My First Ground Loop
Goto page 1, 2  Next
rawheels
PostPosted: Wed Aug 06, 2008 3:46 am    Post subject: My First Ground Loop Reply with quote
Went up last night for what was supposed to be my last lesson before getting my tailwheel endorsement. Went over to do some hard surface work, and the first two landings were squirrelly. Third landing the aircraft just darted left, with full right brake and rudder nothing would stop it. Right flaperon touched the ground and the tailwheel is cocked to the left. CFI thinks the bolt on the tail wheel broke and that is what caused it to shoot left, but I'm not sure. Landing on pavement the aircraft was really grabby. It will take some convincing before I want to go on pavement again. Need a 12 step program; loppers anonymous.
Ryan Wheeler
Kitfox IV-1200
Sbennett3(at)aol.com
PostPosted: Wed Aug 06, 2008 4:02 am    Post subject: My First Ground Loop Reply with quote
Ryan, Same thing happened to me last September. Dont feel alone here it happens to even the veterans. I put a piece of red electrical tape on the top of the panel to mark my strait line. It really helped. You need to make ALL your landings on hard surface. Then the grass is just easy landing Smile It gets better as you start to feel the airplane more. I promise. Steve Bennett 4 classic 912
In a message dated 8/6/2008 7:48:38 A.M. Eastern Daylight Time, rawheels(at)yahoo.com writes:
--> Kitfox-List message posted by: "rawheels" <rawheels(at)yahoo.com>
Ryan Wheeler
Kitfox IV-1200
http://forums.matronics.com/viewtopic.php?p=196853#196853
Looking for a car that's sporty, fun and fits in your budget? Read reviews on AOL Autos.
Michel
PostPosted: Wed Aug 06, 2008 4:37 am    Post subject: My First Ground Loop Reply with quote
Ryan, the only time I did a ground loop was when I broke my tailwheel spring. I thought first that the ground loop broke the spring but it was the opposite: the lost of tail control was the reason I went in the ground loop.
I hope you can fix your tailwheel and flaperon and are soon back in the air.
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200 ... grounded.
lcfitt(at)sbcglobal.net
PostPosted: Wed Aug 06, 2008 6:18 am    Post subject: My First Ground Loop Reply with quote
Ryan,
I have to ask the question, do you have the original tube gear or have you
changed out to the Grove. The reason I ask is when I was jigging up to make
the taller wider tube gear with compression spring struts, I used the old
gear as a starter to make the jigs. These came from the factory seriously
toed in. It was visually obvious possibly up to a couple of degrees. I
would expect, since these were all made from the same jiggs, that every set
was toed in. I think this is a major cause for much of the ground handling
problems with the early gear. My first Model IV was toed in. I caught it
before first flight because in the then published Kitfox Times and article
explained how to check and correct it. That airplane was very docile on the
ground.
Maybe this is the difference between the grass and pavement experiences that
many have described as grass would not grab the toed in gear and pavement
makes for the big surprise.
The tape on the windsheild is a great help. I had it on mine, but check the
gear alignment and see if that is what is causing the need for such extreme
vigilance.
Lowell
PostPosted: Wed Aug 06, 2008 6:28 am    Post subject: My First Ground Loop Reply with quote
Another thing I was told makes our birds squirrely... Too much air in the tires. Assuming you have the golf cart/atv style tire, The air pressure should only be 7 to 10 lbs.
Steve Bennett
In a message dated 8/6/2008 10:19:26 A.M. Eastern Daylight Time, lcfitt(at)sbcglobal.net writes:
--> Kitfox-List message posted by: "Lowell Fitt" <lcfitt(at)sbcglobal.net>
Ryan,
ground.
vigilance.
Lowell
----- Original Message -----
Sent: Wednesday, August 06, 2008 4:46 AM
Subject: My First Ground Loop
Ryan Wheeler
Kitfox IV-1200
he es y --> - MATRONICS WEB FORUMS nbsp; - List Contribution Web Site ;   =========================
rawheels
PostPosted: Wed Aug 06, 2008 7:06 am    Post subject: Re: My First Ground Loop Reply with quote
Thanks for the responses:
TAPE: How do you align the tape; just set up on the runway and lay it down?
GEAR: Yeah, regular tube gear. I saw the grove gear on the units up at Oshkosh. Looks really nice, but out of the price range right now. I'll have to see if I have the alignment instructions, and check out my set-up.
TIRES: I'm not sure if they are original or not. They are pretty small. Max Press is like 25 lbs, and I have them filled to around 20 psi. Can 7-10 be right?
Ryan Wheeler
Kitfox IV-1200
Indianapolis, IN
Tom Jones
PostPosted: Wed Aug 06, 2008 7:32 am    Post subject: Re: My First Ground Loop Reply with quote
Ryan hopefully the damage is minimal. from your description it sounds like it is.
Like Lowel's, my tube gear was seriously toed in when first installed. the suggested fix is to cold bend the gear with a six foot cheater pipe over the axle. I didn't like the stress this would put on the gear and fuselage so I took the axles out and cold bent them in a vise with light taps of a sledge hammer.
