Annual Air Frame Inspection
hgmckay
PostPosted: Sat Jul 26, 2008 4:13 am    Post subject: Annual Air Frame Inspection Reply with quote
It is time for me to conduct the annual airframe check/inspection on my
Allegro 2000 ELSA. The only check list I have for the Allegro 2000 is a 7
page, Check and Maintenance Manual V1.0, copyright X-Air Australia 2004. I
don't believe this document was produced by the airplane manufacturer,
Fantasy Air, so I don't know if it is the correct one to follow. The only
other document I have to follow is AC90-89A, Appendix1, dated 5/24/95. The
Australia document is undoubtedly specific to the Allegro, but much of the
language terminology seems to be "Australianeez", and a bit difficult (at
least for me) to figure out. What I am asking is, what check list are you
E-LSA guys using for your annual, or 100, 200, and 500 hour airframe
inspections?
Hugh McKay
Allegro 2000
N661WW
Rotax 912 UL
Roger Lee
PostPosted: Sat Jul 26, 2008 7:44 am    Post subject: Re: Annual Air Frame Inspection Reply with quote
Hi Hugh,
The Rotax "Line Maint. Manual" has their own check list. I tried to attach a Flight Design check list, but it didn't work. The FD check list is a very good inspection check list.
If you would post your email address I will try and send it through Yahoo.
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
hgmckay
PostPosted: Sat Jul 26, 2008 3:52 pm    Post subject: Annual Air Frame Inspection Reply with quote
Roger:
Many thanks! My email is hgmckay(at)bellsouth.net
Hugh
Thom Riddle
PostPosted: Sun Jul 27, 2008 2:20 am    Post subject: Re: Annual Air Frame Inspection Reply with quote
Hugh,
Attached is for Allegro 2000. I am pretty sure the Australian one is just a copy of this one from Fantasy Air. It is written in Czechlish.
Allegro Check-and-Maintenance-Manual.pdf
Allegro 2000 Check and Maintenance
 Filename:  Allegro Check-and-Maintenance-Manual.pdf
 Filesize:  315.32 KB
 Downloaded:  1494 Time(s)
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
