george.mueller(at)aurora. Guest
Posted: Thu Sep 04, 2008 6:24 am Post subject: Slats |
Just another data point regarding the question about slats vs vgs, if I was doing it over again, I would: 1) build the wing without slats (adding vgs of course); and 2) build the wing longer. I didn't like having my slat brackets out in the wind, but I didn't want to cut them completely off either, so I have left about 3/4" of my slat brackets on, and have fabricated a mounting system so I can add the slats back on if I ever want to. But they will be mostly collecting dust on the the hanger wall.
Other mods that I have done recently: I added a George Race type towbar fitting to the nosewheel and bought a piper towbar for $50. I also fabricated a fiberglass cover for the BRS bridle on top of the fuselage. Before that I just had the bridle covered with leading edge tape, which was starting to come off in places.
My next project is to fabricate strut fairings. I have looked at different options but I think I will go with making them out of .016 6061-t6.
Separately, I get the digest version so I can't selectively delete flicka, so I would vote to ban him if possible. I am all for diversity of opinion but this horse operates outside the bounds of civil discourse.
George in Milwaukee
N701GM 42 hours flying
jpspencer(at)cableone.net Guest
Posted: Thu Sep 04, 2008 7:49 am Post subject: Slats |
>My next project is to fabricate strut fairings. I have looked >at
| Quote: | different options but I think I will go with making them out >of .016
6061-t6
That's what I did. It was quite a bit of work but well worth it as has been documented here before. When the strut fairings are combined with the no slats/vg's the plane feels like it's been set free. The only thing I have found that some might fault is the glide angle is much flatter of course because the drag is so dramatically reduced but the thing slips so well with the slab side that it's of no consequence. Rpm/fuel burn/noise/engine wear/buffet are all down, some dramatically...a vastly improved airplane.
Speaking of buffet; there are lots of opportunities for simple cleanup in the tail area, where it seemed a lot of the airframe buffet/vibration was coming from on mine. I faired in the nasty pocket under the rudder leading edge with foam and bondo, and under the HS leading edge with .016 and of course the VGs under the elevator. What a difference.
All those little cleanups add up to free fuel.
Joe
nyterminat(at)aol.com Guest
Posted: Thu Sep 04, 2008 8:06 am Post subject: Slats |
Joe, Could you post some pictues of the cleanup of the tail area?
Bob Spudis
Posted: Thu Sep 04, 2008 8:07 am Post subject: Slats |
Bob Spudis
ricklach
Joined: 20 Jun 2006 Posts: 127 Location: Kernville, Calif.
Posted: Thu Sep 04, 2008 8:13 am Post subject: Re: Slats |
Hi Joe,
I’ve been thinking about cleaning up the tail area where the Rudder, horizontal stabilizer and fuselage come together. It sounds like you have done just that. I would love to see some pictures of what you did and a little more conversation as to the results. Some people think trying to clean up a box like a 701 is a waste of time, but I think any improvement gained are free performance gains.
Rick
Posted: Thu Sep 04, 2008 9:39 am Post subject: Slats |
>I would love to see some pictures of what you did and a >little more conversation
I will send a few pics to somebody who already knows how to post them and they can post them if they like. I'm a little short on time right now trying to get things together for a trip...who wants them?
I tried to measure a speed gain with the tail cleanup and kept getting varying results since it's so small it's hard for me to accurately measure...the one that came up most often was 2.25 mph IIRC. Not definitive but indicative. Call it a couple mph...not a whole lot but it adds up and it's near free and did make it smoother. And it looks better to me and is light. As far as cleanup on this plane being a waste of time goes...it's SO crudely done that it can be easily improved. I never consider free speed/efficiency a waste, personally.
Joe
aa9td(at)verizon.net Guest
Posted: Thu Sep 04, 2008 8:05 pm Post subject: Slats |
Joe can you send some pictures of how you cleaned up the the tail of the 701 Bob aa9td(at)verizon.net (aa9td(at)verizon.net)
NYTerminat(at)aol.com Guest
Posted: Fri Sep 05, 2008 2:52 am Post subject: Slats |
Joe sent me some pictures to try to post. I'll give it my best.
Bob Spudis
In a message dated 9/5/2008 12:05:57 A.M. Eastern Daylight Time, aa9td(at)verizon.net writes:
[quote] Joe can you send some pictures of how you cleaned up the the tail of the 701 Bob aa9td(at)verizon.net (aa9td(at)verizon.net)
28.17 KB |
617 Time(s) |
34.43 KB |
638 Time(s) |
37.73 KB |
629 Time(s) |
28.61 KB |
667 Time(s) |
37.85 KB |
662 Time(s) |
Posted: Fri Sep 05, 2008 8:25 am Post subject: Slats |
What with all this recent business about slats and vgs I went back and read some of my flight test notes and ran across what I consider to be an important point that should be mentioned...it has been posted here before but I know most don't dig back thru all that old stuff so here it is again.
