djwild2(at)hotmail.com Guest
Posted: Tue Aug 26, 2008 5:44 pm Post subject: spinner |
I have a 532 with a GSC 3 blade ground adjustable prop. and I am looking for a spinner. The dia. of the spinner mounting plate behind the prop is 7" and has 9 small holes all spaced out around the edge. Can anyone show me the way to a spinner? Thanks
Dan Wild
kitfox model 1
532
MDKitfox(at)aol.com Guest
Posted: Tue Aug 26, 2008 6:12 pm Post subject: spinner |
Dan,
This may be your lucky day. I have a new aluminum spinner, apparently for a GSC prop. It's nearly 11 inches long and about 7 in diameter at the base. It was supposed to fit on my 912S with a Warp Drive prop, but it doesn't. I have a feeling it may be for a different Rotax. I bought it from the old SkyStar company. As a matter of fact it has a SkyStar part number on it. It has two plates, one is the bulkhead plate and the other is more forward. I have all the nut plates, screws, etc. It's never been used.
If your interested and think it may work for you, please feel free to contact me off line or at 301-502-8029.
Rick Weiss
Series V Speedster, 912S
On Aug 26, 2008, at 9:41 PM, Daniel Wild wrote:
| Quote: | I have a 532 with a GSC 3 blade ground adjustable prop. and I am looking for a spinner. The dia. of the spinner mounting plate behind the prop is 7" and has 9 small holes all spaced out around the edge. Can anyone show me the way to a spinner? Thanks
Dan Wild
kitfox model 1
532
Rick Weiss
Series V Speedster, 912 Power, SkyStar S/N 1
MDKitfox(at)aol.com (MDKitfox(at)aol.com)
= [quote][b]
