jaybannist(at)cs.com Guest
Posted: Fri Aug 15, 2008 2:29 pm Post subject: Crash |
OK, a few facts from the horses mouth:
As most of you know, I have just completed a Zodiac CH 601XL (Lil
Bruiser). Both me and the insurance company wanted me to get at least
an hour in make and model before I solo my airplane. I discovered a new
service at McKinney Airport (TKI), for training and rental in a 601XLi.
This was a familiarization flight in a nearly new AMD built 601XLi.
The airplane originally had the “old style” canopy latches. The owner
was not satisfied with that mechanism and had the factory retrofit the
new style latches. The owner, Dennis Levy, who is also CFII. was in the
right seat, me in the left. We had gone through all the standard
maneuvers and were straight and level. I noticed that the right hand
canopy latch had come loose and the rail was up about 2 inches. I
pointed it out to Dennis. We were in sight of a private airfield, but
Dennis decided he was going to re-latch it - in the air! In doing so,
the latch on my side came loose and the canopy immediately shot up to
about 50 deg., and the nose went down about 60 deg. I immediately
pulled the power completely off. We both grabbed what we could on the
canopy but could only pull it down to about 30 deg. We both pulled
back on the sticks, with all our might, but never got the nose up to
level. I steered toward an open, plowed field. We hit the ground at
about 10 deg nose down and stopped immediately. No fire. The canopy
did not depart the airframe. Dennis was air lifted to Baylor Hospital
in Dallas. I was taken to the trauma suite at the Presbyterian
Hospital in Greenville. X-rays and CAT scans showed nothing out of
place or broken. I have a badly sprained right foot and ankle, a
bruised rib cage and lots of cuts and bruises on my arms. I also have
a slight vision problem. In pain, but still OK.
It is important to note that this had nothing to do with wings, but
with a “new and improved” canopy latching system.
Consequently, I am STRONGLY recommending that any 601 have a fail-safe
strap to the rear canopy bow, regardless of the latching system, to
keep this from ever happening again.
Alive and still with you - Jay
Bannister________________________________________________________________
________
Email message sent from CompuServe - visit us today at http://www.cs.com
naumuk(at)alltel.net Guest
Posted: Fri Aug 15, 2008 2:40 pm Post subject: Crash |
Jay-
Good job.
Bill
jonaburns
Posted: Fri Aug 15, 2008 2:47 pm Post subject: Re: Crash |
Jay,
I am happy that you guys are alive, and hope that Dennis recovers soon.
Posted: Fri Aug 15, 2008 2:55 pm Post subject: Crash |
This confirms other reports (from myself and others) about open bubble canopies in XLs and Evektor SportStars. In at least two cases with all your strength you can't close a open canopy in the air. I've attached the old report about a deliberate test in England again.
This is what I have written in the past:
Back in December Clive Richards sent out the attached report from the UK PFA magazine of an anonymous pilot testing his (pre-XL?) 601 with an open canopy. He attached a safety cord and intentionally unlatched his canopy. Quoting:
“I commenced the test at 3500 ft and 80 knots cruise. I secured the safety cord to the cleat at my elbow with about 1 ft of slack and released the catch. The canopy rapidly popped up about 1 ft at the trailing edge as expected. I then slowly paid out the cord from the cleat and allowed the canopy to rise to a steady state. The canopy adopted a position where the base of the canopy settled to an angle of about 35 degrees to the airflow. Full lateral and pitch control could be maintained but forward speed dropped to about 60 knots and despite increase to full throttle descent was about 300 ft/min. An unexpected problem now presented itself. I was descending quickly and all the strength I could muster with my right arm was only just sufficient to pull the cord down and cleat it progressively. Possibly the slot effect at the front of the canopy open at the front increased the lift (and additionally the gas struts require a cord load of 15 lbs static). I finally, exhausted, got it down to about 6 inches and returned to…”
Craig again. I had a similar experience in an Evektor SportStar. This LSA resembles the 601XL: low wing, front-hinged bubble canopy. One difference is that the canopy is split behind the seats. There is a cross-bar behind the seats:
www.evektoramerica.com/SportStarPlus.htm
I was flying left-seat with my instructor. The canopy popped while we were in the pattern. I would estimate that the gap was well over a foot. While the instructor flew I tried to close the canopy. I wrapped my arm around the cross-bar and used all my weight and strength and could not close the canopy. At best I think I got the gap down to 6-8 inches. Evektor redesigned the latch the next year.
I believe the upward force was generated by lift and not wind under the canopy as it did not decrease as I closed the gap.
-- Craig
canopyopening.pdf |
99.01 KB |
822 Time(s) |
sperry50(at)comcast.net Guest
Posted: Fri Aug 15, 2008 3:09 pm Post subject: Crash |
HOLY MOLY BATMAN!!!! If you were in Fort Myers every drink would be on me.