When I installed my VG's I did a WAG and put them at 12% chord. Well I went out and tried to force it in the air like I had been able to do with the slats. It got up on its hind legs and ran about 3 or 400 feet before breaking ground. Like a chicken trying to fly. The VGs were uncovered from the airflow I think. So I moved them to 10% and same thing but not quite as long a run before getting airborne. So I moved them to 8% and thats where they are now and will stay. I haven't been able to uncover them at 8%. Works good.
The point of all this drivel is if you decide to go VGs be sure and flight test them to see what you've got before stuffing it in some place where you need a max effort to get out...the placement is important for them to work properly...and 8% might not be the magic number for your bird. Test it.
Joe
lrm(at)skyhawg.com Guest
Posted: Fri Sep 05, 2008 5:35 pm Post subject: Slats |
Isn't it a problem to move them? The ones I have use a double sided
tape, once stuck, they are stuck. Seems like it would be a pretty good
job to take them up and relocate them without tearing them up, plus more
tape. Are we talking about the same VGs? Larry N1345L
Joe Spencer wrote:
| Quote: | What with all this recent business about slats and vgs I went back and read some of my flight test notes and ran across what I consider to be an important point that should be mentioned...it has been posted here before but I know most don't dig back thru all that old stuff so here it is again.
Joe
Checked by AVG - http://www.avg.com
kmccune
Joined: 22 Sep 2007 Posts: 577 Location: Wisconsin, USA
Posted: Fri Sep 05, 2008 5:48 pm Post subject: Re: Slats |
Thats interesting, kinda like what Chris said happens on a 701 with slats, on his Slats vs VG page. I wonder if he just gave up on the idea with out further testing?
Kevin
[quote="jpspencer(at)cableone.net"]
Joe
_________________ “Always do what you are afraid to do.”
R.W. Emerson (1803-1882)
Dorothy McCune |
vgstol(at)bigpond.net.au Guest
Posted: Fri Sep 05, 2008 9:08 pm Post subject: Slats |
Yep 12% is way to far back. That's why I recommend 7% to the front tips. Seldom any problems from being to far forward, but to far back the stall is happening in front of them.
JG
Posted: Sat Sep 06, 2008 4:01 am Post subject: Slats |
| Quote: | tape, once stuck, they are stuck. Seems like it would be a pretty good
I have the ones from JG. They use a 3M double sided tape that is easily(sort of) removed. It takes me about 2 hours to remove and replace them.
Joe
Posted: Sat Sep 06, 2008 6:17 am Post subject: Slats |
That's what I have too. It does seems like after twice it wouldn't be
very good. I don't think I will have that problem, thanks to you and
this list. Larry N1345L
Joe Spencer wrote:
| Quote: | > Isn't it a problem to move them? The ones I have use a double sided
Joe
Posted: Sat Sep 06, 2008 9:43 am Post subject: Slats |
>That's what I have too. It does seems like after twice it >wouldn't be
Larry
I replaced the adhesive on mine each time I moved them. Got more from JG but it should be available here somewhere.
Joe
Posted: Sat Sep 06, 2008 9:03 pm Post subject: Slats |
That 3M adhesive is an industrial product and I have to buy in $200 lots. Someone in Canada tried to get it from 3M there and had the same problem. Anyone needing more of it, just contact me and I'll send more, no charge.
JG
www.stolspeed.com
John Bolding
Posted: Sun Sep 07, 2008 5:00 am Post subject: Slats |
If Zenith is going to be stocking your VG's it would seem they would be the logical spot to go to for extra tape in N. America huh?
John
bobkat(at)btinet.net Guest
Posted: Sun Sep 07, 2008 11:28 am Post subject: slats |
I still don't seem to be able to post but will try it again.
Is it possible for someone thoroughly familiar with the g;ohjy vjstsvyrtodtovd pg yr 701 to fly the plane with slats on one side and slats removed wand VG's on the other.
I coubt it would be dangerous for an experienced pilot but might be enlightening.
A friend did it with those drooping wing tips on a kitfox and found absolutely no difference in takeoff, yaw, lift, etc.
Posted: Sun Sep 07, 2008 1:40 pm Post subject: slats |
