raimo.toivio(at)rwm.fi Guest
Posted: Tue Sep 02, 2008 11:43 pm Post subject: Autopilot /Trio Avionics - Dynon |
All
I have decided to install autopilot, probably one axis only.
Trio Avionic´s Ez Pilot looks neat.
Also their customer support seems to be fast and pro, so far.
On the other hand, I have in my panel Dynon D10A.
I know there is a possibility to update it for Dynon´s autopilot.
That would be much cheaper way but somehow I do not like that idea.
What about user´s experience´s?
Somebody there - do you have any important info?
Thanks, Raimo
OH-XRT
frans(at)paardnatuurlijk. Guest
Posted: Wed Sep 03, 2008 12:19 am Post subject: Autopilot /Trio Avionics - Dynon |
Hi Raimo,
I also decided to use a Trio Avionic's EZ Pilot. I've built it in, but
I'm not flying yet. Their customer support is great indeed! Installation
is pretty straightforward, I linked the servo to the starboard stick,
and put the servo itself under the left thigh support.
The nice things are that it really communicates very well with the GPS,
and has very nice features, not seen in other auto pilots. The complete
installation is very lightweight.
Frans
pm(at)tecnam.co.uk Guest
Posted: Wed Sep 03, 2008 1:00 am Post subject: Autopilot /Trio Avionics - Dynon |
Hi,
I have had both the wing leveller and altitude hold installed in a Tecnam
Sierra connected to an Avmap 4 GPS. I had the standard altitude hold without
auto trim as the Sierra exhibits very little trim change during flight and
so did not go for the auto trim which is available if the aircraft has
electric trim fitted. The EZ 2 allows pre set climb or decent rates as well
and the EZ 3 does that but with the addition of it also levels off at a pre
set height.
Over the winter I have built another Sierra and have installing the new
Trio Pro Pilot which uses the same servos but all incorporated in one head.
This is in fact the wing leveller and EZ3 in one case and is cheaper as a
package than the two separate units to the same spec. This will be connected
to a "Flymap GPS" but the Trio units uses the standard NMEA 0183 signal
link that is common to most GPS. Pre made wiring harnesses are available if
required.
The Trio does what it says on the box and will fly the aircraft better than
you can. As for service, it is superb. I stripped a gear in my first one
through clumsiness on my part while adjusting the clutch and they sent me a
whole new servo by return..
Paul Mitchell
peter.rees01(at)tiscali.c Guest
Posted: Wed Sep 03, 2008 3:29 am Post subject: Autopilot /Trio Avionics - Dynon |
I can vouch for the quality of the customer service from Trio - we
installed the unit but the data string from our GPS wasn't correct - we
shipped the GPS and head back to them and they did a 'special' in the
firmware so that it could understand our data stream - they shipped it
back to us - total cost £0 (or should that be $0).
The only thing that let our installation down was the quality of the
servo - we had the old style Navaids servo - the build quality was very
poor but they have since realised that and replaced it with a servo of
their own design.
Peter
How safe is your email? - http://www.tiscali.co.uk/products/securemail
__________________________________________________________
karelvranken(at)hotmail.c Guest
Posted: Wed Sep 03, 2008 11:36 am Post subject: Autopilot /Trio Avionics - Dynon |
Raimo C
I have a Trutrak wingleveler and for the 200 hours I have flown it works great. It is slaved to the Garmin 430 and intercepts at the waypoints of the route. Also good after sales service.
Best regards C
Karel Vranken.
> From: raimo.toivio(at)rwm.fi
Quote: | To: europa-list(at)matronics.com
Subject: Autopilot /Trio Avionics - Dynon
Date: Wed C 3 Sep 2008 10:54:57 +0300
--> Europa-List message posted by: "Raimo Toivio" <raimo.toivio(at)rwm.fi>
All
I have decided to install autopilot C probably one axis only.
Also their customer support seems to be fast and pro C so far.
On the other hand C I have in my panel Dynon D10A.
Thanks C Raimo
OH-XRT
&g========================>