You deserve it. This doesn't deter me from finishing and flying but it does
give me an extra chapter in the "odd things that might happen" chapter.
Congratulations on keeping a level head and "flying the plane". Hope your
healing is quick!
Skip Perry
N601MP
DO NOT ARCHIVE
Posted: Fri Aug 15, 2008 5:55 pm Post subject: Crash |
Craig,
A canopy strap would be a good idea, but the one I constructed was to
preclude damage from wind getting under it
and taking it past top dead center. I've had it act like a full sail
pulling me across the apron in taxi after shutting off the engine.
Would suggest a bit stronger hardware than the nylon buckles used.
Knowing you're really latched is the best thing. A white stripe across
the visual latch slot and white on the arm to improve
seeing a good latch condition is my active solution. I've been unlatched
three times, once the right, twice the left side only.
None since adding paint for a good visual cue.
Craig Payne wrote:
Here is how Larry McFarland attached a canopy safety strap on his 601:
http://www.macsmachine.com/images/canopy/full/viewupperbracket.jpg
http://www.macsmachine.com/images/canopy/full/viewcanopyopen.jpg
I couldn't find a good picture of the lower attachment of the cable. I believe there is an adjustable buckle on the strap to cinch it up before flight. Look in the archives for an old post from Larry describing the setup.
-- Craig
Afterfxllc(at)aol.com Guest
Posted: Fri Aug 15, 2008 6:30 pm Post subject: Crash |
Jay,
First let me say I'm glad both of you are ok and I am not questioning you in any way I am just trying to understand what happened.
What I am trying to understand is what the canopy being open had to do with the crash. I have pictures of a 601xl flying with the canopy open and it can and will fly in that situation. Did you just decide to land or forget to re apply power? As soon as I get to the airport I will take some pics of a latch Ben made for his 601xl and before flight he can insure the canopy is locked. I hope that Zenith didn't create a brand new problem for the brand new airplane. I was going to modify the canopy and latch system for the one I am building but might reconsider that now in light of the new information.
My other question is if the new canopy can withstand the wind forces on the rear solid mounted piece or will it depart the aircraft if the canopy pops open. Has this been tested open?
I will post the pics of a flying 601 with canopy open as soon as I find them.
Jeff
Looking for a car that's sporty, fun and fits in your budget? Read reviews on AOL Autos.
kmccune
Joined: 22 Sep 2007 Posts: 577 Location: Wisconsin, USA
Posted: Sat Aug 16, 2008 4:58 am Post subject: Re: Crash |
WOW, glad you guys are OK.
Kevin
_________________ “Always do what you are afraid to do.”
R.W. Emerson (1803-1882)
Dorothy McCune |
Posted: Sat Aug 16, 2008 5:42 am Post subject: Crash |
Jeff,
The canopy had EVERYTHING to do with the crash. I have heard that the
601 is docile and controllable with the canopy up. Post all the
pictures you want; but this 601 was NOT controllable, at least in
pitch. I was able to make a gentile turn toward the "landing" site,
but both me and the other pilot could NOT get the nose up to a landing
configuration. When the canopy went up, it was almost out of reach and
we absolutely could not pull it down to more than about 30 deg. We did
noit "decide" to land. We could not keep it from going down. In our
situation, we may have "forgotten" to do several things, but with two
hands pulling mightily on the canopy and the other two pulling mightily
on the stick, we had no options as to what else to do. The wind was
unbelievable. The headset and my cap blew off my head. We were
fighting for our very lives. As they say, you just had to be there".
Jay
d.goddard(at)ns.sympatico Guest
Posted: Sat Aug 16, 2008 6:03 am Post subject: Crash |
Jay, don't worry about the clowns who think they know better than you what
could/should have been done. It's pointless.
Congratulations on getting to the ground and walking away!! Major
accomplishment, well done!
bryanmmartin
Posted: Sat Aug 16, 2008 6:34 am Post subject: Crash |
Did you leave the power off for the entire duration of the incident or
did you try to reapply power at some point? It seems that some prop
wash flowing over the tail might have provided more pitch control, if
you had the time to try it. I'm not trying to criticize or second
guess, but if i ever find myself in a similar situation, it would be
good to at least know what didn't work for someone else.
I know how quick you can run out of options in such a situation, I
just recently had a close call myself involving a forced landing after
a power failure. I was lucky to be very near an airport at the time
and put it down on the runway.
