RE: Ampreg 20
ami(at)mcfadyean.freeserv
PostPosted: Sat Jan 07, 2006 10:23 am    Post subject: RE: Ampreg 20 Reply with quote
Don't make the floating lids from polystyrene foam (eg blue foam), because
it will dissolve!
Duncan McF
europaflyer_3(at)msn.com
PostPosted: Sat Jan 07, 2006 12:52 pm    Post subject: RE: Ampreg 20 Reply with quote
Martin,
Glad to hear that was useful. Martin is a top guy.
Just a quick tip to be careful putting water through a resin pump. The mild
steel springs will rust in no time, and getting water out of the chambers
will be near impossible (you'll end up disassembling it to get all the water
out).
Don't ask how I know - all I'll say it is wasn't me...
Kind regards,
Jeremy
Jeremy Davey
Europa Monowheel 537M G-EZZA
Europa Club Vice-Chairman, Webmaster, PFA NC Representative
PFA EC Member
"If you can keep your head when all about you are losing theirs, then it is
possible you haven't grasped the severity of the situation."
Tail done
Standard XS wings with mods underway
CM installed in fuse (with airbrakes fittings)
1430 build hours to date, build currently stalled due to house moves and
lack of workshop
Intended fit:
Rotax 914 turbo, Airmaster CS fully-feathering prop
Lots of lights, buttons, switches, gizmos, and alarms
rowil(at)clara.net
PostPosted: Sun Jan 08, 2006 11:29 am    Post subject: RE: Ampreg 20 Reply with quote
At 2006-01-07 07:27 -0800 Flying Farmer wrote:
The solution was to wash out with soapy water
Richard - either your water or your soap must be different to what I
can get in Cheltenham - despite advice from SP that each component of
SP20 is water-soluble before thay meet up with each other, I have
never managed to clean off either resin or hardener completely
satisfactorily with anything less than acetone.
My second-hand pump was squirting out brown stuff when I first tried
it, despite the input liquids being clean cleaning out the
rust in the pump innards solved that (after emptying the reservoirs -
a glass turkey baster is the answer here!).
Beats me why they don't make the metal bits out of stainless instead
of mild steel - after all they charge enough for it ...
regards
Rowland
| Rowland Carson PFA #16532 <http://home.clara.net/rowil/aviation/>
| 750 hours building Europa #435 G-ROWI e-mail <rowil(at)clara.net>
