Strut Fairings
Tommy Walker
PostPosted: Sun Aug 10, 2008 1:21 pm    Post subject: Strut Fairings Reply with quote
Builders,
I am looking for some dimensions for strut fairings for the 701. I have a little extra .016 sheet that gremlins drilled wrong while I was asleep. I would like to convert it into some fairings to cover the tubes.
I'm also interested in attachment points for the fairings.
Many thanks for any info.
Tommy Walker in Alabama
N8701
70.0 HRS
Tommy Walker
N25A - Anniston, AL
kmccune
PostPosted: Sun Aug 10, 2008 1:32 pm    Post subject: Re: Strut Fairings Reply with quote
Shocked Razz Very Happy
Darn, I have some of that too!
Sorry could not resist, I am interested in the answer though!
Kevin
R.W. Emerson (1803-1882)
Dorothy McCune
craig(at)craigandjean.com
PostPosted: Mon Aug 11, 2008 10:58 am    Post subject: Strut Fairings Reply with quote
Since no one has chimed in with a real answer I'll offer some hearsay: I
have read (on these lists) that a 3/1 length/width ratio in the cross
section's profile is the ideal.
The usual disclaimers: your millage may vary, offer null where void,
contents under pressure, keep away from children or politicians, rotate your
tires, don't stare into the sun, look both ways when crossing the freeway,
use in a well ventilated space, may contain peanuts or have been processed
on a planet that contains peanuts, this work is protected by international
copyright conventions.
-- Craig
zodierocket(at)hsfx.ca
PostPosted: Mon Aug 11, 2008 11:07 am    Post subject: Strut Fairings Reply with quote
3:1 ratio for best performance.
Mark Townsend Alma, Ontario
Zodiac 601XL C-GOXL, CH701 just started
www.ch601.org / www.ch701.com / www.Osprey2.com
jpspencer(at)cableone.net
PostPosted: Tue Aug 12, 2008 3:01 pm    Post subject: strut fairings Reply with quote
Tommy
I faired my struts with 016 as you are planning. Made a big difference. It was also a surprising amount of work(as usual), took several days off and on. I made a fixture for shaping the 016, it doesn't really like to bend in a proper leading edge radius, as I am sure you already know. I made them up in 4 foot "blanks" and then cut to fit. That put a joint about in the middle. I put one pop rivet at each end and the jury strut bolt holds it in the middle. The blanks were 8" wide before bending mostly because that works out for a 2x4 sheet of material and gets somewhere around the 3 to 1 ratio somebody mentioned but I wasn't too concerned about that.
You aren't too far from my place...I think this fixture might fit in a 701 if you want to come borrow it. It took a little while to build it.
Joe
Curt.Thompson(at)verizon.
PostPosted: Tue Aug 12, 2008 7:19 pm    Post subject: strut fairings Reply with quote
Anyone have any opinions on using 4130 streamline wing-strut tubing?
Curt
Redmond, WA, USA
graeme(at)coletoolcentre.
PostPosted: Tue Aug 12, 2008 8:21 pm    Post subject: strut fairings Reply with quote
A few scratch built CH 701 in Australia use streamline Alloy as used on the Lightwing seems to work well.
I will be using same when I get to that stage. (approx 3inch wide)
Graemecns
n801bh(at)netzero.com
PostPosted: Tue Aug 12, 2008 8:51 pm    Post subject: strut fairings Reply with quote
These guys advertise streamline stuff. look pretty promising...
http://www.ultralightnews.ca/streamlinedfairings/1.html
Ben Haas
N801BH
www.haaspowerair.com
-- "Curt Thompson" <Curt.Thompson(at)verizon.net> wrote:
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Curt
<?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com:office:smarttags" />Redmond, WA, USA
1-List">http://www.matronics.com/Navigator?Zenith701801-List
tronics.com
www.matronics.com/contribution
____________________________________________________________
[url=_blank]Compete with the big boys. Click here to find products to benefit your business.[/url]
SABorns(at)aol.com
PostPosted: Wed Aug 13, 2008 4:18 am    Post subject: strut fairings Reply with quote
Works great, but have you checked the price? It's out of sight.
Steven Bornstein
475 E. North Broadway
Columbus, Ohio 43214
614 263-5819
In a message dated 8/12/2008 11:20:10 P.M. Eastern Daylight Time, Curt.Thompson(at)verizon.net writes:
Curt
Redmond, WA, USA
st href="http://www.matronics.com/Navigator?Zenith701801-List">http://www.matronics.com/Navigator?Zenith701801-List
.matronics.com/">http://forums.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
Looking for a car that's sporty, fun and fits in your budget? Read reviews on AOL Autos.
Tommy Walker
PostPosted: Wed Aug 13, 2008 5:21 am    Post subject: strut fairings Reply with quote
Thanks Joe, I will take you up on that. It looks like it will be this fall before I get to that part of building this second plane.
Tommy
[quote]“…You aren't too far from my place...I think this fixture might fit in a 701 if you want to come borrow it. It took a little while to build it.”[b]
Tommy Walker
N25A - Anniston, AL
PostPosted: Wed Aug 13, 2008 5:50 am    Post subject: strut fairings Reply with quote
>Anyone have any opinions on using 4130 streamline >wing-strut tubing?
Curt
There are a lot of old Cub struts around that were removed and replaced with the lifetime no AD ones that might be a good source of streamline material if you are into scrounging and you are a welder and can allso determine to your satisfaction that they are strong enough ... I had a set I was gonna fab up some struts with but they were so rusty I didn't. The cross section isn't 3 to 1 but I thought it would be ok for me anyway. They are often cheap as in near free.
Joe
PostPosted: Wed Aug 13, 2008 6:46 am    Post subject: strut fairings Reply with quote
Steven,
Out of sight in deed! What I have found so far is about 10 times the cost of chromalloy tube. It appears that they are hard to manufacture and are prone to cracking.
Curt
Plans building CH701.
From: owner-zenith701801-list-server(at)matronics.com [mailto:owner-zenith701801-list-server(at)matronics.com] On Behalf Of SABorns(at)aol.com
Sent: Wednesday, August 13, 2008 5:18 AM
To: zenith701801-list(at)matronics.com
Subject: Re: Zenith701801-List: strut fairings
Steven Bornstein
614 263-5819
