rlaird
Posted: Fri Aug 08, 2008 4:20 pm Post subject: Can you identify this fabric? |
Could someone please take a look at the attached image and tell me what weight of Poly-Fiber fabric this is? Thanks!
-- Robert
| Description: |
| Filesize: |
203.99 KB |
| Viewed: |
309 Time(s) |
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
Posted: Fri Aug 08, 2008 4:35 pm Post subject: Can you identify this fabric? |
Robert L:
D-104 is 1.6 oz. It is stamped on the fabric in your photo. That is what
we covered the wings and tail with some years ago.
I used D-103, 3.6? oz for the fuselage of my FS, 1986.
_________________ John Hauck
Titus, Alabama |
rlaird
Posted: Fri Aug 08, 2008 4:46 pm Post subject: Can you identify this fabric? |
Thanks, John. If I were to patch my wing (upper surface) should I use the same 1.6 oz fabric, or go up to the medium?
-- Robert
On Fri, Aug 8, 2008 at 7:33 PM, John Hauck <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:
[quote]--> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)>
Robert L:
D-104 is 1.6 oz. It is stamped on the fabric in your photo. That is what we covered the wings and tail with some years ago.
Robert Laird
Houston, TX area
Posted: Fri Aug 08, 2008 4:52 pm Post subject: Can you identify this fabric? |
Robert L:
Probably would not matter much.
The weave of 1.6 is much finer than the heavier fabric. Correct me if I am wrong, but that would be the biggest difference when doped and painted.
How big is the hole? If small, I'd stick a "sticker" on it. My mkIII is held together with stickers.
-- Robert
Titus, Alabama |
