larry huntley
Posted: Sat Aug 09, 2008 10:28 am Post subject: 91 octane, time to be heard! Ethanol testing |
984 K Road
Minden, Nebraska 68959
3O8/832-22OO
Send email to Petersen Aviation (todd(at)gtmc.net)
Testing fuel for ethanol
The following test can be performed to determine the presence of ethanol in gasoline.
On a test tube or olive bottle, make a permanent line about two inches from the bottom.
Fill with water to this line, then fill the tube to the top with gasoline.
Cover the tube, agitate it then let it stand.
Ethanol mixes with water and the two will separate out together. Therefore, after mixing the water and the gasoline, if the water level appears to have increased, then the fuel contains ethanol and should not be used.
Ethanol fuels can damage the rubber and aluminum components of your aircraft fuel system. Ethanol increases the volatility of fuel, and hence the possibility of vapor lock also increases. Ethanol may vent off at altitude, reducing both range and octane. For these reasons fuel containing ethanol must never be used in airplanes.
We offer a ready made ethanol tester for $15.00.
| Table of Contents |
Animations courtesy of "Free Gifs & Animations"
3.25 KB |
1934 Time(s) |
4.62 KB |
1935 Time(s) |
_________________ Larry Huntley,Dundee,NY
Kitfox 4-1200 N234EE
EA81,AMAX Redrive Warp 3 blade |
