gareywittich2000(at)yahoo Guest
Posted: Thu Aug 21, 2008 8:02 pm Post subject: Construction question for RV-8(A) Elevator |
My Drawing 4PP (circa 2000), which Vans has "somewheres", is confusing to me:
1) This drawing shows the "DIMENSIONS of Elevator Spar E-602PP" (narrow end) with cutouts of 3/4" X 5/8". What is this cut-out for - does not make sense ??
2) Section B-B: Shows the E-602PP Spar mating to the aft end of the E-604 Rib. It looks like the aft end of E-604 Ribs "flange" is cut out so as to not interfere with the E-602PPs "flange" at this point. Is this correct ??
3) Section B-B: Shows a "dashed line" where the above Spar and Rib meet. IF the aft end of E-604 Rib's flange is cut-out, what does this "dash line" signify as nothing is there ???
3) Earle in Florida I lost your phone number.
Need a little clarification HELP.
Thank you, Garey Wittich (310) 392-1682 Santa Monica, CA
gcomfo(at)tc3net.com Guest
Posted: Sat Aug 23, 2008 5:32 am Post subject: Construction question for RV-8(A) Elevator |
