pascal(at)rv10builder.net Guest
Posted: Tue Aug 05, 2008 1:33 pm Post subject: The rear bulkhead SB |
Maybe this is the plane Nasa used for Oregon aero's High G seating ?? etc.. [img]cid:40E467A231EB4212BCD2EE08A3A7E407(at)pascaldell[/img]
Seat Cushion Testing:
Cushions Pass Full Scale 19G Lumbar Load Test
FULL SCALE, REAL TIME TEST — While a highly modified seat with Oregon Aero cushions was used in the pictured test conducted at NASA a few years ago — and the Oregon Aero cushions passed the test — Oregon Aero is developing a complete seat (frame, pan and cushions, with and without legs) that will pass this test and be comfortable, reliable and affordable.
Pascal
Sent: Tuesday, August 05, 2008 1:06 PM
Subject: Re: Re: Asymmetrical trim noted at OSH
Does anyone know which plane was used for spin testing of the RV-10?
I would not be surprised if it was the green and white one and that is where the cracks originated from.
The loading that a couple of rotations in a spin could be an issue though.
I was just curious. With only one plane with the issue makes me wonder what type of loading that plane has seen that no one else has seen.
Scott Schmidtscottmschmidt(at)yahoo.com
----- Original Message ----
Sent: Tuesday, August 5, 2008 1:28:44 PM
Subject: Re: Asymmetrical trim noted at OSH
title="http://www.matronics.com/Navigator?RV10-List
CTRL + Click to follow link" href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
| Description: |
| Filesize: |
1.31 KB |
| Viewed: |
1215 Time(s) |
| Description: |
| Filesize: |
13.49 KB |
| Viewed: |
245 Time(s) |
| Description: |
| Filesize: |
12.59 KB |
| Viewed: |
233 Time(s) |
| Description: |
| Filesize: |
13.3 KB |
| Viewed: |
235 Time(s) |
| Description: |
| Filesize: |
11.42 KB |
| Viewed: |
228 Time(s) |
| Description: |
| Filesize: |
13.93 KB |
| Viewed: |
242 Time(s) |
scottmschmidt(at)yahoo.co Guest
Posted: Tue Aug 05, 2008 2:23 pm Post subject: The rear bulkhead SB |
No wonder the bulkhead cracked!
| Description: |
| Filesize: |
1.31 KB |
| Viewed: |
1214 Time(s) |
