Hose Clamp Safety Wire
Steven Green
PostPosted: Thu Aug 14, 2008 5:25 pm    Post subject: Hose Clamp Safety Wire Reply with quote
How do you safety a hose clamp?
I have a multitude of hose clamps on my airplane, coolant, oil, and fuel
hoses. None of them are safetied. None have failed.
What kind of hose clamp failed on your engine? There are a multitude of
different makes and styles of hose clamps in use on airplanes, tractors,
trucks, cars, etc.
 Filesize:  37.63 KB
 Viewed:  493 Time(s)
Steven Green
PostPosted: Thu Aug 14, 2008 6:26 pm    Post subject: Hose Clamp Safety Wire Reply with quote
purplemoon99(at)bellsouth
PostPosted: Fri Aug 15, 2008 9:17 am    Post subject: Hose Clamp Safety Wire Reply with quote
EXCELLENT !!! GREAT PICT... Joe N101HD
Steven Green
PostPosted: Sat Aug 16, 2008 6:49 pm    Post subject: Hose Clamp Safety Wire Reply with quote
John,
Not on an aircraft engine. I have had problems with some on oil cooler
lines on VWs. Probably poor quality clamps.
Steven
Hi Steven G:
Thanks for the tip.
Why did you safety the hose clamps? Did you have a problem with one
loosening up?
Steven Green
PostPosted: Sun Aug 17, 2008 7:02 am    Post subject: Hose Clamp Safety Wire Reply with quote
Why Not...... One more little idea that could help, instead of a lot of
second guessing, and would of ,should of could of. It's called prevention !
Great Idea . safety wired the easy one's yesterday,and the hard ones under
the plane and against the fire wall today Joe N101HD
PostPosted: Sun Aug 17, 2008 7:33 am    Post subject: Hose Clamp Safety Wire Reply with quote
of
! Great Idea . safety wired the easy one's yesterday,and the hard ones
under the plane and against the fire wall today Joe N101HD
Joe:
Don't think anyone has established a requirement for safety wiring hose
clamps. I looked and turned up zilch.
Preventing the screw from backing out of the clamp is not the problem, when
a hose pulls or is blown loose from a fitting. Compression and shrinkage is
the problem, which requires periodic retightening of the clamp and/or
replacing the hose.
Please tell us about your firewall. I don't have one.
PostPosted: Sun Aug 17, 2008 1:21 pm    Post subject: Hose Clamp Safety Wire Reply with quote
Glad to tell you about my firewall it's just foward of my dash and my feet
.It's really neat, and a good idea keep's the heat out of the cockpit,not to
mention the bugs and rain, it also hold's the engine mount,AND that holes
the engine that turns the little (68") blades in the front of the aieplane
and makes it go, I don't know who thought of it ,but it is a good idea just
like safety wireing hose clamps, that's all I can tell you about my fire
wall ,If you don't under stand,I'll be glad to send pictures. Joe
Zenith 601HD
slyck(at)frontiernet.net
PostPosted: Sun Aug 17, 2008 1:45 pm    Post subject: Hose Clamp Safety Wire Reply with quote
har har, guess you stepped into that one John.....
This guy is from another universe.
I went to another fly in picnic today, breaking a record (for me)
Forecast to be windy, I brought along my ladyfriend for ballast
(don't tell her that)
Ground speed to: 40mph, great event with a considerable variety of
craft.
The folks there supplied chocks and bungees for gust locks and I
parked tail to the wind.
Nice brisk but smooth ride back but a scary struggle on short final,
bucking, dropping and climbing,
managing to stay out of the corn.
Think I'll stick to calmer air for a while.
BB
btw: ground speed return 90mph
On 17, Aug 2008, at 5:20 PM, Southern Reflections wrote:
<purplemoon99(at)bellsouth.net>
my feet .It's really neat, and a good idea keep's the heat out of
the cockpit,not to mention the bugs and rain, it also hold's the
engine mount,AND that holes the engine that turns the little (68")
blades in the front of the aieplane and makes it go, I don't know
who thought of it ,but it is a good idea just like safety wireing
hose clamps, that's all I can tell you about my fire wall ,If you
don't under stand,I'll be glad to send pictures. Joe Zenith
601HD
PostPosted: Sun Aug 17, 2008 5:02 pm    Post subject: Hose Clamp Safety Wire Reply with quote
Zenith 601HD
Joe:
Thanks for the info on fire walls.
Most of the aircraft I fly have the prop on top or the rear of the fuselage.
Still looking and waiting for someone to give me a requirement to safety
wire hose clamps.
PostPosted: Sun Aug 17, 2008 7:30 pm    Post subject: Hose Clamp Safety Wire Reply with quote
All in fun John. I still like the safety wire idea. Joe N101HD
NeilsenRM(at)comcast.net
PostPosted: Sun Aug 17, 2008 7:34 pm    Post subject: Hose Clamp Safety Wire Reply with quote
I have had a bunch of other things work loose or crack on my airplane but
never a hose clamp. I had a old cog belt redrive that was a pretty good
shaker and tester of anything that could work loose and I never had a hose
clamp work loose. Also if you get good hose I'm not sure one would come off
a fitting even without a hose clamp. Have your ever tried to remove a good
hose from a good fitting. It can't be done without making a slit in the
hose. No.... take the time to safety all your bolts, exhaust system, carb
boots etc. If you still NEED something to do go ahead and safety wire your
clamps.
My $.02 worth
Rick Neilsen
Redrive VW Powered MKIIIC
PostPosted: Sun Aug 17, 2008 7:51 pm    Post subject: Hose Clamp Safety Wire Reply with quote
hose.
Rick Neilsen
Rick N:
This last 912ULS uses clampless oil fittings. Shove them on, after soaking
in boiling water, with a lot of effort. The blue oil line looks good and
will require a utility knife to remove when the time comes.
