Dash mounting bushings?
matronics(at)bob.brennan.
PostPosted: Mon Aug 11, 2008 1:59 pm    Post subject: Dash mounting bushings? Reply with quote
This should be an easy answer - the dash on my Kitfox II is held on by 4 shock-absorbing rubber thingies, 2 of which are pretty much shot. I need to order new ones from Aircraft Spruce, or whoever carries them, but I don't know what they are called. Searching for "dashboard shock-absorbing rubber mounting thingies" doesn't work Wink
I have attached a section of borrowed image from a previous list posting, hopefully the original poster won't mind but it's a perfect shot. The "thingie" is in the center.
Thanks in advance,
Bob Brennan
1991 UK Model 2 Kitfox
Rotax 582 with 3 blade prop
Wrightsville Pa
 Filesize:  73.53 KB
 Viewed:  418 Time(s)
jdmcbean(at)kitfoxaircraf
PostPosted: Mon Aug 11, 2008 2:21 pm    Post subject: Dash mounting bushings? Reply with quote
Give a shout.. we have them..
97006 is our part number…
Fly Safe !!
John & Debra McBean
Ph 208.337.5111
www.kitfoxaircraft.com
"The Sky is not the Limit... It's a Playground"
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Bob Brennan
Sent: Monday, August 11, 2008 3:58 PM
Subject: Dash mounting bushings?
Thanks in advance,
Bob Brennan
Wrightsville Pa
Lynn Matteson
PostPosted: Mon Aug 11, 2008 2:54 pm    Post subject: Dash mounting bushings? Reply with quote
They're called Lord mounts....Lord knows why. Sorry...I couldn't
resist...
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
Status: "Condition grounded, but determined to try." (Pink
Floyd..."Learning to Fly")
Fly Safe !!
John & Debra McBean
Ph 208.337.5111
Thanks in advance,
Bob Brennan
Wrightsville Pa
http://www.matronics.com/Navigator?Kitfox-List_-
============================================================ _-
forums.matronics.com_-
contribution_-
Lynn
Kitfox IV-Jabiru 2200
N369LM
PostPosted: Mon Aug 11, 2008 3:36 pm    Post subject: Dash mounting bushings? Reply with quote
Lordy! They are indeed. Now why didn't I know that!? It's such an obvious
name...
I could think of many other parts of the airplane that would be more
appropriately named Lord Mounts, 'cause their failure could make a meeting
with the Lord sooner than one may have wanted. But not *panel* mounts!
Thanks Lynn
MichaelGibbs(at)cox.net
PostPosted: Mon Aug 11, 2008 8:51 pm    Post subject: Dash mounting bushings? Reply with quote
Bob sez:
Nah, those are called "Jesus bolts", like those two big ones that
hold the lift struts to the fuselage. Helicopters have them, too...
Mike G.
N728KF, Kitfox IV-1200 Speedster
Phoenix, AZ
Michel
PostPosted: Mon Aug 11, 2008 10:11 pm    Post subject: Dash mounting bushings? Reply with quote
.. is that what they are called, Mike? Gosh! I remember when I started flying my Kitfox that I looked at those with respect and awe. Now I nearly ignore them in my preflight. ... have I lost faith? Smile
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200 ... grounded
PostPosted: Mon Aug 11, 2008 11:00 pm    Post subject: Dash mounting bushings? Reply with quote
I had sed:
> Nah, those are called "Jesus bolts"...
To which Michel sez:
...Now I nearly ignore them in my preflight. ... have I lost faith? Smile
I hope not, Michel. You were too close for comfort recently!
Mike G.
Phoenix, AZ
Lynn Matteson
PostPosted: Tue Aug 12, 2008 5:44 am    Post subject: Dash mounting bushings? Reply with quote
As you observed, some of the engine mounts are Lord Mounts, and if
these let go (unlikely) the "big meeting" just might be on your agenda.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
On Aug 11, 2008, at 7:35 PM, Bob Brennan wrote:
<matronics(at)bob.brennan.name>
obvious
name...
meeting
Thanks Lynn
Lynn
N369LM