The wheel alignment is now straight ahead with fuselage level (tail up). It is easy for me to keep straight now.
For what its worth about "Walking the rudder" in a kitfox. If I try that like I did in the Stinson or Cub things get out of control in a hurry.
On take off I anticipate and add some light left rudder (left hand prop) when throttle is applied then a little light left rudder pressure when the tail comes up. Thats about all.
On landings I just add rudder as needed. If there's no cross wind and the touch down is aligned straight with the runway I don't need to add any rudder at all until the runway exit.
Tom Jones
Classic IV
Ellensburg, WA
Tom Jones
PostPosted: Wed Aug 06, 2008 7:41 am    Post subject: Re: My First Ground Loop Reply with quote
Ryan,
I just reread this thread and can tell by your questions you have not read the book "How to Fly a Kitfox".
This book was a big help for me. It has been rewritten as "kitfox Pilot's Guide". My opinion is this is a must have must read for kitfox owner/pilots. I think it is still available from http://www.kitfoxaircraft.com/
Tom Jones
Classic IV
Ellensburg, WA
PostPosted: Wed Aug 06, 2008 7:41 am    Post subject: My First Ground Loop Reply with quote
Ryan,
To align the tape, line up your airplane with a distant object - for me here
it is a tree on the hill - by sighting from the rear across the vertical
stabilizer and a vertical prop blade. Then get in the airplane, wiggle a
bit to find your flying position and place some narrow - the 1/8" masking
tape works great - on the windsheild aligned with the distant object. I
found that the tape helped a bunch when landing with a substantial cross
wind once on a must do landing late one evening in a cross country.
Lowell
Guy Buchanan
PostPosted: Wed Aug 06, 2008 7:52 am    Post subject: My First Ground Loop Reply with quote
Not at all, you've just joined the ranks of those who have,
leaving the ranks of those who will. (I have, albeit slowly, and
without damage. My right foot got stuck on the brake and around we
went. I was practicing stop and goes with the tail up.) Now that
you've gotten that out of the way you can go forward without worry.
(Though I'd check the toe to be sure, and second Lowell's suggestion
of putting a "gunsight" on the windshield. I added a horizon line for
3-pointers, as well.)
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
rawheels
PostPosted: Wed Aug 06, 2008 8:31 am    Post subject: Re: My First Ground Loop Reply with quote
Tom,
You are right, I've not read that. I purchased the aircraft a few weeks before Oshkosh, so I have very limited experience with the aircraft. I don't see an online store, but I'll e-mail the McBeans about it.
Some damage to the plane, but I don't think I'll be rebuilding a wing or anything. The wing and flaperon looked and felt solid and straight. There is a rip in the wing fabric and I think I noticed some damage to the right side of the turtle back. So, Ill need to look into that further. The big noticeable item is the tail wheel. I'll have to bend the horizontal tabs back in place and then try to get it realigned before replacing the three bolts with new. Guess it could be worse, but definitely not fun.
Ryan
Guy Buchanan
PostPosted: Wed Aug 06, 2008 8:33 am    Post subject: My First Ground Loop Reply with quote
Set up on a taxi-way or runway. Get comfortable and focus at
infinity. Closing each eye, make a mark on the windshield where
runway centerline is. (Use a water soluble marker.) When you get done
you should have two marks about 2" apart. Put the tape vertically
midway in between these marks. When you land and focus on the far end
of the runway the vertical tape should bifurcate into two, offering a
"gun sight" in which you center the runway centerline. The poor man's
heads-up-display! (This may require some iteration.)
Go for Lowell's gear. I hear he's given' em away. Wink
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
peteohms
PostPosted: Wed Aug 06, 2008 8:37 am    Post subject: My First Ground Loop Reply with quote
Ryan,
I wouldn't loose any sleep over the ground loop. Now you have it out of
your system. I did the same thing in my Kitfox III with about 7 hours under
my belt and my 6th landing. A slight gust caught me off guard on a landing
while I was patting myself on the back for my smoothest touchdown ever. I
think Grove gear saved me. My right wing came within 2' of the ground. I
ran off the runway at 5t6 and had half of a complete circle when I got
control. I completed the loop and got back on the runway and announced on
the radio "Kitfox 73BH has arrived". Both of my flying instructors were at
the field that day. I now do not loose my focus on landing until I come to
a complete stop.
I had tailwheel steering break on me on a KR2 once and I ended up running
off the runway because of that.
