Rattle Can Primers
numskull99(at)netzero.net
PostPosted: Tue Aug 26, 2008 3:34 pm    Post subject: Rattle Can Primers Reply with quote
I have seen that several people are using NAPA 7220 self etching primer, and I started using it. But NAPA is 20 min farther than several other hardware stores. Has anyone used any other rattle can primers? If so, How has it worked? Also is 6061-t6 considered galvanized?
Derek Lewis
DO NOT ARCHIVE!
Click here to find Medical Transcription Training programs.
http://thirdpartyoffers.netzero.net/TGL2231/fc/Ioyw6ijmaKOPGCngAHYgMQAl3YoUZ0lM0XctRCZsA9Vc9n27dqrOjw/
larry(at)macsmachine.com
PostPosted: Tue Aug 26, 2008 3:58 pm    Post subject: Rattle Can Primers Reply with quote
Derek,
6061-T6 is just aluminum, really corrosion resistant as aluminums go,
but still no etch or plating.
Suggest you continue with the self etch primer if it seems to work for you.
Derek Lewis
DO NOT ARCHIVE!
psm(at)att.net
PostPosted: Tue Aug 26, 2008 4:46 pm    Post subject: Rattle Can Primers Reply with quote
Hi Derek,
Self etch primers contain acid to eat through the aluminum oxide that
forms almost instantly on pure aluminum. This oxide is impossible
for paint to stick to. There are several different approaches to
deal with this and the self etch primer is ideal (in my opinion) when
you are doing small areas at a time.
I don't think it is possible to galvanize aluminum. This is a
process used primarily on steel. A pure zinc coating is placed on
the steel to prevent rust. To my knowledge there is no way to
successfully paint the zinc and it is nearly impossible to
remove. It also causes great difficulties for welders.
Good luck,
Paul
XL getting close
Derek Lewis
leinad
PostPosted: Tue Aug 26, 2008 5:09 pm    Post subject: Re: Rattle Can Primers Reply with quote
Derek,
I've been using Dupli-Color self etching primer. It sticks great to the aluminum. I first scuff it with a little scotch bright, and wash it well with a solvent to remove any residue and sharpee marks. I spray it outside with a dust mask. You can find this stuff almost anywhere that sells spray paint in rattle cans.
Dan
ch601xl/corvair plans builder
Derek Lewis
DO NOT ARCHIVE!
professor71(at)HOTMAIL.CO
PostPosted: Tue Aug 26, 2008 6:03 pm    Post subject: Rattle Can Primers Reply with quote
.hmmessage P{margin:0px;padding:0px}body.hmmessage{FONT-SIZE: 10pt;FONT-FAMILY:Tahoma}Derek
I used rust-oleum primer and paint rattle cans for the whole plane. It is still on after 3.5 years. I did do what Dan did as far as scuffing the surface and washing it down with lacquer thinner before priming. Everyone that has seen the plane cannot believe I did the plane with rattle cans. I am not an expert painter by any means but it came out looking pretty nice. (see pic) Inexpensive too.
John
601HD-912ul-315hrs
Subject: Re: Rattle Can Primers
Date: Tue C 26 Aug 2008 18:09:43 -0700
--> Zenith-List message posted by: 'leinad' <leinad(at)hughes.net>
Derek C
I've been using Dupli-Color self etching primer. It sticks great to the aluminum. I first scuff it with a little scotch bright C and wash it well with a solvent to remove any residue and sharpee marks. I spray it outside with a dust mask. You can find this stuff almost anywhere that sells spray paint in rattle cans.
Dan
> I have seen that several people are using NAPA 7220 self etching primer C and I started using it. But NAPA is 20 min farther than several other hardware stores. Has anyone used any other rattle can primers? If so C How has it worked? Also is 6061-t6 considered galvanized?
> Thanks C
> Derek Lewis
> DO NOT ARCHIVE!
http://forums.matronics.com/viewtopic.php?p=200793#200793
&gt
Get thousands of games on your PC C your mobile phone C and the web with Windows®. Game with Windows
 Filesize:  397.92 KB
 Viewed:  377 Time(s)
Afterfxllc(at)aol.com
PostPosted: Tue Aug 26, 2008 6:29 pm    Post subject: Rattle Can Primers Reply with quote
Auto zone sells a good etching primer also.
Jeff
It's only a deal if it's where you want to go. Find your travel deal here.
