Clem Nichols
Joined: 10 Jan 2006 Posts: 88 Location: Munfordville, Ky
Posted: Fri Aug 01, 2008 10:10 am Post subject: Alternator for NSI EA81 |
I've a buddy who needs a replacement alternator in his NSI EA81 powered Kitfox. The data plate is missing from his, and the owners manual says it's a Nippon Denso 38 amp alternator with a built in voltage regulator. Googling for this particular model has not produced any satisfactory results. Any help will be appreciated.
CN
pwmac(at)sisna.com Guest
Posted: Fri Aug 01, 2008 10:54 am Post subject: Alternator for NSI EA81 |
Suspected that it has a heritage from a Geo Metro of the earlier days. Pretty popular for many homebuilts.
Ask the aeroelectric list.
Paul
At 12:07 PM 8/1/2008, you wrote:
[quote]I've a buddy who needs a replacement alternator in his NSI EA81 powered Kitfox. The data plate is missing from his, and the owners manual says it's a Nippon Denso 38 amp alternator with a built in voltage regulator. Googling for this particular model has not produced any satisfactory results. Any help will be appreciated.
CN
Fox5flyer Guest
Posted: Fri Aug 01, 2008 12:18 pm Post subject: Alternator for NSI EA81 |
That is a very ubiquitous alternator, but I believe mine is a 50amp. Try googling the 50amp nippon and see what you get. Also, try a Subaru Brat 84-86 vintage.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 385+ TT
- Joseph Joubert
Clem Nichols
Posted: Fri Aug 01, 2008 1:52 pm Post subject: Alternator for NSI EA81 |
Thanks for your response. This should at least point him in the right direction. Interestingly, one place in the owners manual says it's a 38 amp unit, and another place a few pages later describes it as a 50 amp unit.
CN
wingsdown(at)verizon.net Guest
Posted: Fri Aug 01, 2008 3:22 pm Post subject: Alternator for NSI EA81 |
Have him take it to Kragen or similar auto parts store for a rebuild exchange, and with a life time warranty. Remove the pulley first. Don't tell them its for a plane. Dune buggy works well.
Rick
clint_bazzill(at)hotmail. Guest
Posted: Fri Aug 01, 2008 4:41 pm Post subject: Alternator for NSI EA81 |
I have a very small alternator. The one that is used on the 912 series engines. It's brand new C contact me off line.
Clint
Date: Fri C 1 Aug 2008 16:18:17 -0700
Subject: RE: Alternator for NSI EA81
Have him take it to Kragen or similar auto parts store for a rebuild exchange C and with a life time warranty. Remove the pulley first. Don't tell them its for a plane. Dune buggy works well.
Rick
Posted: Sat Aug 02, 2008 9:19 am Post subject: Alternator for NSI EA81 |
Here are a couple pictures. Neat alternator.
Clint
Subject: Re: Alternator for NSI EA81
Date: Fri C 1 Aug 2008 16:49:20 -0500
Thanks for your response. This should at least point him in the right direction. Interestingly C one place in the owners manual says it's a 38 amp unit C and another place a few pages later describes it as a 50 amp unit.
CN
76.61 KB |
560 Time(s) |
86.47 KB |
594 Time(s) |
Clem Nichols
Posted: Sat Aug 02, 2008 10:53 am Post subject: Alternator for NSI EA81 |
Certainly a nice size, no question about that. The most obvious problem I see is that the alternator and water pump on the Subaru are run by two belts which obviously requires a double pulley, and the shaft on your alternator doesn't stick out far enough to accomodate a double pulley. Thanks anyway.
Clem Nichols
