wstucklen1(at)cox.net Guest
Posted: Sun Jul 20, 2008 12:08 pm Post subject: IO-360 with vertical sump |
Can any one tell me what they used for the throttle/mixture bracket and throttle/mixture cable lengths for an IO-360 with a vertical sump? I'm installing a TMX IO-360 with the experimental Precision fuel body. Relative to a Carburetor, the throttle & mixture positions are reversed. It looks like Van's Throttle/Mixture bracket is OK for the Throttle, but will require modifications for the Mixture side. Also, it looks like the cables have to be longer.
If anyone has pictures of this type of installation, and specifics on the bracket and cable lengths, it would be a great help...
Fred Stucklen
RV-7A N924RV (Hope to be flying by Labor Day!)
carl.froehlich(at)cox.net Guest
Posted: Sun Jul 20, 2008 3:14 pm Post subject: IO-360 with vertical sump |
I back fitted Airflow Performance fuel injection on RV-8A with a Van’s O-360-A1A. Both throttle and mixture required custom cable brackets, the mixture being the far harder of the two. For the 8A the gear leg interference is the problem.
I got a few lengths of 1x1 and 2x2 aluminum angle stock in 1/8” and 3/16” thicknesses. Each bracket required two pieces of angle cut just right to make the complex arm for where the control cable is secured. Once this is done, fabricate the small piece of angle with the terminating hole for the cable and bolt it to the now assembled arm. I trimmed the angle to clear interference as needed, and to eliminate unnecessary bulk.
I had a lot of scrap aluminum and aluminum dust when I got done with this painful evolution.
Carl Froehlich
RV-8A (450 hrs)
RV-10 (fuselage)
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Fred Stucklen
Sent: Sunday, July 20, 2008 4:04 PM
To: rv-list(at)matronics.com
Subject: IO-360 with vertical sump
Fred Stucklen
Terry Watson
Joined: 09 Jan 2006 Posts: 290 Location: Seattle, WA USA
Posted: Sun Jul 20, 2008 4:54 pm Post subject: IO-360 with vertical sump |
I have a series of detail photos of the bracket I made for my RV-8A with a Superior IO-360A1B with Airflow Performance fuel injection. As Carl says, it took a lot of aluminum to come up with just the right combination that would work. It’s been awhile so I don’t remember the details, but I can send the photos or post them to a website if that would help.
Terry
RV-8A #80729
Stalled in the shop
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Carl Froehlich
Sent: Sunday, July 20, 2008 4:10 PM
Subject: RE: IO-360 with vertical sump
Carl Froehlich
RV-8A (450 hrs)
RV-10 (fuselage)
Fred Stucklen
Bret Smith
Joined: 09 Jan 2006 Posts: 178 Location: Mineral Bluff, GA
Posted: Sun Jul 20, 2008 5:45 pm Post subject: IO-360 with vertical sump |
Terry, I would like to see any photos you have. I am installing (actually, trying to figure out how) the AFP FI on my IO-360.
Bret Smith
RV-9A N16BL
Blue Ridge, Ga
www.FlightInnovations.com
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Terry Watson
Sent: Sunday, July 20, 2008 8:49 PM
Terry
RV-8A #80729
Stalled in the shop
Carl Froehlich
RV-8A (450 hrs)
RV-10 (fuselage)
Fred Stucklen
_________________ Bret Smith
RV-9A (Emp) |
Dick Sipp
Posted: Sun Jul 20, 2008 6:50 pm Post subject: IO-360 with vertical sump |
Email Don at AFP or give him a call. I believe he has a photo library of installation examples.
Dick Sipp
RV10 N110DV
Terry Watson
Posted: Sun Jul 20, 2008 7:29 pm Post subject: IO-360 with vertical sump |
I posted the pictures on this website: tcwatson.zenfolio.com. Look for the RV-8A details gallery. Feel free to poke around my other photos. There are a few very old photos of T-37 formation aerobatics by one of my pilot training classmates that are fun.
Terry
Bret Smith
Posted: Mon Jul 21, 2008 4:38 am Post subject: IO-360 with vertical sump |
Thank you Terry, very nicely done. That is a great help.
Bret Smith
RV-9A "Canopy"
Blue Ridge, GA
RV-9A (Emp) |
rv9jim(at)juno.com Guest
Posted: Mon Jul 21, 2008 1:08 pm Post subject: IO-360 with vertical sump |
Bret,
I have AFP FI on my IO 360 and I made custom brackets. You can
see them on my web site at www.websites.expercraft.com/jimn and if that
is not enough, I can e=mail you the pix I took to mount the system. I
used the material that AFP provided and cut pieces to make up the
brackets and had them welded to mount the cables. I could have had a
longer mixture cable and it would have been better. THe only fire wlall
position that matched up was for the throttle. I made the bracket such
that it was a straight shot to the throttle linkage. The mixture bracket
was such that I had the cable come down from the top , just clearing the
fuel pump and terminating with the lainkage working thru the vertical
mode. That penetrated the fire wall thru the off set for the oil filter.
I have a 90* adapter so the filter mounts in the "vertical mode. That
freeded up that area. Again, if you want more pix I can send them to
you. It all works out fine as I have 5 hours TT on the airframe, Just
cleared to fly--- keep pounding as they are fine birds to take flight.
Jim
N15JN
RV9-A
Click to go wireless with your computer, ultra fast speed.
http://thirdpartyoffers.juno.com/TGL2141/fc/Ioyw6i3nBfh6waxgErL6pKmmEtM69b28YvrMWxREGklL0jPlXqBacz/
Fred.Stucklen(at)UTCPower Guest
Posted: Tue Jul 22, 2008 3:41 am Post subject: IO-360 with vertical sump |
I'm installing the Precision Silver hawk Fuel body, which is essentially the same as the old Bendix unit, on a vertical sump TMX IO-360. It would appear that Van's IO-320/360 Throttle/Mixture bracket will work for this fuel body….
So now I only have to determine where the firewall penetrations will go, and how long the cables need to be….
Fred Stucklen
RV-7A N924RV (Hope to be flying by 9/1/08….) [quote][b]
Bret Smith
Posted: Tue Jul 22, 2008 4:39 am Post subject: IO-360 with vertical sump |
Thanks Jim,
I have used your site several times and it has been very helpful. Thanks
for doing such a great job with it.
Bret Smith
RV-9A "Canopy"
Blue Ridge, GA
RV-9A (Emp) |
