Annual Condition Inspection
Tommy Walker
PostPosted: Mon Aug 25, 2008 12:10 pm    Post subject: Annual Condition Inspection Reply with quote
701-ers,
I started my annual today and found a couple of things that might be of interest to you. Actually, I found one of them a week ago, but started working on it today.
Landing Gear.
1. 7L2-2A RUBBER SPACER. - Attaching a picture. You might want to include this in your inspection. This is our third rubber spacer. I think I'm going to find a 6-ply radial tire and cut me a length of material to support the gear.
2. 79-SB Rotax engine Radiator mount.
Obviously I did not have the needed radius for the bend in this mount. I am fabricating a new mount with the required 1/8 " radius.
Hope this helps,
Tommy Walker in Alabama
 Filesize:  39.53 KB
 Viewed:  435 Time(s)
 Filesize:  46.41 KB
 Viewed:  435 Time(s)
Tommy Walker
N25A - Anniston, AL
NYTerminat(at)aol.com
PostPosted: Mon Aug 25, 2008 7:33 pm    Post subject: Annual Condition Inspection Reply with quote
Tommy,
I just replaced mine with pieces I cut out of a truck tire, this has been my 3rd time with pieces of rubber. I hoe this will be the final solution.
Bob Spudis
N701ZX/ 912S/ 160hrs many landings
In a message dated 8/25/2008 4:11:47 P.M. Eastern Daylight Time, twalker(at)cableone.net writes:
701-ers,
Landing Gear.
It's only a deal if it's where you want to go. Find your travel deal here.
Tommy Walker
PostPosted: Tue Aug 26, 2008 2:14 pm    Post subject: Re: Annual Condition Inspection Reply with quote
Hi Bob,
I am going to find a good tuff truck tire and cut me out a couple of pieces of material.
What did you cut the rubber with?
Was it a steel belted radial?
Tommy
NYTerminat(at)aol.com wrote:
Tommy,
Bob Spudis
Tommy Walker
N25A - Anniston, AL
Joemotis(at)aol.com
PostPosted: Tue Aug 26, 2008 3:08 pm    Post subject: Annual Condition Inspection Reply with quote
A sabre saw with a medium blade works quite well, although the pieces that I was cutting (roughly 4"X 4") were used as buffers on a Catapult to launch melons!!! A piece of plywood backing secured through the sidewall with drywall screws will allow a lot more creativity in your shape/design, though.
(Cutting through both at the same time and being patient)
Joe Motis
No Archivos Hombre
PostPosted: Tue Aug 26, 2008 6:34 pm    Post subject: Annual Condition Inspection Reply with quote
Tommy,
Yes it was a steel belted tire, used a sawzall to get the chunk of tire apart ad then used my bandsaw to cut to size and shape. Thanks for your reporting on the subject.
Bob
In a message dated 8/26/2008 6:15:06 P.M. Eastern Daylight Time, twalker(at)cableone.net writes:
Hi Bob,
Tommy
beachyjeff(at)juno.com
PostPosted: Wed Aug 27, 2008 3:53 am    Post subject: Annual Condition Inspection Reply with quote
On the advice of a fellow builder, I went to the nearest Caterpillar heavy equipment dealer and bought a short section of heavy hydrolic hose, which I cut in half lengthwise. I then cut pieces to fit the landing gear bracket. 138 hours later they haven't slipped out or worn through. The curve of the hose helps keep them in place.
Jeff Beachy
> Tommy,
> Bob Spudis
[url=_blank]Pamper yourself with great package deals on luxury travel. Click now![/url]
cffd(at)pgrb.com
PostPosted: Wed Aug 27, 2008 9:22 am    Post subject: Annual Condition Inspection Reply with quote
Tommy,
I sliced open large diameter auto heater hose and made landing gear spacers,
for top and bottom of gear.
They have been in place a couple of years and no signs of deterioration.
Chuck D.
N701TX
Jab 2200
