icubob(at)newnorth.net Guest
Posted: Wed Aug 27, 2008 3:47 am Post subject: exhaust pipe clearance |
hi all, i ran this by the jab list with not too much response . how much clearance are you allowing between the fiberglass cowling and the exhaust pipe where it passes thru the cowl?
also, any opinions on the effectiveness of a ''lip'' at the rear of the cowl to pull air from the low pressure chamber of the cowl?
any info appreciated. bob noffs
woodruff, wi
Lynn Matteson
Posted: Wed Aug 27, 2008 4:21 am Post subject: exhaust pipe clearance |
Bob-
My pipes pass between the cowl lip and the firewall, and there is
probably (can't measure as engine is out) 1--1/2" to 2" all around
pipe. With your 3300 engine (right?) you probably can't flip the
muffler over can you? On my 2200, I could flip the muffler over and
either have the pipes go through the cowl....holes required...or flip
the other way and they pass between the cowl lip and the
firewall....slick! If it was me, I'd give it an inch clearance,
paint it with primer, taxi it and see if it looks "cooked"...if so
add a half-inch more clearance all the way around, and test again.
When in flight, there should be no more higher temps in that area, I
wouldn't think, than what you'd see in a ground-run/taxi situation.
The lip is VERY helpful in drawing out the heated air from the cowl
interior. In fact, it is *strongly* recommended at the Jabiru clinics
to do this.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200, 562 hrs and holding for repairs
Status: "Condition grounded, but determined to try." (Pink
Floyd..."Learning to Fly")
On Aug 27, 2008, at 7:47 AM, bob noffs wrote:
| Quote: | hi all, i ran this by the jab list with not too much response . how
woodruff, wi
http://www.matronics.com/Navigator?Kitfox-List_-
============================================================ _-
forums.matronics.com_-
contribution_-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Lynn Matteson
Posted: Wed Aug 27, 2008 4:36 am Post subject: exhaust pipe clearance |
Also, Bob, on that "low pressure" chamber inside the cowl...it
becomes a low pressure area when you have about 3 times the exit area
as compared to the inlet area. You need about 3 times the area in
order to allow for the expanded air to escape...remember that the air
goes into the air inlets as cool air, then becomes heated and
expands, and this expansion is why the 3x larger area is needed. The
lip just makes for a venturi effect, which helps pull the heated air
from the cowl chamber.
Lynn Matteson
Kitfox IV Speedster
woodruff, wi
contribution_-
N369LM |
Michel
Posted: Wed Aug 27, 2008 4:56 am Post subject: exhaust pipe clearance |
| Quote: | From: bob noffs [icubob(at)newnorth.net]
The best there is, Sir!
Here is a photo of my "lip" and it works like marvel to keep my Jabiru the coolest engine on this side of the galaxy!
http://home.online.no/~michel/tmp/Heater.jpg
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200 ... flying as PAX
_________________ Kitfox 3 - Jabiru 2200 |
gary.algate(at)sandvik.co Guest
Posted: Wed Aug 27, 2008 6:04 am Post subject: exhaust pipe clearance |
I agree with Lynn on the cowl lip - I have even increased the outlet area under my Jab installation (Round Cowl) and fitted additional Aluminum lips to increase the pressure reduction (See Foto)
regards
Gary
Gary Algate
Classic 4 Jab 2200
Office Phone: +61 8 8276 7655
This e-mail is confidential and it is intended only for the addressees. Any review, dissemination, distribution, or copying of this message by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error, kindly notify us immediately by telephone or e-mail and delete the message from your system. The sender does not accept liability for any errors or omissions in the contents of this message which may arise as a result of the e-mail transmission.
Lynn Matteson <lynnmatt(at)jps.net>
Sent by: owner-kitfox-list-server(at)matronics.com
27/08/2008 10:04 PM
Please respond to
kitfox-list(at)matronics.com To
kitfox-list(at)matronics.com cc
Subject
Re: exhaust pipe clearance
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
Bob-
to do this.
Lynn Matteson
Kitfox IV Speedster
> woodruff, wi
> contribution_-
264.37 KB |
350 Time(s) |
Michel
Posted: Wed Aug 27, 2008 9:56 am Post subject: exhaust pipe clearance |
| Quote: | From: gary.algate(at)sandvik.com
Size wise, yours looks pretty much like mine, Gary.
.. I mean ... well, you know what I mean!
Michel Verheughe
Norway
Posted: Thu Aug 28, 2008 4:24 am Post subject: exhaust pipe clearance |
Michael
As you know - Size really does matter
Gary
Gary Algate
SMC, Exploration
Michel Verheughe <michel(at)online.no>
28/08/2008 03:49 AM
Please respond to
<kitfox-list(at)matronics.com> cc
Subject
RE: exhaust pipe clearance
Michel Verheughe
Norway
</b></font></pre></body></html>
