fltrbg(at)yahoo.com Guest
Posted: Fri Mar 10, 2006 7:12 pm Post subject: C-90 or 0-200 cam. |
Hello all,
I'm about to begin re-assembly of a C-90 and I have both the C-90 and 0-200 cams available.I'd like some advice as to which one to use.
Is it preferable to use the C-90 cam with a slightly higher pitch prop,or the 0-200 cam with less pitch prop to allow higher RPM.The plane that it will power has about 100 mph cruise and I'm trying to maximize short field performance.
Thanks in advance for any advice,
John Koning
C-FGCC
Stits Flut-r-bug.
| | - The Matronics Engines-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Engines-List |
jrccea(at)bellsouth.net Guest
Posted: Fri Mar 10, 2006 9:30 pm Post subject: C-90 or 0-200 cam. |
The 90 with a relatively flat pitch will give you better takeoff and climb
(you won't be able to reach maximum rater rpm with either engine or prop).
The 90 does better at lower rpm.
