*****SPAM***** Re: Chris Heintz letter
dwilde(at)clearwire.net
PostPosted: Sat Jul 26, 2008 9:08 am    Post subject: *****SPAM***** Re: Chris Heintz letter Reply with quote
Gordon wrote:
I found that I needed to slacken the elevator cables in order to
eliminate the tendency for the control stick to constantly push to the
left. The cables are just snug and I'm sure much less than: Elevator
tension should be about 40 lbs +/- 5
Has anybody else encountered this effect, or do I have something
rigged improperly?
Gordon
CH701 912ULS 25hrs
I have done the same thing as you have on my 701. It appears to be a
common problem. If there is a better solution, I sure am open to it.
Dan Wilde
stepinwolf
PostPosted: Sat Jul 26, 2008 1:42 pm    Post subject: Re: *****SPAM***** Re: Chris Heintz letter Reply with quote
I'm not sure this solution is appropriate , but a few of my friends who own 701's, have encountered the same problem. I was told that they solved the issue, by removing the two triangler shaped plates that hold the horizontal tail bellcrank at the rear of the torque tube, and re-installed the plates right next to the tube, on it's own, home made metal bracket, no longer being an integral part of the tube.
Now the pressure is equal on both sides, and not only can they tighten to the correct tension on the cables, but the stick is also neutral when it's moved back and forth, with no unequal pressure on either side.
Hope this helps
Bob, the 701 scratch
Three Rivers
# 7-7143
Long wing + vga's, = lo & slo
stepinwolf
PostPosted: Sun Aug 31, 2008 5:43 am    Post subject: Re: *****SPAM***** Re: Chris Heintz letter Reply with quote
I was asked a little while back to post a few pic's of the modification, so here they are.
In the second photo, ( rod1 ) you can clearly see that the triangular plates were removed from the tube, and relocated to a reinforcement channel, over the original tube, thereby eliminating any interference between the two control surfaces, when either is moved.
Hope this helps
Bob the 701 & 750 Scratch
Three Rivers, Quebec.
 Filesize:  118.86 KB
 Viewed:  518 Time(s)
 Filesize:  118.83 KB
 Viewed:  518 Time(s)
