neoprene auto fuel line
(I use Gates, heavy wall), and all is well again.
Dennis Kirby
Mark-3 Classic, N93DK
by0ung(at)brigham.net Guest
Posted: Tue Sep 09, 2008 12:59 pm Post subject: fuel line? |
I went to the NAPA store and bought some black rubber fuel line,,, been on
for about 5 years now.. the plastic line that came with the kit gave me
problems after 6 months,,, the clamps that came with the kit left a very
small area on the fuel line fittings that would not seal well.... while
checking on some staining on 1 carb, I was doing some pressure test and
found a very small leak coming from the connection... put in the black hose
and never found any problem since.
Boyd Young
MkIIIC
500 + hours
Dana
Posted: Tue Sep 09, 2008 1:42 pm Post subject: fuel line? |
At 04:57 PM 9/9/2008, Kirby, Dennis CTR USAF AFMC MDA/AL wrote:
Quote: | ...When installing these new tanks in June, I used Tygon for those two
5-inch pieces of flexible fuel line in each tank...
...air was being sucked into the fuel line
Dennis, since we've been discussing various types of tubing, what kind of
Tygon was it? Their yellow "Fuel and Lubricant Tubing"? Or something else?
-Dana
People are more violently opposed to fur than leather because it's safer
to pick on rich women than biker gangs.
russ(at)rkiphoto.com Guest
Posted: Tue Sep 09, 2008 1:54 pm Post subject: fuel line? |
Dennis
I hope everyone reads and remembers your story -- only way to fly
safe is to check EVERYTHING you can, whether you think it needs
checking or not. Sounds as tho your attention to detail avoided an in-
flight engine-out.
Good man , nice going
On Sep 9, 2008, at 4:57 PM, Kirby, Dennis CTR USAF AFMC MDA/AL wrote:
Quote: |
AL" <Dennis.Kirby(at)kirtland.af.mil>
Grant -
short story:
past
month.)
connected
little
would
be OK. I was wrong.
this thread.)
lost
this
electric
on.
line
Dennis Kirby
Jim Baker
Posted: Tue Sep 09, 2008 6:13 pm Post subject: fuel line? |
X-SpamReason %%SpamReason%%:
Quote: | When installing these new tanks in June, I used Tygon for those two
snip...
Quote: | After only 3 months of sitting in gasoline, that piece of flex line lost
Then, on the other side of the experience continuum....
I have fuel grade Tygon F-4040-A fuel and lubricant tubing at the
bottom of my tanks, in a setup similar to yours, and they've been
there for 13 years. Still like new with very minor swelling and no
cracks, abrasions.
There's a huge difference in Tygon formulations. Just happening to
have some yellow tubing lying around doesn't ensure that it's the
correct formulation. I'm sure that most folks are convinced that
Tygon is the Devil's own spawn and I'd have to say that assumption
would be correct...IF you haven't taken the time to research the
issue.
Jim Baker
580.788.2779
Elmore City, OK
Posted: Wed Sep 10, 2008 5:36 am Post subject: fuel line? |
To keep my tank pickups simple I have only straight dip tubes with no
floppy devices at the bottom.
I cut the ends at an angle. I think they end about 3/8" from the
bottom. I have some unusable fuel
but I wouldn't be trying to get that last few ounces anyway.
BB
snip...
> line lost
cracks, abrasions.
issue.
Jim Baker
580.788.2779
Elmore City, OK
Posted: Wed Sep 10, 2008 6:09 am Post subject: fuel line? |
Quote: | floppy devices at the bottom.
I cut the ends at an angle. I think they end about 3/8" from the bottom.
BB
Bob B:
I have always pulled fuel from the bottom of tanks, US, FS, and mkIII. I
don't want the engine to quit and still have a gallon of gas in the tanks to
crash with.
Never did like multiple tanks and dip tubes, but that is strictly personal.
My engine driven pump does a good job of pulling fuel (flown at 14,500 feet
MSL wide open throttle), although I help it along with a Facet electric pump
on takeoff, landing, and during low level flight, which is most of the time.
Would probably never get the standby pump turned on if I lost an engine due
to fuel pump on takeoff, landing, or low level flying.
I figure if I get myself into an impending crash I can turn off the master
switch and alternator switch which will shut down the electrical system, and
isolate it all the way back to the battery. However, don't think I have
ever remembered to do this on any of my crashes to date. Hardly ever hear
of a post crash fire in a Kolb, but there is always that one time. I don't
want to be the victim.
Titus, Alabama |
