Trimming 7F19-12
john.marzulli(at)gmail.co
PostPosted: Mon Jul 21, 2008 11:53 pm    Post subject: Trimming 7F19-12 Reply with quote
Can anyone post how they trimmed the door sill, specifically the rear inside?
The plans and manual are lacking.
I've got a picture of my best guess ( minus curving it to carry the stress ) here: http://bp2.blogger.com/_mhDbWUJRTOE/SIWO6T1qpPI/AAAAAAAAExs/8fdW6bGFYCE/s1600-h/IMG_8251.jpg
Thanks and DO NOT ARCHIVE,
John Marzulli
http://701Builder.blogspot.com/
http://www.GenevieveMarzulli.org/
http://www.JohnMarzulli.net/
rrsharp(at)cox.net
PostPosted: Tue Jul 22, 2008 12:01 pm    Post subject: Trimming 7F19-12 Reply with quote
This is the way I did mine. Drilled #30 pilot hole and cut slot using snips. The tricky part was fitting the forward end of sill around tubes. Took many fittings and trimmings to get it right.
Ralph
 Filesize:  41.32 KB
 Viewed:  467 Time(s)
 Filesize:  40.23 KB
 Viewed:  516 Time(s)
PostPosted: Tue Jul 22, 2008 12:32 pm    Post subject: Trimming 7F19-12 Reply with quote
Thanks Ralph!
That was exactly the sort of picture I was hoping for!
DO NOT ARCHIVE
John Marzulli
On Tue, Jul 22, 2008 at 12:59 PM, Ralph Sharp <rrsharp(at)cox.net (rrsharp(at)cox.net)> wrote:
[quote] This is the way I did mine. Drilled #30 pilot hole and cut slot using snips. The tricky part was fitting the forward end of sill around tubes. Took many fittings and trimmings to get it right.
Ralph
ruruny(at)aol.com
PostPosted: Tue Jul 22, 2008 12:55 pm    Post subject: Trimming 7F19-12 Reply with quote
John,
Click on link to door sill installation. Might help.
http://www.701builder.com/00fuselagehome.htm
BrianThe Famous, the Infamous, the Lame - in your browser. Get the TMZ Toolbar Now!