On Aug 16, 2008, at 9:41 AM, jaybannist(at)cs.com wrote:
Jeff,
the 601 is docile and controllable with the canopy up. Post all the
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
_________________ --
Bryan Martin
do not archive. |
jmaynard
Joined: 27 Feb 2008 Posts: 394 Location: Fairmont, MN (FRM)
Posted: Sat Aug 16, 2008 7:08 am Post subject: Crash |
I'm not about to second-guess your decisions and actions. You were there,
and I wasn't. I'm just looking for information before I go out to the
airport and start looking at N55ZC to see what can be added.
On Fri, Aug 15, 2008 at 06:28:42PM -0400, jaybannist(at)cs.com wrote:
| Quote: | I noticed that the right hand canopy latch had come loose and the rail was
up about 2 inches.
At this point, the left latch wasn't loose, I assume. The new latch can be
visually verified to be latched quite easily. Did you or Dennis look before
takeoff?
I'm at a loss to explain how one side could be unlatched. I've tried in my
airplane to latch just one side and not engage the hook on the bolt on the
other, and just wasn't able to without it being obvious there was a problem.
| Quote: | I pointed it out to Dennis. We were in sight of a private airfield, but
This is probably why the AMD POH says to fly the airplane and make a normal
landing, then fix it on the ground.
| Quote: | In doing so, the latch on my side came loose and the canopy immediately
shot up to about 50 deg., and the nose went down about 60 deg. I
immediately pulled the power completely off.
I do wonder what would have happened with power - but I'm not about to
suggest anyone run the experiment!
| Quote: | It is important to note that this had nothing to do with wings, but
with a ???new and improved??? canopy latching system.
Indeed. The naysayers can't say this is somehow related to the Zodiac's
structural design.
Another thought I just had: If this is a case of one side coming unlatched
in flight somehow (though, again, I'm at a loss to explain how it might
happen short of a component failure), maybe it'd be possible to add some
sort of a keeper to the open end of the latch hook that would have to be
manually moved out of the way before the latch could be undone? This would
be a bit difficult to undo while solo, but there's probably a way around
that, too.
| Quote: | Consequently, I am STRONGLY recommending that any 601 have a fail-safe
Hm. I'm wondering if it wouldn't be possible to create some sort of latch
between the rear canopy bow and the tube on the front of the
turtledeck...have to look at that. I do know the turtledeck extends forward
a fair amount (I've thought about putting my 496's XM antenna up there), but
just how far forward I don't recall at the moment.
| Quote: | Alive and still with you
And we're all thankful for that! In the end, you and Dennis were able to
walk away (well, almost), and that's what really counts. The airplane can be
replaced. You can't.
Jay Maynard, K5ZC http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
Fairmont, MN (FRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC
_________________ Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC |
Posted: Sat Aug 16, 2008 7:50 am Post subject: Crash |
Bryan,
When the nose pitched down 60 deg was when I pulled the power off.
After that, we had all four hands fully engaged, so no way to change
anything.
I have had three previous engine-outs, which I handled without bending
anything. Those didn't scare me like this one, because I had full
control of a glider. Those caused immediate concern, but this one
scared the living sh...t out of me!
Jay
Posted: Sat Aug 16, 2008 8:11 am Post subject: Crash |
See inserted comments (***):
Posted: Sat Aug 16, 2008 8:31 am Post subject: Crash |
Please. I would like to see no more "woulda', coulda', shoulda'" about
this subject on this public forum. If you have questions, please
contact me directly. If I feel there is subject matter that concerns
the list, I will most certainly share it with you.
Thanks - Jay
________
Posted: Sat Aug 16, 2008 8:32 am Post subject: Crash |
Jay
I wonder if the difference is 2 people inside the aircraft. He was flying alone.
Jeff
| Quote: | Jeff,
Jay
Posted: Sat Aug 16, 2008 8:39 am Post subject: Crash |
No one is thinking they know better than anyone and the pic's weren't to say what he should or shouldn't have done but I haven't seen anything negative until your post. And since I build these things and was considering the new latch system I too am looking for ways to help and understand.
backstagelive(at)gmail.co Guest
Posted: Sat Aug 16, 2008 9:02 am Post subject: Crash |
Jay,
Is it possible your shoulder may have hit the new canopy release lever the
factory put between the pilot and passenger? Did you have any up elevator
travel left before you landed? Do you think the new canopy release lever
should be moved to a different location? Do you think it would be possible
at a higher speed to loose the canopy and inadvertantly put the airplane in
a condition that would overstress the wings?
Congratulations on demonstrating great skill as a pilot. We all wish you the
best and heal fast!
Joe in Oshkosh
sky_ranger161
Jay!
Well done my man. Thanks for sharing your story so that others can benefit from it. Because of your account, I'll definitely be incorporating some type of secondary canopy safety strap in mine. I'd heard of things like this happening, but truly now understand the consequences. Much appreciated.
Debo Cox
Nags Head, NC
Doing my best to keep my nose from pitching 60-degrees. *Gulp*
