Posted: Thu Jul 24, 2008 3:04 pm Post subject: Wanted Drilling/Bolting layout for the NEW type 6B6-4 |
I've attached the revised 6B6 dated 8/07 PDF that Caleb sent me.
-- Craig
6-B-6.pdf |
103.19 KB |
788 Time(s) |
Thruster87
Posted: Thu Jul 24, 2008 10:53 pm Post subject: Re: Wanted Drilling/Bolting layout for the NEW type 6B6-4 |
The numbers don't add up too well 14mm is OK then 56mm is OK but then the 40mm [total so far 110mm] lines up with the canopy tang which is 100mm from the end so a no no there,56mm instead of 40mm would work and then 40 or 56mm would be OK. What did you make yours ?Cheers T87