Pete
Hell Paso, TX
Pete
Leander, TX
Kitfox III, 912ul, Grove
malpass
PostPosted: Wed Aug 06, 2008 9:09 am    Post subject: My First Ground Loop Reply with quote
20 PSI WILL MAKE YOU SQUIRREL ALL OVER THE RUNWAY !! 9 POUNDS IS GOOD.
kitfox III w/ 582 greyhead
Lynn Matteson
PostPosted: Wed Aug 06, 2008 9:42 am    Post subject: My First Ground Loop Reply with quote
Cheer up, Ryan....my attempt to teach myself to taxi ended up like
this, a week before my DAR visit...all was repairable, and it came
out looking pretty good. It wasn't a ground loop, but a side gust and
a dumb rookie who shouldn't have been doing what I was doing...going
too fast and trying to see if the tail was up (it was) and then
pulling back and probably some to the left, too.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
Status: "Condition grounded, but determined to try." (Pink
Floyd..."Learning to Fly")
Ryan
http://forums.matronics.com/viewtopic.php?p=196925#196925
 Filesize:  151.64 KB
 Viewed:  542 Time(s)
 Filesize:  122.74 KB
 Viewed:  540 Time(s)
Lynn
Kitfox IV-Jabiru 2200
N369LM
n85ae
PostPosted: Wed Aug 06, 2008 11:48 am    Post subject: Re: My First Ground Loop Reply with quote
Cheer up, when I did my ground loop I did it at Prime time Saturday
afternoon right in front of the airport restaurant which was packed
and busy.
real nice tire smoking 270 degree turn right off into the grass. Loud
enough tire noise from the 8.50's to hear clearly from about a mile
away.
The unicom operator came up "N85AE are you ok?", I replied "I'm
fine but I probably need a change of undershorts ..."
Jeff
msm_9949(at)yahoo.com
PostPosted: Wed Aug 06, 2008 11:50 am    Post subject: My First Ground Loop Reply with quote
That's attractive, Lynn. I especially admire the sporty effect of those grass-like streamers. Wink
But seriously Ryan, if you fly tailwheel long enough you will groundloop. I got mine out of the way early too and it had nothing to do with the airplane. I do concur with those who have recommended checking excessive tire pressure and/or toe-in on the tube gear. Either condition can contribute to "squirreliness" on pavement.
Good luck and keep those feet a-moving.
--- On Wed, 8/6/08, Lynn Matteson <lynnmatt(at)jps.net> wrote:
Subject: Re: Re: My First Ground Loop
Date: Wednesday, August 6, 2008, 1:39 PM
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
Ryan
Ken Potter
PostPosted: Wed Aug 06, 2008 3:02 pm    Post subject: Re: My First Ground Loop Reply with quote
As one our old investigators here at the TSB Canada says, "there are two types of tail-dragger pilots; those who have ground looped, and those who will!
Im still awaiting my turn and humbly accept my fate.
Cheers
Ken Potter
Kitfox II No. 483
Rotax 583, C Box,
98% finished
kitfoxpilot(at)msn.com
PostPosted: Wed Aug 06, 2008 3:54 pm    Post subject: My First Ground Loop Reply with quote
Not that this is what happened to you! but if you have not lined the fox up on the runway you will go hard to the left or right!! hard surface is not a problem C just have to have happy feet on the rudder and make sure your goiung straight.
Ray> Subject: My First Ground Loop> From: rawheels(at)yahoo.com> Date: Wed C 6 Aug 2008 04:46:45 -0700> To: kitfox-list(at)matronics.com> >
Get Windows Live and get whatever you need C wherever you are. Start here
gary.algate(at)sandvik.co
PostPosted: Wed Aug 06, 2008 5:13 pm    Post subject: My First Ground Loop Reply with quote
Ryan
I have about 750 hrs now on Kitfox's and I can still remember my first few landings on Tarmac - at the time I had lot's of tricycle time and of course I was a "highly experienced" 1/3rd scale RC modeller (specifically tail wheel) so I assumed it would be a breeze! Talk about wrong on all counts.
My tailwheel training was given to me by the local Kitfox sales guy and all he wanted to do was get me off his hands so when he signed me off I still couldn't make a straight line up the runway and usually ended up horsing it of the ground just to put an end to the torture.
This all sounds pretty dramatic but for the life of me I couldn't get it right - (Same for landing)
Then an experienced Kitfox pilot went with me and immediately solved my problems - I was aligning the tapered sides of the Kitfox nose with the centre-line of the run way so in effect, on take off and landing I was trying to slip the plane in a crabbed position. As soon as he pointed this out I put a small piece of tape on the windscreen that aligned with the runway centre-line in my normal seating position. After about a dozen landings I threw the tape away.
Since then I've never had a problem - I even landed at the Sudbury airport with a completely flat tire and kept her straight until almost stopped (No ground loop)
Hope this helps
Gary
Gary Algate
SMC, Exploration
Office Phone: +61 8 8276 7655
This e-mail is confidential and it is intended only for the addressees. Any review, dissemination, distribution, or copying of this message by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error, kindly notify us immediately by telephone or e-mail and delete the message from your system. The sender does not accept liability for any errors or omissions in the contents of this message which may arise as a result of the e-mail transmission.
Sent by: owner-kitfox-list-server(at)matronics.com
07/08/2008 12:46 AM
Please respond to
kitfox-list(at)matronics.com To
kitfox-list(at)matronics.com cc
Subject
Ryan Wheeler
Kitfox IV-1200
Indianapolis, IN
http://forums.matronics.com/viewtopic.php?p=196901#196901
Goto page 1, 2  Next
Page 1 of 2
